Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Machine totally unresponsive just blinks model with letters AU after it" for model UF 885
  • 37 Answers
This may just be a faulty toner cart...try replacing that first. If not try what FixinFax says, :)
Posted on Jun 19, 2009
    President:
  • 3,085 Answers
Remove the toner cart
Pull up on the operation panel to open
unplug the machine
hold down the pointed switch near the **** glass while plugging the machine back in.
wait for the beep
close feeder
scroll down to SHIPMENT SET
press SET
press 2
press SET
wait for the machine to initialize
Posted on Jun 15, 2009
I would like to forward my faxes to another fax machine. the fax machine that i am using is panafax uf-885. how do i do that
Try entering *72########### where #=fax # that you want to forward to. To end forwarding, enter *73. This depends on if your carrier supports call forwarding.
Jun 10, 2011 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF885 unresponsive. Display is flashing UF-855 (AU). I replaced the battery and even went back to Radio Shack to make sure it was a good battery. I also tried: Remove the toner cart Pull up on the...
Hi, you have done all you can do. Your fax machine has a bad main board. At LEAST $600.00 to repair.
Sorry.
Just thought of something..... Lift the operation panel....There is a 5 inch log cover on the rear top of the machine held down with 1 screw. Remove the cover. if there is a memory card sticking up, remove it and try the shipment set again.
Nov 30, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
I want to delete the memory from my panafax uf 885 fax machine.
Press
Function
7
monitor key slowly 4 times
* star key
6
set
wait for machine to reboot
Nov 10, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
How do I programme a number into the memory of the fax machine?
Function
72
set
1 for 1 Touch
Press the 01 on the soft pad
enter fax number
set
enter name from soft pad letters
set
press 02
continue as before
when done press Stop
Sep 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF 885 replace battery
Turn the machine off for 10 seconds.
If the display shows 00% there is nothing in memory.
Apr 20, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Mar 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error code 634
Check your phone line by plugging a regular phone in.
Feb 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
UF-885 Panafax
Unplug the power cord in the rear of the machine
Open the document feeder by pulling it straight up
hold down the pointed switch by the scanner glass while plugging the machine back in until you hear a beep
close the document feeder
press SET or START
press 2
wait for the machine to reboot.
Dec 30, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
