Safe mode only start
Check your documentation; that may be a safeguard because there is a problem or corruption in Windows, so it auto-starts in safe mode so that you can troubleshoot. I am just guessing. Safe mode loads only the bare essential drivers to get Windows running, all peripherals are blocked because one of them is crashing Windows. I am just guessing, so check your manual that came with the computer. What you can do is a system restore to an earlier date; hopefully that will take care of it.
Windows 8:
http://www.bleepingcomputer.com/tutorials/windows-8-system-restore-guide/
(NOTE): SOME PROGRAMS MAY BE DELETED SO CHECK CAREFULLY
Windows 7:
Startup Repair: http://windows.microsoft.com/en-us/windows7/products/features/startup-repair
System Restore: http://pcsupport.about.com/od/fixtheproblem/ht/system-restore-windows-7.htm
Note that you will not lose any programs or data in Windows 7 System Restore.
SOURCE: How to start in safe mode Dell Optiplex GX 150
Is it booting to normal mode?
If it is booting to normal mode, click start - run and type msconfig.
Click on Boot.ini tab and Check Safeboot. Click Apply and Close or OK. It will restart the computer to safe mode. Remember to uncheck Safeboot to make the computer to boot in normal mode again.
SOURCE: i cant get into bios on acer veriton l410 pc
Try loging in as Administrator and then on restarting press F8or F10 as given in your manual, else enter into sfe mode as administrator and then again tru to enter BIOS as usal. Sometimes the TAB key also gives the desired results...sodeep
SOURCE: Computer will not boot up.
check for viruses in the system, it corrupts system boot up files, take time to load the os to normal mode, else repair the os, using bootable cd, it works.
SOURCE: computer not booting in safe mode
I'm pretty sure IBM Lenovo online support has a troubleshooting page to help you with your restart problem, but if you've looked there already, try to work through this article. Also see here for info on how to disable the restart and use a stop error code to diagnose the cause. Frequently this indicates a hardware or device conflict of some kind, but can also be a symptom of malware. In the latter case, I recommend you follow these malware removal protocols.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: Can't factory restore dell inspiron 531 (windows xp).
You might want to try going into setup and setting your boot drive options to DVD drive as your 1st, HD as 2nd and Floppy as 3rd. Put your windows disk in the DVD before boot and run the program from DVD.
