Question about Century "Bob" Body Opponent Bag
CLEANING MOLD OFF OF MY BOB BODY OPPONENT BAG
I HAD IT OUTSIDE AND IT WAS PROTECTED FROM THE ELEMENTS BUT HAS COLLECTED MOLD AND WONDERING IF ITS SAFE TO USE ON THE BOB.
  • Alvin Lin
    Alvin Lin Apr 17, 2016
    I used sandpaper 150 grit and 200 grip on the BOB to clean off the mold. Then I used mild detergent to polish the exterior. It is very time consuming and laborious.
2 Suggested Answers
HondaCRX
  • 252 Answers
SOURCE: i have a cut in the neck of my bob body opponent
Due to the material that is used, I'd get some fishing wire and sew the cut up. Stitch it normally, then go back over cross-stitching to get double the holding capacity.
I'd then use some doctors tape, it's very sticky and will keep the cut together.
I know this sounds like doctors and nurses but it will work. Fishing wire isn't going to snap, the only problem I can see is the bob body might hang its head slightly when you pull the stitching tight. Either way a cut to the neck will make him look hard as nails :)
Hope this helps. Your vote counts a lot. Thanks.
Posted on Jul 13, 2010
When I turn the air conditioning on in my 2013 GMC Terrain there is the smell of mold. Apparently the air conditioner doesn't get rid of any moisture left after using it.
There is a procedure for this condition. GM says to flush the core with a cleaning agent they sale. I have found Lysol Fresh scent does a much better job of curing the condition.Spray the Lysol in the outside air intake vent while the vehicle is running with it set to max a/c and fan speed also on max. It will take about 1/4th can to fully clear the mildew smell and stop it from growth. When parking the vehicle always put it in max a/c position so the fresh air outside the vehicle will dry out the coil.
Mar 06, 2016 | 2013 GMC Terrain
Location of the Throttle Body on 2008 toyota rav 4
Hi harry, the throttle body is the part mounted onto the intake manifold and is held in place by four bolts and nuts. One side fits onto the metal of the manifold with a gasket between, and the other side has the rubber ducting from the air cleaner. The throttle cable and kickdown cable are fitted to it. On the other side of the throttle body is the throttle position sensor. Do not carry out any adjustments to it. Cover it with a plastic bag and do not allow any cleaning fluid to contaminate it! Resetting the sensor requires special adjustments and very careful settings and can stop the engine from starting once refitted. Regards John
Oct 24, 2012 | Toyota Cars & Trucks
How sturdy is a body punching bag device?
Technically, you can hit a BOB bag with the same amount of strength you would a traditional heavy punching bag; however it would defeat the purpose. When you hit as hard as you can your aim is to develop power, strength and stamina. These are not the same goals you would be working towards training on a BOB.
Aug 07, 2012 | Boxing
How do you fix the bob when it has a tear in its neck. the head is starting to come off.
I had the same problem, started with inch long tear in his adams apple ,eventually more than half his head was fallin off. I took a nice sharp knife and pirced a hole an inch above and below the tear every 4 or so inches and stuck zip ties through em. Feed the end of the tie through the top hole going inward. Do all the top holes like that. Once your done with the top feed the now inside ends of the ties outside through the bottom holes. Do this all the way across, THEN feed the ends through the locks and zip em tight. i then put a scarf on his neck to hide the tie ends, or i suppose you could tape em down. I dont think striking the ties will do any damage to your hands it just looks tacky. Make sure your holes are atleast an inch away from the edge of the tear so the ties dont rip through the "skin" inbetween them.
Jun 19, 2012 | Century "Bob" Body Opponent Bag
Century bob
Cheap plastic nipples are stripped out! Moving it while Bob is still attached & kids jumping on Bob's shoulders did the same to mine... I am going to try short bolts & nuts after dipping in plasti-dip/rubber product of some sort.
Nov 21, 2011 | Century "Bob" Body Opponent Bag
The dirt and mold collected by the rubber gasket is awful. Is there anything that can be done? cleaning? replace? prevent?
cleaning call frigidair they may have a kit or fix for that or leave door open a little so it can get air and dry
Oct 03, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have a cut in the neck of my bob body opponent bag. its about 1 inch long right on his neck. how can i repair the cut?
Jul 10, 2010 | Century Body Opponent Bag
Mold inside the home unit
You can use a spray bottle with 100% bleach in it to kill the mold. After spraying the gunk, you can put on some rubber gloves (those dishwashing ones are a good choice) and use some paper towels to wipe up as much of the mold as you can reach.
Spray more bleach on the parts you're cleaning to keep sanitizing the A/C unit and wipe everything dry. You should put all the stuff you used for cleaning it up (paper towels, gloves, etc.) into a plastic trash bag,
I'd also recommend that you do this when any small children and pets aren't in the room you've got the A/C in, and also wear a face mask to keep from breathing in anything that could cause a respritory ailment.
You can also use some Lysol disenfectant to give the whole unit a nice going over, once you're done, to be sure that you've killed any active mold spores. It might be good to give the unit a once-a-month cleaning to prevent the growth of mold in the future.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Century "Bob" Body Opponent Bag Logo
249 people viewed this question
Top Century Sport & Outdoor - Others Experts
Are you a Century Sport and Outdoor - Other Expert? Answer questions, earn points and help others
