Question about Haier HLP140E Electric Portable Dryer
Dryer won't turn on
Appears to be the on/off button wore out. I wanted to take a look... There's a panel on the front, I removed the screws, but panel still won't come out. Afraid if I try too hard to pry it off, I'll break it.
How to remove the front panel of my lg dryer
  • Hey Nicholas Coccovizzo
    Unplug the dryer's 3-prong electrical cord from the power outlet.
  • Pull the dryer away from the wall and turn to one side to access the back of the appliance.
  • Remove the screws at the top of the dryer on the back panel.
  • Push the cover of the dryer from the front toward the back to disengage it from the cabinet, then lift the front of the cover up a few inches and toward the back at an angle.
  • Remove the two screws inside the front corners that attach the cover to the control panel. this will disconnect the cover from the front control panel.
  • Unplug the control panel from the wire plugs connected to the knobs and buttons. Set aside the control panel
  • Remove the two screws that were hidden underneath the control panel. These screws hold the top of the front cabinet in place.
  • Open the dryer door in the front of the appliance and remove the screws just below the slot for the lint screen, keeping one hand braced against the front of the cabinet to prevent it from falling forward. Removing these screws will detach the front cabinet from the sides, exposing the motor, dryer drum, belts and the blower for circulating hot air
    Good Luck!
  • Jul 29, 2012 | LG Dryers
    Dryer drum won't spin
    the front control panel has 2 little screws on the 2 top corners remove them, then pry off the entire control panel (very careful ) once the panel is off remove 4 screws that hold the front to the body, then open the door and remove the 2 screws in front next to the lint filter, slowly remove the front door assembly starting from top, disconnect the door switch, then lift it off the front hooks and the door is out, then remove the front 4 screws from the front bearing and remove, so will gain access to the blower housing, good luck
    Apr 11, 2012 | LG Dryers
    Kenmore Front Load Dryer Model 97078712 Will Not Start I have a Kenmore Front Load dryer Model: 970787712 that wont start. If I hold the start button and jiggle the timer it starts. Is it correct to assume...
    There can be many reasons why your dryer will not start or turn...
    The most common causes are the belt breaking or jumping off, or the motor goingbad...
    Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
    Dryer Repair - The Dryer is not Turning
    Dryer Repair - The dryer will not start
    heatman101
    Jul 21, 2011 | Kenmore Dryers
    Inside the drum, one of the metal things is loose. It appears that it is held on with screws, so they are probably loose. Could you tell me teh easiest way to access the outside of the drum so I can...
    The top cover needs to be lifted to the rear of the dryer to access the outside of the drum and tighten the baffle screws. But before the top cove can be lifted, the front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
    Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
    Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
    The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
    Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
    Rotate the drum until the baffle screws are on top to tighten it. Reinstall the top panel and the front panel by following the removal steps in reverse order.
    May 25, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
    Our dryer has become unseated from the unit's back wall. The strap is still in place on the drum, so the drum turns. However, it scrapes the housing. Is there a trick to re-seatinng the drum?
    usually you have to pop off and swing back the top( usally spring clips in the front) pry at the front,swing top open, then remove the screws from the front panel. im suspecting it came off because the felt wore off the drum edge.
    Sep 04, 2009 | Dryers
    Hotpoint Clothes Dryer (ctd00) is tearing clothes.
    Hi, It sounds likethe front tub bearing (Glides) might be wore down. To raise the top....... there are two screws located where the door closes to the front panel that hols the top down. Remove those screws and the top should raisse up. Look down toward the front of the drum and see if the glides or felt are ok.
    Hope this helps
    Vic
    May 07, 2009 | Hotpoint Dryers
    REMOVE FRONT PANEL - ZIPPER PARTS STUCK IN DRUM GUIDE.
    I found the parts manual on line at GE Appliances.
    The replacement parts for the top indicated pictured two clips holding the front of the dryer in place.
    I tried a narrow screw driver on the clips and that released the top.
    With the top off, removing the front panel required removing two screws, lifting the drum and pulling slightly on the front panel.
    After removing the wires from the door switch, I was able to find the broken zipper, clean out the fan, remove excess lint and reassemble.
    Dec 06, 2008 | GE DBL333EBCC 5.7 cu. ft. Electric Dryer
    How to remove the back
    Dryer back does not come off, the screws removed secure parts to the inside of the case.
    put them back before anything detaches.
    the front panel comes off
    • pull wall plug
    • remove lint screen
    • remove 2 screws in housing under lint screen
    • with putty knife or other blunt blade in gap between top and front,
      depress spring catches at both corners of top panel front, tilt up top
    • remove 1screw each side 1/3 down front panel
    • remove door swicth wires
    • tilt front panel down and remove
    all internal parts are accessible
    perform repair
    examine rear of case from inside and refit anything detached by screw removal
    reassemble in reverse order
    Oct 20, 2008 | Whirlpool LER4634J Electric Dryer
    Replace belt on Whirlpool LE09508KQ1 Electricl Dryer
    remove the lint fiter and remove the two phillips screws then lift the top up
    you will find two screws on each side of the inside of the frount panel down about 4 inches , this when removed will allow you to swing the frount arround to gain access to the belt
    Apr 30, 2008 | Whirlpool LER5636P Electric Dryer
    How to remove a back panel of maytag neptune dryer?
    You have a choice for which side front door should be on this model. There are 4 screws on front door. Take all 4 screws and pull down the front panel. You will see two metal parts each side which holds top panel. Remove two screws and metal parts. Now you can push up the top panel.
    Mar 17, 2008 | Maytag Neptune MDG5500AW Gas Dryer
    Haier HLP140E Electric Portable Dryer Logo
    32 people viewed this question
    Top Haier Dryers Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Bill Long
    Are you a Haier Dryer Expert? Answer questions, earn points and help others
