Question about Karcher Garden
Water coming out of detergent pipe from top for karcher 3030 b jet wash
How can i stop water coming out out of detergent feed pipe when I switch karcher 3030b on
    Guru:
  • 145 Answers
DISCONNECT HYDRO OR WITH ENGINE NOT RUNNING DISCONNECT SPARK PLUG THEN RE-LEAVE WATER PRESSURE BEFORE SERVICING the detergent pipe plugs into a pipe on the pump, under which is a spring and ball bearing (stuck open, debris) WEAR YOUR SAFETY GLASSES
Posted on Apr 16, 2014
SOURCE: B302 - unable to start detergent flowing - How should it work?
It will only pick up detergent if you use a low pressure detergent nozzle - or no nozzle at all. It also takes a while for the detergent to get to the nozzle.
Posted on Nov 19, 2007
  • 14 Answers
SOURCE: where can i put lubricating oil for karcher jet wash machine
It sounds like you are referring to the oil in the swash plate housing. You can use a multi grade motor oil such as 20w50 or 10w40. Fill to about half way over the swash plate. If the old oil has gone amilky colour, please replace the oil seals first.
Posted on Mar 11, 2009
Testimonial: "post was very helpful and i am going to replace o ring rubber seal where i suspect oil is leaking and also fill it with oil.Thanks very much"
aroostookb
  • 98 Answers
SOURCE: Karcher detergent draw problem
return it to Walmart
Posted on Jun 23, 2009
  • 34 Answers
SOURCE: hi ive got a karcher
This seems strange, as it is under warranty you can take it back or contact them about the situation. It depends were you purchased the machine but if it is a manufacturers fault they will fix/replace it.
Posted on Jan 17, 2011
Testimonial: "thankyou yes thats what im going to do"
bigomoe
  • 12 Answers
SOURCE: LOST KARCHER INSTRUCTION BOOK, ARE INSTRUCTIONS ON LINE
Here is the offical link to manuals and warranty cards for the residential models of Karcher Pressure Washers
http://www.karcherresidential.com/us/Service/usermanuals.htm
Posted on Mar 04, 2012
Washing machine willstart agitating while running water.
there is a sensor that is feed from the drum bottom pipe if this becomes blocked it does not tell the washer to stop feeding. it should feed 2-3 times but in between these feeds the drum spins, then stops and then feeds and stops. the switch is a pressure switch so the pressure turns on and off the switch the pipe can get blocked and stop the pressure switch working. it will need to be removed and clean out. you can clean this out from the top of the washer, take the top off and you will see a round space ship like thing that's the presure switch it has a pipe and wire attached to it , remove the pipe and blow down it, if it blows out fine replace the switch as it must've become faulty. they are easy to find and not dear to replace.
Aug 14, 2017 | Washing Machines
Fisher and Paykel top loader washing machine, won't stop filling up with cold water
The pressure switch usually has air in the feed pipe which sometimes gets water into it which then fails to notify the system when to switch off water supply which then prevents the relay to the motor to start.check the feed pipe so it is empty of any water.this will allow the pressure switch to work properly.if the switch has failed you can get replacement part from eBay.
Dec 05, 2014 | Fisher and Paykel Washing Machines
Water coming out of detergent pipe from top for karcher 3030 B jet wash.When i start using the jet wash there is not enough pressure and water starts coming out of detergent pipe.How can i stop water...
remove deterfent pipe,unscrew detergentnozzle carefully, inside is spring and ball bearing, clean and re-fit, replace if missing. spring on upstream (soap) side
Apr 03, 2014 | Karcher Garden
I have karcher k4.98. I can not get the detergent to come out. I have checked the trouble shoot in the manual and all items are ok. Any ideas ?
Just had the same problem, brand new machine, the detergent feed pipe was squashed under the bottle holder bracket!
Dec 30, 2012 | Karcher Garden
How did I get the film off my glassware? My glassware has a thick film that is very unappealing. I have to hand wash them. I use cascade detergent.
If you are not using a water softener use a rinse aid such as Jet Dry. This will help to eliminate scum on glassware. Use the solid form of Jet Dry. If you use a water softener you need to decrease the amount of detergent.
You can determine the cause of cloudy glassware by soaking a glass in vinegar for 5 minutes. If the cloudiness is removed it is a hard water deposit and more detergent is likely needed. If the cloudiness is not removed it is a permanent condition known as etching. In this situation, use less detergent and stop pre-washing. In actuality, dishwashing detergent needs a bit of soil to work on, otherwise it will tend to foam up.
Mar 12, 2011 | Whirlpool Dishwashers
Water over flowing from detergent drawer
If machine is just filling all the time till water comes out detergent drawer then this will be a pressure fault. Most likely a blockage.Unplug your machine and remove the top. You will see a round switch with a number of wires going to it and a thin pipe at the bottom of the switch.This is the pressure switch that controls the level of water. the water goes into the pipe at the bottom and builds up air pressure within the pipe which operates the switch. the water should never come up this pipe to the switch.
You now need to follow this pipe down to the bottom of the machine. There it will be fitted with a small spring clip to a pipe, or small chamber. This is where your blockage will be and you now need to find something to clear this without damaging any parts. When done replace all pipes secure and test machine.Now you are hopefully satisfied that this was your problem. Goodn luck
Mar 12, 2010 | Washing Machines
Karcher k3.91 how do i change from just water to soap
Twist the end of the nozzle or jet pipe until you get low pressure. This will **** the soap through
Aug 16, 2009 | Karcher PSI Electric Pressure Washer
I have a Karcher 3.99 Pressure Washer. The motor appears to be working and water is passing through the machine when turned to the detergent application setting. However when the lance is tightened to turn...
Hi I have a karcher 3.99 the motor comes on and water comes out however thre is no pressure i have tested the lance on my brothers washer and this is ok what is wrong
Feb 21, 2009 | Karcher K 5.85 M Electric Pressure Washer
Water gushes out of the inside of my Karcher jet washer.
you can sometimes seal the water leak from the inside as I think your water inlet case has split
Jan 07, 2009 | Karcher Quick Connect Nozzle Set
Garden Logo
249 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
