Horizental line on screenwith voice
When we start tv we have seen a horizental line in middle screen & voice is clear, but one or two strock on right side of tv body screen restore as normal.
  • 380 Answers
SOURCE: Green vertical bar on right side of plasma TV screen
You could have one of three problems. One is really expensing to fix and you might want to trash the set. Thats if the panel is bad. Secondly, it could be a buffer board that went back. Not as expensive as the panel. Finally, it could be the connection between the two. I would first take the back off and locate this board. Undo the ribbon cable and clean it off a bit and put it back. If its still there, you have a deeper problem.
Posted on May 27, 2009
lilperrin
  • 6 Answers
SOURCE: Left Side of Screen goes semi dark
That Probaly Means Your ******* Kid Jerked Off All Over The Monitor *******
Posted on Jan 31, 2010
SOURCE: when I turn on my kdl-46xbr5 sony tv in the
Goto http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
Posted on Mar 19, 2010
SOURCE: Vertical colored lines on left half of screen.
I had this problem on a 37" Viewsonic LCD. Pulled it apart and through a process of elimination, I traced the problem back to a small board with several flat white ribbon cables coming out of it. The board was near the top center of the screen and under a ton of other equipment requiring almost a total disassembly.
This small board was clean but I noticed one of the rubber standoffs had slipped down and was making contact with one of the outputs running to the LCD. It also happened to be the output running to the section of the screen with the problem.
I postulated that the sticky glue on the rubber standoff may have just enough conductivity to cause a problem. Moved it so that it was no longer touching anything electrical and then reassembled the TV.
Afterwards, I turned it on and was pleased to see the problem has gone away! If you're having the vertical line problem, then maybe this could be your problem too, especially if you have a Viewsonic since it could be a manufacturing defect.
Posted on Mar 22, 2010
agibbsholden
  • 30 Answers
SOURCE: Black vertical column
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Posted on Oct 30, 2010
How may I fix colorful vertical lines on screen but clear voice on Sharp Aquos TV when I first turn it on?
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 13, 2015 | Sharp Aquos Televison & Video
How to clear a square on tv screen that has a black rectangular block in middle of picture?
it could be you have pressed the old teletext service button, look for a button with 3 lines on it in a box and press it or try turning the tv off at the plug then back on again.
Jan 22, 2015 | Televison & Video
Horizental line center of the screen
Horizontal thin bright line across the screen, denotes the vertical sweep failure. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 17, 2014 | Vizio Televison & Video
White horizental lines across the LCD Monitor.
This is a high voltage horizontal output problem. Could just be a loose connection or an intermitant component failure. If you can get into it, check for any loose connections. Sometimes this can also be caused by a large accumulation of dust. Make sure you unplug it before opening it up.
Apr 04, 2012 | HP LP2465 24" LCD Monitor
My Panasonic HDTV has sound but no picture
I have a question : Is the line a faint band top to bottom towards the middle or to the right of the screen?
This was a fairly common problem if you can confirm it?
Nov 13, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Blue haze/blob near the center and lower right corner.
Failing optical block. check this website
http://sites.google.com/site/sonylcdrptvproblems/sonykdf-55wf655opticalblockreplacement
Mar 08, 2010 | Sony KDF-E50A10 TV
Horizental lines on dell inspiron E1505 monitor
Sorry to say but screen needs to be rplaced you can find one on ebay for about $100.
If you find this helpful please rate so.
Thanks
May 06, 2009 | E-Machines e15t 15" Flat Panel LCD Monitor
Audio ok, no video
I’ve never seen this kind of video output caused by a bad video cable or bad FL inverter board. it was fixed after I replaced the monitor
Apr 03, 2009 | LG Flatron F700B 17" CRT Monitor
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Jul 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
