Question about Kenwood Excelon DDX-7015 Car DVD Player
Bought the kenwwod 7015 but it wont turn on fuse is good
Stereo is not blown cause when connect it battery direct it sparks so its getting power but screan is blank
2001 Stratus Coupe. new battery and starter. engine wont crank when i turn the key. also no dash lights
You need to clean all the batt. and starter solenoid connections.
make sure they are tight
make sure to clean batt neg wire at body connection
check your fuse link to starter from battery,
a 6 inch section of thinner wire designed to burn out to protect starter. this is why you can jump starter you bypass the blown fuse link.
mike
Mar 25, 2016 | Eastern 2001 Dodge Stratus - Coupe, 2.4L...
04 Polaris predator, I bought used last week. I put a new battery and new carb on it. It doesn't have power, won't start, and no spark with kick starter. Dead. Fuses,wires, look good. Any ideas
Did it have compression before you bought it?
No power to the electric starter? Then you probably have no power to the ignition system. I'd check battery connections. Is the battery going flat overnight? Some shorts. Is there an ignition with a key? Is the switch good? or all the connections good? Corrosion does some funny things. Fuses may look good but actually are not.
Apr 02, 2015 | ATVs
Hey there, i have a kenwood cd receiver kdc-mp142 and it doesnt work, i connected it directly to a battery (not in a car). When i connected it it sparked and shut off, the fuse is not blown, and idea why...
Hello... the wiring diagram is here...
http://download.tigersea.com/caraudio/kenwood/kdcmp142/manuals_file/178700.pdf
Try to connect separates speakers( not the installed in the car) If your car stereo dont turn ON... then there is a short circuit in the audio power circuits.
Jan 14, 2015 | Kenwood Car Audio & Video
Spark caused vaccum to turn off
Some vacuums have a reset button you can push. Some have a fuse in the power line that may have blown. You will have to follow the power all the way through the vacuum checking the voltage at each switch, connection, etc. I often unhook the power & neutral wires from the motor and hook up a power cord with connectors on the end directly to the motor to make sure the motor is good. You must be very knowledgable with motors, switches, electrical testing, etc. If not this repair is best left to a professional.
Mar 03, 2014 | Dirt Devil Vacuums
Car stereo short circuit. Won't start.
Worse case, fried body ground. Which will feed fuel pump. And surrounding circuits. Check every point for a good ground to body. Then check fuse panel for blown fuses.
Jan 15, 2014 | Cars & Trucks
Spark plugs
If the lights won't even come on, the spark plugs are not the cause of that problem.
Make sure the battery cables at the opposite ends from the battery are connected tight and corrosion free.
Check that all the fuses are good.
For some reason the power isn't getting from the battery (if it is in fact charged up) to the electrical circuit (blown fuse, loose/disconnected wire, etc).
Jan 03, 2014 | Honda Motorcycles
1993 volkswagon passat VR6 wont start
Sounds like a blown fuse or wiring problem.
A mechanic would check to see if the starter will crank with power direct from the battery, then look for power to the starter from the key switch.
Jul 12, 2012 | Cars & Trucks
JVC KD-LX333 car stereo turns on, but then shut off and wont...
TAKE IT OUT AND TRY IT ON A 12V BATERRY AND IF IT TURNS ON ITS GOOD AND IF IT DOESNT IS NOT GOOD. IF IT TURNS ON FOLLOW UR CONSTAN AND UR POWER WIRES AND SEE IF IT HAS A FUSE BOX IN THE BOAT/ CHECK THOSE FUSES. AND CHECK UR BOAT BATTERY TOO CAUSE IT COULD HAVE DIED WHEN TESTING THE STEREO TOO IT HAPPENS ALOT ON BOATS
Jul 04, 2009 | Sony CDX-GT210 CD Player
I have an issue.. my battery died yesterday the guy who jumped my car messed up and attached the jumper cables wrong on his battery. Now my kenwood excelon ddx 7015 wont turn on at all do you think it is...
Hello Melissa,
The first thing I would check is if your fuse is okay. If your fuse is blown replace and try to turn on the radio. If the fuse is good have the radio taken out and have it bench tested. take the power wire and the memory wire put them together and apply power to them then take the black wire and connect it to ground if the radio turns on then its okay and he fried something else. If the radio doesn't turn on then chances are that he fried it.
You can use a car battery to test your radio or a portable boost jumper.
Hope this helps you.
Dec 03, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Kenwood Excelon DDX-7015 Car DVD Player Logo
69 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
