Question about Salton Snack N Sandwich Maker Model Sa4 black
What can i grill
Not sure what to grill
We have a Tuscany Grill TGR30LP. The brackets for the warming tray have been burned out and the backing of the grill that holds up the grates needs to be replaced. Any idea where we can get those. We...
The Tuscany Gas Grill line was manufactured by Sure Heat. I'm not sure that the parts your need are replaceable, as they are considered as part of the grill's body. However, you can call their Customer Support Dept @ 800-229-5647, to see if they can help you.
Hope this helped you and thanks for choosing FixYa.
Sep 12, 2011 | Tuscany TGR30 Grill
Nothing fits as it should, I would like to find a step by step install vidio for a part number 71405 shadow billet grill by putco. thanks mb
Congratulations on your purchase of a high quality PUTCO product. Should you need any application or technical assistance feel free to call us at: 1-800-247-3974 Monday-Friday 8:00 a.m.- 5:00 p.m. (Central Standard Time) Contact your PUTCO dealer for other quality accessories. PUTCO Inc. - 216 West First Street - Story City, Iowa 50248 PLEASE READ ALL INSTRUCTIONS BEFORE INSTALLATION AND TO CHECK TO SEE THAT ALL PARTS ARE INCLUDED. Please consult your Vehicles owners manual for vehicle air flow restrictions Putco is not liable for any vehicle damage resulting from the installation of our Grille inserts (71101) 99-02 CHEVROLET SILVERADO / 00-06 TAHOE/SUBURBAN, (71107) 01-02 CHEVROLET HEAVY DUTY, (71102) 99-02 GMC SIERRA/YUKON, (71102) 01-02 GMC HEAVY DUTY, (71104) 99-03 FORD F-150 (71137) 03-06 CHEVROLET HEAVY/LIGHT DUTY, (71138) 03-06 GMC HEAVY/LIGHT DUTY, (71189) 07-UP CHEVROLET LIGHT DUTY, (71163) 07-UP CHEVROLET HEAVY DUTY, (71158) 07-UP TAHOE/SUBURBAN/AVALANCHE, (71190) 07-UP GMC SIERRA LIGHT DUTY, (71164) 07-UP GMC SIERRA HEAVY DUTY, (71159) 07-UP GMC YUKON/YUKON XL. Step 1: Remove the factory plastic hood that covers the area between the grille and radiator by removing the plastic plugs or screws that fasten it in place. Step 2: Remove the bolts and mounting plates from the bag kit. Step 3: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. Step 4: Reach between the grille and radiator and reinstall the bolts, plates and nuts onto the grille insert. Step 5: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. (71105) 99-07 FORD SUPER DUTY PICKUP AND 00-05 FORD EXCURSION, (74105) HORIZONTAL SIDE VENTS Step 1: Remove the four factory screws that hole the top of the factory grille in place. Step 2: Remove the bolts and mounting plates from the bag kit. Step 4: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. If you have purchased the side vent pieces install them at this time. NOTE: The installation bolt will go though a hole in the side vent that is closest to the center grille section. Step 5: Carefully pull the grille forward and reach between the grille and radiator, install the bolts and mounting brackets onto the grille insert and/or the flat washer and nut on the side vent pieces. Step 6: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. (71103) 94-01 DODGE RAM, (71132) 02-05 DODGE RAM, (71156) 06-08 DODGE RAM, 04-UP FORD F150 AND 08- UP FORD SUPER DUTY Step 1: Remove the bolts and mounting plates from the bag kit. Step 2: Place the SHADOW GRILLE insert over the grille making sure that it is centered on the vehicle. Step 3: Reinstall the plates and nuts onto the grille insert. (Verify that the bolts do not come into contact with the radiator) Step 4: Check to make sure the grille is properly in place and tighten the bolts just enough to hold the grille in place. DO NOT OVER TIGHTEN as this may cause the grille to crack. Note: Please adjust horizontal blades if irregular. This is the result of shipping and handling outside of Putco's contro
This is the installation instruction sheet for your grill.
Apr 16, 2011 | Ford F-250 Cars & Trucks
New natural gas grill will not start. What are we doing wrong?
Is the inline gas shut shutoff valve, that's required by code, turned ON? Are you sure you're getting any gas to the grill? Have you tried to match light one burner to test it? That's where you need to start your trouble shooting.
Also, don't go by what it said on the box it came in. Check the manufacturer's tag on the grill to make sure it is in fact, a Natural Gas Grill. If it's propane, nothing you do will get it to light. Sometimes the wrong things get in the wrong boxes.
Mar 08, 2011 | Barbeques Galore Turbo Elite 4-Burner with...
Grill won't heat up
i would make sure the valve on the tank is open all the way counter clockwise
Apr 24, 2010 | Weber Genesis Silver A Grill
My grill leaks the juices all over the counter why
You have to make sure you have the drip tray set under the lip of the grill. The edge of the grill should be near the center of the cup.
Dec 26, 2009 | George Foreman GR30 Indoor Grill
My grill is turning chicken gray. We've let it run a long time, to do a burn off but no luck. Taste isn't an issue but the turkey looked gross. I am using the cast iron plates. We just replaced the igniter...
First of all make sure you are preheating your grill to at least 500". Also make sure your burners are clean and clean your grates every now and then. Last make sure your are putting veggie or olive oil on the meat before putting it on the grates.
Dec 01, 2009 | Weber Genesis Silver B Grill
The grill is lit, but sputters and doesn't get hot. It seems like there is an obstruction in the gas line or something.
if it is propane try this make sure all knobs are turned off turn tank off disconnect from grill reconnect to grill make sure fitting is all the way on tank turn tank on and try again if this does not work your eegulator and hose need to be replaced
Aug 29, 2009 | Grilling
Low heat from weber grill
turn tank off disconnect from grill make sure all knobs are turned off including side burner reconnect tank make sure fitting is all the way on tank turn tank on and try again
Aug 15, 2009 | Weber Genesis Silver C Grill
Forgot how many coals to use for Weber 18 inch grill
as much as it takes to cover the bottom of the grill that is under the food..ex..if grill is covered with food then make sure the bottom is covered and spread out evenly. If just two types of meat make sure the bottom under them have coals not necessary to cover whole bottom..if any help please rate me and let me know..
Jul 10, 2009 | Weber One-Touch Gold 18.5 Grill
Clogged gas line new grill- our gas grill will not heat up properly it is relatively new and we bought it at home depot- help
Check a few things:
Make sure your hose is not chewed or marred.
Make sure you are turning the unit on and off correctly. Webers are different than other grills to turn on /off. Please check your manual for the instructions on how to do this.
Another thing if this is propane it might be a spider in your grill that is clogging the unit for you.
go to: weber website they will be able to help you.
Apr 13, 2008 | Weber Genesis Silver C Grill
Salton Snack N Sandwich Maker Model Sa4 black Logo
23 people viewed this question
Top Salton Kitchen Appliances - Others Experts
fixzum
Level 1 Expert
Robert Plante
Kolbrun...
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
