How did mungo man die
Mungo man die
  • 3,961 Answers
It seems all we know is that he died from natural causes. He was quite elderly for his time. His teeth were worn out, and he had advanced arthritis.
Posted on Apr 02, 2014
How old was mungo man when he dies
Old enough to die. Launch a Google search on the subject if you are still interested.
Mar 03, 2014 | Computers & Internet
How to disable / hide digital clock on the main screen of Sony Ericsson Yendo?
Wie blendet man die Uhr aus, oder kann man diese komplett deaktivieren?
May 07, 2012 | Orion Gadgets Car Charger for Sony...
Wenn mans anschaltet passiert halt dix die "an"
Write please in english , Try to change motherboard RAM
Aug 07, 2011 | ASUS A8N-SLI Deluxe Motherboard
My Yard Man push gas-powered lawn mower dies out
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Makesure the small screen is free of debris.
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jun 24, 2009 | Yard Man Garden
Display / Clock display not working
SONY MHC-EX50
Het is al een paar weken verder, maar ik ben eruit: C161 en C162 (100uF/35V) in de voeding zijn slecht.
wel 105 graden elco's gebruiken en hoger dan 35 volt, liefst 100v
et gaat dus om een VFD (Vacuum Fluorescent Display) die geen gloeispanning krijgt. Het vervangen van C161 en C162 lost het probleem helemaal op.
Radio: ST-EX100
Amp: TA-EX50
Symptome=Tuner-Display zeigt nichts an, sonst Tuner OK.
Defekt=C161 und C162 (100µF,35 V) auf der Tunerplatine ersetzen.
Wenn bei dem Sony-Tuner RDS EON ST-EX100 (z.B. zu der Anlage Sony MHC-EX5, aber auch MHC-EX 70) pünktlich eine Woche nach Ende der Garantiezeit die Beleuchtung im Display wegfällt und man deshalb leider keine Sender mehr programmieren kann, dann handelt es sich vermutlich um eine fiese Soll-Bruchstelle.
Auf der Platine des Tuners sind zwei Kondensatoren zu schwach ausgelegt und gehen zwangsweise früher oder später kaputt. Die Reparatur ist ganz einfach. Man kauft zwei neue Kondensatoren (100µF,35 V) - kosten nur ein paar Cent! - und besorgt sich einen Lötkolben. Dann schraubt man den Tuner auf, entfernt auf der Platine die Kondensatoren C161 und C162 (die sind namentlich gekennzeichnet) und ersetzt sie durch die neuen.
Nov 12, 2008 | Sony ICF-2010 AM/FM/SW Radio
Fritz!BOX fon WLAN 7170
DHCP und FritzBox gibt öfters Probleme.
Ich würde eher meine Drucker auf DHCP umstellen als den Rest der PCs und die Fritzbox.
Bei HP - Druckern kann man das via InternetExplorer ändern.
DHCP vergibt zwar die IP´s automatisch, aber nicht dauernd neu.
Erst wenn die maximale Anzahl an Geräten erreicht ist oder ein komplettes Reset gemacht wird.
In meinem Netzwerk laufen 5 Rechner und 3 Drucker, verbunden über einen SMC - Switch, alles über DHCP. Geht problemlos.
übrigens: das ist ein englischsprachiges Forum, da kann eine Frage auf Deutsch länger bis zur Beantwortung brauchen :)
Aug 18, 2008 | AVM Computers & Internet
I Have a Hitachi Ultravision projetion TV Ned help to fix it.
This sounds like the solder joints on one of the convergence output IC's have cracked loose or the IC itself is defective and quitting when it warms up. The IC needs to be either resoldered or replaced.
May 15, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
