Question about Dual XDVD210 6.2" Touchscreen DVD Receiver
What do i connect the yellow wire, the blues and yellows to when installing dual xdvd210 in 2006 ford five hundred les
What do i connect the yellow wire, the blues and oranges to when installing dual xdvd210 in 2006 ford five hundred les
3 Suggested Answers
  • 74 Answers
SOURCE: there are red, yellow, and orange wires with
the red is for key power(gives power to it when you turn the key on) yellow is for memory power all the time keeps clock and progremed challels bule and orange are for the amp blue turn amp on when the radio is powered up
Posted on Oct 03, 2009
  • 192 Answers
SOURCE: Installed my dual xdm6825 into
I suspect you may have a blown fuse. Either the red or yellow wire from your dash board should have power (+12 DC volts or greater) all the time relative to chassis ground, which should be the black wire. Use a voltmeter to measure this. The other wire (red or yellow) should only have power (+12 DC volts or greater) when the car is turned on or the key is turned to the Aux position. Use the voltmeter to measure this also. If one of these wires doesn't measure correctly you most likely have a blown a fuse. I think the Honda Passport has 2 fuse boxes. If you open the driver's door I believe you will see a panel for one fuse box on the left side of the dashboard. I believe the other fuse box is located on the passenger side of the engine compartment. Fuse boxes sometimes have a labeled diagram on their cover or you may be able to find a diagram in your owner's manual. Look for fuses labeled radio or dash. You should be able to easily pull them out with a pair of needle nose pliers. If you look carefully at them you can usually tell if they're blown because the wire inside will look broken. Replace any burnt out fuses with new fuses rated at the same current value. The current rating of the fuse is usually written on the outside and it will generally be a number like 10, 15, or 20. Most of the time the fuses are color coded by current rating. You can buy new fuses at any auto parts store, or if you're lucky there will be a few spare fuses inside the fuse box. I hope this advice helps you out.
Posted on Jan 06, 2011
You'll need the electrical wiring diagram for that. You can also buy a universal harness where you bought your sterio with the adapter kit.
Apr 01, 2014 | 2006 Ford Five Hundred
No Sound
A couple of things here. The yellow wire isn't for an amp; the blue wire is. The yellow wire should be connected to constant power. Secondly, that truck may have a factory amp, in which case you have to connect the blue wires to the remote for that amp, or it will light up, but you will never get any sound.
Apr 03, 2012 | Dual XD-7500 CD Player
Where is the transmission dip stick on a 2007 ford five hundred?
look to the left of the airfilter ( passenger side ) of engine close to firewall of car for yellow painted stick. It is a good reach so wear some old clothing.
Feb 04, 2012 | 2006 Ford Five Hundred
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
Where does the yellow and blue cable connects to?
The yellow connects to power, if the blue wire has no stripe its an accessory and simply needs connected to power if the blue one has a white stripe its the remote turn on wire for an amp.
Sep 17, 2009 | XO Vision XOD1742BT Car DVD Player
I need the wiring diagram to install an aftermarket dual stereo in a 1996 chevy lumina
first take out the stock head unit, after the colors of the wires originally from the car is usually red black yellow orange blue or gray, blue or gray w/ stripe, and purple or green, and purple or green w/ stripe. the head unit should have a power on it for the speaker wires those are the only tricky ones. color with stripe is negative. yellow for +12 black for -12 ground and red is for ignition, turn the radio on with ignition on. purple is usually rear and blue is usual front
Jul 26, 2009 | Dual Car Audio & Video
1994 FORD EXPLOER XLT RADIO CONNECTORS HAVE BEEN CUT OFF
here is wire color diagram.
1994 Ford Explorer Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Light Blue/Red
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Pink/Light Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Mar 29, 2009 | 1994 Ford Explorer Limited
Trailer wiring
Hi Smokey,
I've got them for Six and Four wire plugs
Six wire plugs:
Horse, stock or utility trailers:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
Jun 29, 2008 | 2005 Ford Five Hundred
How to by pass the e brake wire
OK PEOPLE, I HAVE THE DUAL XDVD8181 just installed, you don't need to do any kind of code to get the video to bypass. this is what you have to do
Get a toggle switch, one that flips one way for ON, and the other way for OFF. connect parking brake wire (yellow/blue) to one end of the switch and the other end to the ground of the radio (Black wire) leave the switch in off position, turn on radio and insert dvd, when you get the blue screen, flip switch ON OFF ON wait 5 seconds and video will come on. That it fellas.
Dec 11, 2007 | Dual XDVD8181 Car Video Player
Dual XDVD210 6.2" Touchscreen DVD Receiver Logo
60 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
