Question about HP LP2065 Monitor
Lp2065 no signal
    Problem Solver:
  • 17 Answers
If screen black but green light on then is inverter was bad.
if screen black n green light off or amber then check then monitor defective.
Try with different monitor and result the same problem, either the monitor or the video connection.
Posted on Apr 01, 2014
Monitor hp lp2065
try this link:
http://h20565.www2.hp.com/portal/site/hpsc/public/psi/manuals
Results?sp4ts.oid=1815933&ac.admitted=1406140017587.876444892.492883150
Jul 11, 2014 | HP LP2065 Monitor
How to remove hinge cover hp lp2065
Please check your model number it is coming up as a 20" monitor!
May 05, 2014 | HP Computers & Internet
Screen sethi, i am using HP LP2065 LCD with my computer. Now the problem is that color setting of LCD is not good and hence no clear picture and video.Please suggest me what i should do. thanks
try in menu auto adjustment and factory reset......
you can also play with frequency a little and color setup , clock and clock phase in Image control menu, play with it and you will see result... then save it...
Mar 27, 2014 | HP LP2065 Monitor
HP LP2065 MONITOR goes to sleep
Hi There The Monitor setting you set through the computer, may you select the sleep mode or hibernate. Chang the mode and fix the problem.
Thanks http://pacificbits.ucoz.com/
May 08, 2012 | HP Pavilion F1503 15" LCD Flat Panel...
Laptop hdmi to dvi monitor
Yes that will work fine
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Dec 28, 2011 | HP LP2065 Monitor
I have an HP LP2065 monitor that I am trying to hook up to a laptop. When the monitor is hooked up it will flash the image on the screen and then go out. When you push the input button on the front of...
The monitor is faulty, this is confirmed when you connected to several laptops.
The fault could be a faulty inverter board which supplies high voltage to the CCFL lamp for the back lighting. Have a close look at the monitor at a sharp angle, if you see a faint Windows image then it is definitely a back light fault.
For parts, check out these WEB sites.
LCD screens and Inverters
www.lcdparts.net http://www.yallstore.com http://www.shope2.com/ http://www.invertercentral.com/qrySearch.asp?Adword=1500&search=1500&Campaign=Google-Models-NA&gclid=CO3lg7HJlKMCFQcbewodZB2qoQ http://www.nylaptopparts.com/ http://www.ccflwarehouse.com/
Mar 05, 2011 | HP LP2065 Monitor
I have a HP LP2065 monitor, and it is currently displaying lines (red, blue and green) vertically on the screen, how do I resolve this problem?
Hello
OK, firstly, this problem can be due to a couple of factors. I will explain it in as much detail as possible.
Internal cracked LCD:
This is the most probable cause for these lines on the screen. Unfortunately this is not something which can be fixed without replacing the whole screen.
Damaged DVI cable:
A faulty DVI connection between the computer and the LCD screen will also cause this symptoms.
Faulty Graphics Adapter:
Lastly, this can be due to a faulty graphics adapter. If you use the on-board adapter, i would suggest that you first test the graphics adapter with another screen. Also, take out the graphics adapter and place it back in, just to make sure that there is not bad connection.
With all of the above explained, i will suggest that you start by testing the system with another screen. If the problem persists, check the connection with another cable.
If all else fails, have a look at the graphics adapter you are using.
Feel free to let me know if you need any further assistance.
Kind regards
Andrea
Nov 12, 2010 | HP LP2065 Monitor
I can't get my external monitor HP LP2065 to work with my laptop Presario R3000
You need to enter your bios at pos, look for the video settings, the setting should have three options,onboard, vga or both you will need to either choose vga or both.
Jan 29, 2010 | Compaq Presario R3000 Notebook
HP LP2065 AS 2ND MONITOR
Make sure in the control panel under power options you change the settings so the screen doesn't go into sleep mode and make sure the display doesn't turn of. Do this by changing the times to never.
Feb 08, 2009 | HP Computers & Internet
Cracked Monitor
Hi...there,
Well sure, if you don't mind pay double the prices... My advised, give yourself a new monitor, since the holidays is coming... saved you the headached and $$$...
Oct 07, 2008 | HP LP2065 Monitor
HP LP2065 Monitor Logo
56 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
