Question about Panasonic Heating & Cooling
Error code f33 what does this mean?
Air con turns on and then shuts off automatically after a few mins of working. First problem in over 10 years
Krazytech
  • 725 Answers
SOURCE: kenmore elite he4t
really need the whole model # ?
1 pressure switch
2 flowmeter
3 CCU
4 hose
he F33 means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch, the flowmeter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Posted on May 20, 2008
  • 57 Answers
SOURCE: F33 error code
F33 System leak If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
1. Check for crack or holes in the washer tub and pressure switch hose.
2. Replace components if necessary.
Posted on Jun 24, 2008
aborcass
  • 2651 Answers
SOURCE: whirlpool duet sport. I am getting a f33 error code.
i would look for a small blak rubber tube running frim the pressureswitch tothe back ofthe tub, its possible that the tubing if either clogged or ripped, and is not able to detect current water level inthe machin causingthe F33. 3 screws from across theback will release the main top, from thereyou an locate the hose back right corner i believe
Posted on Mar 12, 2009
relaga58
  • 158 Answers
SOURCE: LG 3phase ducted CH02 fault
indoor pipe thermistor is possibly defective, to check it you must know how to use multimeter or just replace the thermistor.
Posted on Jul 24, 2009
tbirdfan1
  • 3051 Answers
SOURCE: remote doesn't work on air con
Should be current detect pcb faulty, or compressor drawing too much current.
I don't have your model a/c, but panasonic fault codes stay pretty much the same
Normally panasonics have this info on the inside of the access panel.
Plus fault codes from the indoor unit make it easier to look up.
if the compressor is running, check the amps and refrig pressures.
Posted on Sep 19, 2009
My electrolux split system air con model #KSV53HRA turns off and shows an E1 error after about 10 min
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Error code details are goven.
Mar 19, 2016 | Electrolux Heating & Cooling
Rinnai RL94i - Produces hot water for 3 minutes, then stops
I just had this exact problem. It kept getting worse until we had no water. Our Rinnai tankless hot water heater started the same way though, with hot water for a few minutes and then would shut off with an error code 10. We just had to shut the hot water off and then back on, wait a minute or so and we had hot water back for a few minutes. Our unit would come on with a loud vibrating noise and remain until it shut off with an error code 10 (air flow fault). The solution was to remove the blower fan and blow out the squirrel cage. Ours had moths in it. We also vacuumed out the fan housing. Be careful to mark any wires you disconnect and take pictures before removal. Our unit is now almost silent when it comes on and supplies endless hot water.
Jun 10, 2014 | Rinnai RL94i Tankless Water Heater
What does F33 mean- its the code on my front loader washing machine
"F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch. The flow meter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Thank you !!
Jul 15, 2010 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore He2plus washer that gives me an error of F33
Thank you !!
Jun 19, 2010 | Kenmore HE2 Plus Front Load Washer
I am getting a S2 and a f33 fault and the washer is not draining what is the problem?
Hi, "F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch, the flowmeter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Apr 10, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore washer he4 has error code f33
F33 is a PUMP DRIVE SYSTEM ERROR
This could be a bad pump or just a loose or bad wiring connected. You could try unpluging it for say 10-15 min and then plug it back in try to run a cycle see what happens. If it does it again the wiring to the pump and or the pump itself will need to be tested. If it is still under warranty I would call sears.
Mar 19, 2010 | Kenmore Washing Machines
F33 error code. drum begins to rotate and then
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore elite he3t model 4596640 year 2005 f33 code
May 05, 2009 | Kenmore Elite 45986 Front Load Washer
Panasonic reverse cycle aircon.
Found the codes are printed inside the air conditioner.
F33 ---01. = locked up compressor.
Cannot fix this problem myself, will have to engage a serviceman.
Stan.
Jul 15, 2008 | Heating & Cooling
Kenmore elite he4t
1 pressure switch
2 flowmeter
3 CCU
4 hose
May 20, 2008 | Kenmore Elite 45986 Front Load Washer
Heating & Cooling Logo
19 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
