Question about Olevia LT42HVi 42 in. LCD Television
TV will not turn on or of m#242511 OLEVIA
Some times the blue power butten stays blue when your trying to turn it on and does notta
    Top Expert:
  • Olevia Master
  • 74,617 Answers
Sounds like a main power regulator board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Posted on Apr 01, 2014
I have a Olevia lt37hvs, When i plug it in the blue(olevia)light comes on then goes off and the screen will be blue for 5-6 second then go black for 1-2 seconds then screen goes blue again and it just...
tried to connect again the supply for main board and disconnect the supply for the inverter board of back light. and turn on the tv, if the indicator stay the inventer board was the cause of voltage drop at the power supply board.
Sep 08, 2012 | Olevia LT37HVS 37 in. LCD HDTV
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
I have an Olevia 42"
The issue you are having is your power supply
Thank you
www.orlandolcd.com
Dec 07, 2010 | Olevia LT42HVi 42 in. LCD Television
Television will not come on, blue light stays lit
jtoddweaver, Check out some YOUTUBE videos of lcd monitor disassembly and lcd monitor repair so you will know what you are looking for that is bad on your unit's "switch-mode-power-supply" printed circuit board. If you do the repair to the board, please document your "tear-down" with video or digital still pictures so you can complain to OLEVIA about poor quality capacitors they installed on power supply and also aid in the reassembly process. Do some reading in the fixya profiles of "budmrtn" "buddymc" "12fixlouie" and follow links you find there. Bye for now 12fixlouie
Jul 30, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
I have an olevia tv model number 542-13-11 and it will not turn on. Any suggestions would be appreciated. lindafranks@hammondhenry.com
do you get a blue light on ? if you do that means you have power so..it could be the main-board is bad on the television. But if you have no blue light on the front of the television then you have no power. You could try switching the power switch on the back of the television several times and see if you get any type of blue light on the front of the tv. If you don't then try connecting the power cord to a power strip or straight to the wall.. if you still don't get power try disconnecting the power cord from the television overnight and then plug it back in and see if you get any sign of power.. if still no sign of power then the television power supply is bad and will need to be replace or repair..
Since the manuf. of OLEVIA is out of buss ..you have this 3rd party repair center that is able to provide you with a repair quote call this number 866-965-3842 the company is called Amergence Technology who is able to repair and service all OLEVIA HDTV products..
Jul 21, 2009 | Olevia LT42HVi 42 in. LCD Television
Olevia 332h comes on for a few minutes then turns off
I have the same problem with my Olevia 332h. The TV shuts off after 10 seconds. I decided to wedge a desk fan in between the wall and the back of the TV. It worked! The TV doesnt shut off anymore. This problem is obviously heat related. I hope this information helps you.
Jun 03, 2009 | Olevia LT23HVX 23 in. LCD Television
Olevia LT26HVE Power issues?
Finally recieved an email from syntax olevia customer support after 1 month. a standard desktop computer power cord is all you need for your Olevia LT26HVE flat screen. We lost ours in a move and FINALLY have it up and running again...for only 9 bucks at RadioShack!
Dec 07, 2008 | Syntax LT26HVE 26 in. HD-Ready LCD...
Power problems
I have a 32'' olevia 232v hdtv. I had a similar problem where the tv stays on less and less as you use it longer and it gets warmer. I called customer service and they explained that its most likely a problem with it is doesnt have enough power to run well. They said turn the TV off, then hit the master turn off switch in the lower back of the tv, then unplug everything from the TV, then unplug everything from the wall. Then after 3 or 4 hours, plug all back in and try again. Then they said if i still have a problem, call customer service at 1 866 9 olevia
Sep 29, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT42HVi 42 in. LCD Television Logo
24 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
