Question about IBM Netfinity 3500 M20 8657 Server
Running Non-ECC Ram in a IBM Netfinity 3500 M20
Will non ecc ram work in this server?
Cheers
  • Mkcoy Mar 29, 2009
    Hey is it ok to use NON-ECC RAM in a machine that uses ECC RAM together? I am getting the NON-ECC Mode message at boot.
    Problem Solver:
  • 17 Answers
Dear NickB,
In my experience working with many servers, Non-ECC memory will not work on a machine that requires ECC memory. It is possible in some servers to disable the ECC mode in the system BIOS to allow non-ECC memory to work, but you will often end up with performence problems later on.
Hope this information helps, let me know if I can be of any further assistance.
Posted on Apr 11, 2008
Will a Samsung 256MB DDR PC2700 CL2.5 184 PIN work
No that memory is not compatible. The Precision 350 uses memory called RDRAM aka RAMBUS.
Here are the speeds and sizes that are supported.
Memory modules supported PC800-40: 64-, 128-, 256-, 512-MB, non-ECC or ECC
PC1066-32P: 128-, 256-, 512-MB, ECC and 64-, 128-
,256-,512-MB, non-ECC
Minimum memory PC800-40: 128 MB non-ECC and ECC
PC1066-32P: 128 MB non-ECC and 256 MB ECC
Maximum memory PC800-40: 2 GB non-ECC and ECC
PC1066-32P: 1.5 GB non-ECC and ECC
Sep 27, 2014 | Computers & Internet
LOUD FAN NOISE IN ml350g6 using non heatsink ddr3 ram
Run with case open. Check for bad fan / warning light.
Jul 23, 2012 | HP ML350 G6 (517430005) Server
CAN I REPLACE THE MEMORY WITH A 4 GIG STICK
this will depend on your motherboard
whether you can install a 4 gb module of ram
you will need to select your motherboard from a dropdown list
also on the left will be types of ram ddr2 ddr3...... you will need to select which type you have
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
NON-ECC/Non-parity - Most desktop and laptop computers take NON-ECC or Non-parity memory.
ECC/Parity - ECC or parity modules look for errors in data and are most often found in servers and other mission-critical applications used by large networks and businesses.
Unbuffered - Most PCs and workstations use unbuffered memory which is faster than registered memory.
hope this helps you
Oct 12, 2011 | Computers & Internet
Got an AsRock P4i65G mobo and bought 2 gig RAM for it. However, I have bought ECC memory by mistake instead of Non-ECC. PC wont boot with the new RAM. Is there any way I can get this to work such as with...
Hi, you can download a manual here:
http://www.asrock.com/mb/overview.asp?model=p4i65g
Your mainboard DOES NOT SUPPORT ECC RAM.
This ram type is ONLY intended for servers
or mainboards that are compatible for that ram type.
This is what your mainboard supports:
Dual Channel DDR memory technology
- 2 x DDR DIMM slots
- Supports DDR400/333/266 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
Use only the asrock site when upgrading the bios.
And a bios upgrade does not supports the ecc ram anyway.
Hope this will help you.
Aug 20, 2011 | Asrock P4i65G Motherboard
Would this particular RAM work with my Dell Dimension 2400? http://cgi.ebay.com/KINGSTON-1GB-DDR-PC2700-ECC-REG-KVR333X72RC25-1G-RAM-/380226148054?pt=LH_DefaultDomain_0&hash=item58873e96d6
According to the Dell specification found here:
http://support.euro.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm#1105481
your PC does not support registered ECC RAM.
Most desktop PCs use unbuffered RAM. Registered ECC (Error Checking and Correcting) is a special type of RAM mostly used in servers.
Unbuffered RAM is faster than ECC RAM and is usually cheaper.
To find RAM that is compatible with your PC try the memory configuration tool at www.crucial.com
Please rate my answer is this was helpful.
Many thanks,
Chris
Mar 05, 2011 | Dell Dimension 2400 PC Desktop
Can the bios support using ecc memory to run as non ecc?
hi simple answer no, this feature is designed for that specific reason, if you have ECC ram you have to enable the ECC support in the bios, ECC ram has a different timing and ways of using the data flow, it is much slower than non ECC ram and uses more voltage, that's why most people prefer normal SD ram or DDR ram, you can however use these in *********** board if you turn the ECC support off, so long as your board will take the specific ram....hope this helps
Mar 15, 2010 | Compaq Computers & Internet
Can we use non ecc ram in this server. My P100 ECC ram is giving problem. that's why i want to know non ecc ram of P100 or P133 supports this server
Thanks. We have replaced our PC100/REG 64MB/ECC with PC133/ 128MB NON ECC ram. Now my server is working fine for more than 16 hours. We hope we have solved our problem. We have tried with PC100/ 256 MB non ECC ram in this server. It is not working. What i want to know is how much RAM this server supports. there are 2 memory banks are there. In E-Bay , USA this PC100/REG 128MB/ECC is available. Make "MASTER". Can i try that. Pl give suggestion.
Jan 04, 2010 | Acer Altos 330 Server
Tried to upgrade RAM now computer won't boot up
check ther is 4 ram bank and if then fix ram after left 1 bank.then check .
there is also check frequency same of both ram.
Jan 10, 2009 | Computers & Internet
Keeps on rebooting
The processor fan should have failed. check it out.
Feb 17, 2008 | IBM Netfinity 3500 M20 8657 Server
IBM Netfinity 3500 M20 8657 Server Logo
498 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
