Switches off after 5 mins
Switches on okay but only works for a few minuets then switches itself off
  • 151 Answers
Thermostat click? A leaky pressure switch will cause this.
Stuck fan, causes compressor to get hot and stop.
Dirty coils, ditto.
Blocked outside vents, ditto.
Weak run capacitor, will cause compressor to run hot and stop.
Low voltage from bad breaker, house wiring, outlet, cord or internal switch, will make compressor run hot.
Low on gas, the circulating gas keeps the compressor cool and will overheat quickly if it's too low.
Have a professional check, pretty much in that order even.
Posted on Apr 01, 2014
Dvd plays for 5 mins maybe 10 then stops playing switches itself off wont power up again for a few mins even do the red light comes on
This is a fault with the TOP249 switched mode power supply controller. I had the same problem and freezer spray on this chip on the power supply card started it workig quickly. Ageing of the chip has reduced the temperature sensing at which thermal shutdown cuts in. Bought a new chip off ebay for £4. Took out old one and fitted new one. Problem solved.
Apr 03, 2012 | Philips LX3700D System
This 800 sportsman will run for a few minuetes then quit! The battery is putting out plenty of volts.26.8 to be exact.How do you fix this? I bet Peg pegro does not have a fix for this.I do-Can you say...
The polaris 800's have a known issue with the thermal switches over heating, then they cut out after 10 minutes then after you wait about 5 minutes they come back on. Peg perego has a replacement kit with contains a new circuit board, thermals switches and two new 350 watt motors, I personally have replaced about 15 of them, its a pretty simple process
Feb 13, 2011 | Polaris 800 Twin Sportsman Ride on Toy
16" lcd new out of box flashing blue light on power indicator
Under a year old tv?This tv have power supply problems.Call the for warrenty repair.Or tries websites like shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 14, 2010 | LG 32LG30 32 in. LCD HDTV
Faulty programmer - oven switches itself off
Try powering everything off at the main switch, waiting a few mins, switching back on and set the clock. Make sure the oven clock is in manual mode and switch the oven on and see what happens.Let mw know.
Jan 01, 2010 | Stoves 720EF Electric Double Oven
Toshiba television will change from tv/video mode to
I would check to see if the Input button is stuck on the front panel of TV. If it is not stuck then it is probably still bad. Tactile switches are notorious for failing in this manor. The only real fix if it is not stuck down is replacing the switch.
I hope this helps,
Skyassoc
Jun 22, 2009 | Toshiba 36A43 36" TV
My less than 2 year old sony dsc-w100 keeps powering off and on
my only idea would be that the power button is glitching out...anything in the manual about this?
Jan 22, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Oven switches 'itself' off without the timer
I sorted it it is a simple solution, if you take the top of your oven you should see the problem...it will be big and black..dont spend a ortune getting it sorted i brought the part off ebay for less than a fiver.. just cant remember what it was called..very simple to fix though.  Mike
Dec 19, 2006 | Electrolux EOB6632 Electric Single Oven
System switches itself off
The HT-DB120 has an automatic shut down that should turn off after 20 min of idle mode, it seems yours is malfunctioning. try disconecting the DVD from power for a few minutes.
Jan 07, 2006 | Samsung HT-DB120 System
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
