Question about Edimax (PS-3205U) Print Server
Printer Server - Fprgetten Password
Havent used print server in ages, come to reconnect it today and cannot remember password, reset button doesn't work. Help!
    Problem Solver:
  • 12 Answers
If it helps, here is a link to the user manual for that print server. Good Luck!
http://www.edimax.eu/images/Image/product/PS/PS-3205UWg/manual/PS-3205UWg_M.pdf
Posted on Jul 02, 2009
Reset brother mfc8880dn
If you wish to reset the print server back to its default factory settings (resetting all information such as the password and IP address information), please follow these steps. Before you factory reset the print server, we recommend that you print a configuration page before resetting the print server.
<For BRAdmin Professional ver.2.xx Users>
Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
  1. From the main BRAdmin screen double click the appropriate printer.
  2. Enter the print server password (The default password is "access").
  3. Click the Control tab
  4. Click the Restore Factory Defaults button
  5. Click the OK button when you have read the warning message.
  6. The print server will then reset back to its default values.
<For BRAdmin Professional ver.3.xx Users>
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional 3 => BRAdmin Professional 3.
  2. From the main BRAdmin screen double click the appropriate machine.
  3. Enter the print server password (The default password is "access").
  4. Click Network Configuration tab, Control Panel and select Set Default.
  5. Click on Submit button.
Via a web browser
Because web based management requires the TCP/IP protocol for communication, any reset option you see when managing the machine with a web browser, will not reset the IP address details that are set. If you wish to totally reset all the print server parameters we recommend you reset the print server by using the BRAdmin application.
To reset the print server (excluding TCP/IP parameters) follow these steps:
  1. Connect to the printer using a web browser.
  2. Click Network Configuration.
  3. Enter the print server password (the print server password is detailed in the user guide for the print server) if it's applicable.
  4. Click the Set Default link or Reset Print Server.
Via the control panel (only for network ready models)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN or Network and press Set, Menu/Set or OK.
  4. Press up or down navigation key to select Factory Reset or Network Reset and press Set, Menu/Set or OK.
  5. Select Reset.
  6. Select Yes.
  7. The machine will re-start, re-connect cables once this is complete.
Jun 19, 2014 | Brother Office Equipment & Supplies
Reset password on hps1p
I would suggest your download PSADMIN and Installation software from Hawking then push the reset button on the print server and start again.
Nov 22, 2013 | Hawking 10/100 PRINT SERVER MINI 1...
Password????
Dear gbp7292, to access the admíns CP on this system yuou may try some of these "default" user and password combinations:
User System Password Manager
User Admin password 0000
User empty password 01234
If this still doesn't works, try doing a hard reset. To do this you will need to hold the reset button for 30+ seconds. After that, you'll have to reconfigure everithing.
Dec 06, 2010 | Linksys WPSM54G Print Server
How to reset a brother mcf-7420 printer?
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
  2. From the main BRAdmin screen double click the appropriate printer.
  4. Click the Control tab
  5. Click the Restore Factory Defaults button
  6. Click the OK button when you have read the warning message.
  7. The print server will then reset back to its default values.
Via a web browser
  5. Select Reset.
  6. Select Yes.
  7. The machine will re-start, re-connect cables once this is complete. please rate it
Nov 29, 2010 | Brother MFC-7420 Printer
What is the default password for D-Link DP-300U print server? Thank you
The D-Link DP-301U Print Server does *not* have a password by default. If you have come into the possession of one and it is password protected, then it is likely that the previous owner added a password.
In order to bypass it and reset the Print Server, while the device is powered on, you will have to hold down the RESET button on the back using a paper clip for 10 seconds.
[NOTE: If this helps, please leave feedback.]
Aug 11, 2010 | D-Link DP 301U (DP-301U) Print Server
Factory reset brother nc 2010h
Same problem, did you find a solution ?
Pascal
Nov 11, 2009 | Brother (NC-2010H) Print Server
How can I reset my printer derver dp-300 to factory defualt values? Close
how reset password for dlink 300 print server please give me solution
Nov 11, 2009 | D-Link DP 300U (DP-300U) Print Server
How to reset Admin password D-Link print server DP-301P+
Unfortunately the D-Link Print Servers are secure and cannot be reset without the password. The unit will have to be sent to D-Link to be reset.
Apr 17, 2009 | D-Link DP 300 (DP-300) Print Server
Dp301p+ psadmin password was forgoten
Problems with your D-Link DP-300U LOST IP If you’re like me, you have a ton of computer **** laying around your house. Today I found an old D-Link DP-300U print server laying around and thought that I could put it to good use. The bad thing about these things is the fact that they do not have a hardware reset button on them, so if you forget the IP or the Password, you’re pretty much hosed… or so I thought. After doing some google searches for how to find a lost IP, I came back empty. The PS Admin program that D-Link publishes for use with this thing couldn’t find it on my network either. After some thinking, I came up with an idea.
If you know anything about networking and how networks work, you should have thought about this too. Get a Wireshark capture running. Unplug the power from the print server and then replug it. It’s going to send out an ARP on the network looking for it’s gateway which should be picked up by Wireshark. It should look like this:
capture.jpg In my case, it came back as 192.168.1.253. After changing the IP on my laptop to fit that subnet, I was able to log into it via it’s web interface (there was no password on it thank God!) and put it back to factory settings. Voila! What once was a brick is now a working print server!
I Copied it!
Shafiuddin Russel
infoshafi@gmail.com
+8801714073692
Feb 16, 2008 | D-Link DP-300U (DHDP300U) Print Server
Cant change or remove the password.
with some system you will have to use ctlr H before the password system
this removes the space so the password is correct
Aug 03, 2007 | Emulex NETQue Print Server
Edimax (PS-3205U) Print Server Logo
324 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Rommel Balcita
Michael Galve
Michael Galve
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
