Question about Fisher and Paykel Refrigerators
FRIDGE TEMPERATURE IS TOO HOT FAULT
FREEZER TEMPERTAURE OK BUT FRIDGE WONT REFGULATE
    Top Expert:
  • Fisher and P... Master
  • 12,962 Answers
There is a conduit from the freezer that feeds cold air into the refrigerator compartment. Make sure that the conduit is not blocked in the freezer area nor the refrigerator area. You should also have a control inside the refrigerator that regulates a sort of trap door inside the conduit. Make sure it is open or increase the opening by moving it to a higher number. Do not confuse that control with the thermostat.
Posted on Apr 01, 2014
Testimonial: "Thanks, I will look later today. Where should I look exactly for the conduit? Inside the back of the fridge - from the inside, or look at the back of the fridge from the outside? Last night I took out the wall section of the central part of the inside back but it seemed to just have polystyrene and wires and connection boards. More information- the temperature regulator for the fridge doesn't seem to have much effect. I would say the fridge section is running at about 6-8 degrees (it is working but not enough, it should be about 2-4 degrees I would guess) . The freezer works fine. Th fridge freezer is only about 4 years old, its in good condition. If you could tell me where to look for that conduit that would be great. Any other comments very welcome. Many thanks."
  • 1 more comment
  • robert ferguson
    robert ferguson Apr 01, 2014
    Another thing, about a month ago things like a lettuce started to partly freeze in the fridge. I don't know if that tells you anything about our current problem of the fridge being too hot?
  • richie46 Apr 01, 2014
    All those units are different - usually the conduit or pathway entrance is towards the back of the freezer compartment. If in doubt just contact the support people at the units web site. Meanwhile, did you locate the special control I referenced? And your refrigerator temps should be around 35 to 40 with the freezer close to zero. The temp readings you gave confused me. Maybe they were typos.
  • robert ferguson
    Thanks again. I will call the manufacturer for precise guidance and look for that special control. I was talking in degrees Celsius. In Fahrenheit the fridge must be running at 40-45 degrees then. Milk, goes off in half the time and cheese is much softer than usual. Cheers.
SOURCE: Samsung RS21w USA style frige freezer panel problem
If the fridge has been making more noise than usual, like the sound of a plastic fan grating against something then the fan has probably seized up with ice. This will cause the fridge temperature to rise. It is located at the back of the fridge behind a plastic panel at the bottom where the water cooler pipe and bottle are. You need to partially remove this panel just enough to be able to aim a hairdryer down the back of it to defrost the fan.
Posted on Sep 20, 2007
Krazytech
  • 725 Answers
SOURCE: My LG GRL207QVJA fridge is
I would check your owners manual but most LG only have a 12 month warranty .
check your Express or Fast Freezing Function is not turn on.
then you most like have a Thermistor/ control problem.
let me know
Posted on Apr 05, 2008
huuum
  • 750 Answers
SOURCE: Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
Posted on Oct 03, 2008
  • 3 Answers
SOURCE: Fridge Temperature wont stop blinking
I had the same prob, you need to defrost it until No MORE water drips out of the drain pipes located at the back ( there should be 2 of them one for fridge one for the frezzer, make sure the rubber thing at the top of the pipe is not closed up- if it is cut it open ) when you think its defrosted place a cup under these pipes and leave it for a few more hours, if there is ANY more water in there your not defrosted yet and it wont work--- Leave the doors open of course, mine took almost three days and i live in a hot climate.
ok once you have done that, take the cover off for the main circuit board ( top of the fridge ) on the circuit board there should be a little black button with "test" on it hold that in and turn the fridge on. it should beep at you ( wait 5 sec ) then push it again ( beeps again, wait 5 sec ) push it again, you have to do it about 3-4 time before it stops beeping, when its stopped, just leave it, it should start up after a couple a mins.
the fridge will take much longer to get cold so be patient, if you find it flashing again push that test button, i just played round with mine and it came right, good luck, because the only other way round the prob is to turn it off at the wall and turn it back on.
Posted on Jan 04, 2009
peyton32034
  • 410 Answers
SOURCE: Kenmore 5126101 middle separator b/t fridge/freezer extremely hot
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Posted on Mar 11, 2009
DEFY C305 combi top fridge bottom freezer FAULT:freezer operates ok, but fridge is running hot.
do you mean that your fridge is not cooling and freezer just freezes up ?
Nov 06, 2017 | Refrigerators
How do I fix a hot point fridge freezer FFUXL 4DK displaying error code 7?
Hotpoint Refrigerator Error Code E7 = Environmental temperature sensor fault
There may be a number of things affecting the temperature in your refrigerator if you see this error code displayed
Jul 22, 2016 | Refrigerators
Refrigerator side is not cooling enough. Temperature is only in low 50's. Freezer side seems to be okay.
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try completely defrosting the FF as despite common belief these units are not totally frost free.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Dec 28, 2009 | Refrigerators
Fridge wires cut
The answer could well be Yes. Ideally you should reoplace the harness anyway. The fridge controls and air valve shutter (see below) will also be wired via the harness.
Nov 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
My Whirlpool side-by-side model-ED20ZKXBW00 MFG date is 9-94. Freezer portion works great and refrigerator part is now barely cool so I have spoiled food. What could be causing this?
Nov 10, 2009 | Whirlpool 19.8 cu. ft. Side-by-Side...
My Samsun RS2534ww side by side refridgerator will not maintain temperature on the fridge side. It consistantly warms up to between 50 and 60 degrees despite resetting the thermostat.
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try defrosting the FF as despite common belief these units are not totally frost free.
Nov 06, 2009 | Samsung RS265LABP Side by Side...
Refrigerator the freezer is cold but other side is not, when I have the freezer door open cold air blows through the vent to the other side through the vent
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the tope of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working Ok then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Also worth checking the return air path from the fridge and making sure it is not blocked or frozen up. Also check the freezer compartment and cooling panel at the rear (behind the cover plates) and the fan for icing / blockage up as it sounds like there is a mini vacuum being created when the freezer door is closed or you have too much in the frezer so it presses on the back plate and stops the mini fan circulating air to the fridge.
Oct 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge warm, freezer working, pump working. where
Either the thermostate is defective or refrigerent blocked or leaked or the relay is not functioning properly. Only on inspection of the above parts could pronounce the right remedy.
Jul 06, 2009 | Refrigerators
ARISTON FRIDGE FREEZER MBA 3842C PROBLEM
It should work the same as before. Does the compressor get really hot after running a while? If so it could be low on charge, or there could be a restriction inside the refrigeration system. Either way a professional would have to look at it.
Jan 07, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezer side wont freeze
If the Freezer and the Fridge are not cooling enough then check that the condenser is not iced up and that the fan is running correctly. These are located behind a panel in the lower half of the freezer at the rear and can be accessed from inside the freezer compartment.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting from the condenser has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Nov 14, 2007 | Samsung Refrigerators
Refrigerators Logo
75 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
