Question about Dell Latitude D410 Notebook
Swithc on bluetooth compaq6720s
Switch on Bluetooth
My bose bluetooth mobile won't link to my apple I pad,when I try to link them ,my I pad tell me that the sound system is not on
Switch your Bose Speaker off.
Open iPad - Settings - Bluetooth - Switch Bluetooth Off
Switch iPad Bluetooth On and quickly switch Bose Speaker On.
They should talk to each other as they find each other and fall in love :>)
Bose Bluetooth speakers from I-pod are listed in the link below with manuals.
On my Bowers and Wilkins T7 Bluetooth speaker you have to press the Bluetooth button on the SPEAKER the first time you connect it. After it is paired, it finds itself as soon as the speaker is turned on. I can highly recommend the B&W T7.
BLUETOOTH Speakers Bose
Jan 02, 2016 | Apple Bose SoundDock Series II Digital...
Can't turn bluetooth on. If I restart the phone and then turn on bluetooth, I get a message "Switching On Bluetooth" but it doesn't turn on. After that, nothing happens when I select "on", not even the...
Set up a Bluetooth connection
Select Menu > Settings > Connectivity > Bluetooth and take the following steps:
1. Select My phone's name and enter a name for your phone.
2. To activate Bluetooth connectivity select Bluetooth > On. indicates that
Bluetooth is active.
thanks
May 16, 2010 | Nokia 6301 Cellular Phone
To disconnect a bluetooth headset or delete it do i need it swithced on?
why do you need to delete it, if your trying to use your headset on another device just lookup how to put you device back in descovery mode and use the other device to connect to it.
Sep 21, 2009 | Video Game Consoles & Games
Jabra BT125 headset not connecting to Samsung F480
you have to switch the bluetooth headset to pairing mode not just swithcing it on. Hold the power on button continuously even after it switches on then the light will remain on. Then you switch on the bluetooth in the mobile and start searching for bluetooth devices. You will find your bluetooth headset in the mobile. Select it and pair. Usual code will be 0000, but it might differ check with the manual which can be found online too. This will definitely solve your problem.
Sep 10, 2009 | Jabra BT125 Headset
How do I enable bluetooth in my Acer Extensa 4420-5963
Actually Acer use the same laptop case for some of their models, so the acer 4420 doesn´t have built-in bluetooth, you won´t find any driver for the bluetooth cause that reason. I have an extensa 4420-5910, have a bluetooth switch in the case but no bluetooth, if you check at Acer´s web page it say thet some models doesn´t have built-in bluetooth but the switch is in the laptop case... On the other hand, if you install an external bluetooth device, the case switch will be usefull to turn it on and off.
Mar 13, 2009 | Acer Computers & Internet
HTC Bluetooth Issues
May be a power off time limit for bluetooth in the settings somewhere.
i.e. switch off if not sending or recieving a signal from another device.
Mar 26, 2008 | Computers & Internet
Bluetooth
my bluetooth device not working. if i try to start it laptop say NO BLUETOOTH DIVICE.so what can i do?
Dec 12, 2007 | Acer Aspire 5100 Notebook
Faulty Sony Ericsson Blutooth
Well i also have a z530i and my screen broke . my bluetooth hasnt done that and i dont have a problem wiht my nokia 6233 or my n95. but i suggest you look on your infared settings and then turn it off IF it is on . then go back onto bluetooth or go on your shortcuts ( bottom left button ) and click bluetooth . if this doesnt work , just take it to a shop and ask for there suggestion. Hope i helped
Oct 17, 2007 | HP iPAQ H2215 Pocket PC
Dell Latitude D410 Notebook Logo
18 people viewed this question
Alun Cox
