Question about Tascam Audio Players & Recorders
Cannot open the draw , when the disc is in cannot start playing after short attempt of spinning 3 times
It looks like some mechanical problem between the motor and transport
5 Suggested Answers
SOURCE: SONY CDP-C450Z 5 disc changer.
Yeah
Posted on Feb 13, 2008
  • 2976 Answers
SOURCE: 5 disc cd changer CC4000 will not read
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Posted on Dec 06, 2009
  • 6771 Answers
SOURCE: cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Posted on Apr 15, 2012
SOURCE: Nad C542 Troubleshooting
found same problem with mine, solution .. place clean paper over the optic, then a magnet, leave for a few seconds, the build up of static causes a magnetic field in the optic preventing it tracking, have cured a few other brands with this as well .. shows manufactures are putting inferior parts in to their players, hope this helps !!
Posted on Apr 20, 2013
SHUFFLE PROBLEM
The playing mechanism has failed.
Nov 10, 2013 | Audio Players & Recorders
Sony dav dz100. Disc does not spin.
Please put few drops of WD-40 on spindle motor shaft that sound not spin smoothly.
Spindle motor is located in middle of dvd mechanism that holds and spins disc.
If that does not solve your problem, replace optical block.
Let me know if you need optical block part number.
Thanks.
Dec 05, 2009 | Sony DAV-DZ100 System
I have a kenwood compact hi-fi system xd-751 the 3
I have a Kenwood hi-fi system XD Series. the three disc draw won't open or play discs. The table shudders when on...can anyone please find a repairer in the adelaide district.
Dec 04, 2009 | Kenwood Audio Players & Recorders
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
I have a dimensionsC521 that has swallowed my cd disc. It is an awkward cd slide since the cd does not stand upright and so I usually tilt the tower over so it doesn't slip out. Now it slipped out and the...
I suspect this is more a mechanical problem than a power or software problem
I suggest powering down your PC,
Laying it down so the CD draw is flat,
Fashioning yourself a home made cd draw ejector device (otherwise known as a straightened paper clip),
Pressing the paper clip quite firmly into the tiny hole next to the CD Draw (it should unlock and open slightly)
Carefully and gently pulling the CD Draw out just enough to see inside and find out where the disc has got to
Physically maneouvering your whole PC to get the disc back onto the tray where it should be
Then you can either manually pull the CD Draw out and remove the disc or start the PC while it's laid down flat and see if the CD Drive auto closes and begins to spin now the disc is properly seated
If your PC doesn't have the tiny hole on the front of the Drive or if the CD Disc cannot be seen at all or cannot be persuaded back onto the tray then it's time to start opening up your PC case and removing the CD Drive for more attention
- NOTE if your PC is still under warranty Opening the Case may invalidate that warranty, check this before you proceed -
Treat Everything Gently and Good Luck!
Sep 16, 2009 | Dell Dimension C521 PC Desktop
I have a sony dvd player (dvp-N5725p) and it says cannot play disc now. I hear it trying to spend but nothing no play or anything it spins until it states cannot play disc now.
Try to clean optical lens of dvd player with soft and nice quality cotton bud / swab by opening top cover of player.
There might be chance of lens sled mechanism stuck so move lens left-right for 2-3 times.
If cleaning doesn't work, you need to replaced optical lens.
Oct 23, 2008 | Televison & Video
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
No disc displayed
The disc won't spin until the unit recognizes that there is actually a disc there. Try cleaning the lens using a cotton swab and alcohol. If that fails, try playing a CD. If the CD plays, the optics are starting to fail as reading a DVD requires higher laser power.
Dan
Mar 19, 2008 | Cyberhome DVR 1600 DVD Recorder
Aiwa 3 disk CX-NMT 70 MODEL SPINS A FEW TIMES ON EACH DISC..wont play at all..What can I do? Thanks!!
This can be fixed by adjusting the POT on the rear side of the laser. My Aiwa had the same issue and there is an orange screw on the rear of the laser. Turn it about 1/16 - 1/8 turn COUNTER clockwise.
Please understand, this is a temporary fix, and will eventually ruin your laser mechanism completely. The company is out of business and the unit is 10 years old, so I didn't much care...perhaps I will run across a CD assembly I can replace it with, but this is a temporary fix for this issue.
Oct 16, 2007 | Aiwa NSX-DS55 CD Shelf System
Disc loading problem
disk draw timing is probably out ( gear or mechanism jumped out of time
Jan 23, 2007 | Cyberhome DVR 1600 DVD Recorder
37 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
