Question about HP EliteBook 2530p Notebook
How to turn on brightness buttons of hp
How to increase or decrease brightness of screen through touch buttons
  • 33 Answers
Keep holding the FN button, and along with that click brightness button
Posted on Apr 01, 2014
4 Suggested Answers
Ranvens
  • 61 Answers
SOURCE: problem with laptop compaq 6720
this function usually requires software to be installed for it to work.... Certainly is in the case of toshiba laptops.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3442833&taskId=135&prodTypeId=321957&prodSeriesId=3442832&lang=en&cc=us&submit=Go%20%C2%BB
Posted on Jan 07, 2009
  • 166 Answers
SOURCE: clicking audio problem with quick touch HP dv5-1160us
Take off the plastic strip above the keyboard, as if to replace keyboard. You will see 2 small wires running from the volume control strip to the left. Make sure they are properly plugged in, and that neither is touching the foil used to ground the laptop. Replace the strip. I have had this on 2 HP laptops, and in both instances it was making contact.
Posted on Sep 03, 2009
Geekman
  • 32281 Answers
SOURCE: HP compaq 6710b - Hi I can't adjust the brigthness
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Posted on Oct 30, 2009
How do I turn down brightness on my hp Windows 7 computer?
Below are instructions to adjust brightness on HP laptop
    • Press the "Fn" key with the computer turned on and hold the key.
    • Press the "F7" or "F8" key on some HP laptops, which are printed with a small sun icon on the key. The sun icon is filled on the function key for dimming the laptop. The other key is printed with a hollow sun icon for brightening the screen.
    • Press the "Fn" and left arrow keys together on some HP laptops to turn down the brightness. The "Fn" and right arrow key will increase brightness. Press and release the right arrow key repeatedly, while holding down "Fn," to decrease the screen brightness slowly, or hold the keys to darken the screen as low as the setting will go.
  1. For HP Monitors
    • Press and hold the down arrow key on the front panel of the monitor below the screen to turn down the brightness on the external monitor to the lowest setting.
    • Repeatedly press the down arrow button to dim the monitor gradually.
    • Press the up arrow key on the monitor to increase brightness.
Regards,
Rahul
Jul 15, 2013 | Computers & Internet
Brighten laptop screen
Down button right hand side there is a battery sign with charging click on that.
Click on ADJUST SCREEN BRIGHTNESS
Down you see SCREEN BRIGHTNESS (written now you can increase and decrease the brightness)
Or
Go to control panel
window vista:- CLick on left hand side CLASSIC VIEW
Window 7:- in address bar click and sellect ALL CONTROL PANEL ITEMS
Now click on POWER OPTIONS
May 11, 2013 | HP Pavilion Computers & Internet
How do you turn up the volume on coby 10" ultra portable netbook pc
Fn + Esc Put your computer in sleep mode.
Fn + F1 Enable/disable the built-in wireless internet.
Fn + F3 Mute.
Fn + F4 Enable/disable the touch pad.
Fn + F5 Shift to other connected display devices, i.e. another monitor.
Fn + F6 Decrease display brightness.
Fn + F7 Increase display brightness.
Fn + F8 Decrease computer volume.
Fn + F9 Increase computer volume.
Fn + F10 Turn on/off the LCD screen.
Fn + Ins/NumLk Enable/disable the Numeric keypad
Dec 02, 2012 | Computers & Internet
Monitor to bright
Decreasing Screen Brightness (FN+F9)
Press and hold the FN key, then hit the F9 key to decrease screen brightness.
Increasing Screen Brightness (FN+F10)
Press and hold the FN key, then hit the F10 key to increase screen brightness.
Mar 21, 2012 | HP Compaq nc6230 Notebook
Loaded windows 7 ultimate and also the drivers on Hp Laptop G62. But the Brightness control buttons on Lap top are not working.Currently brightness seems to be 100%. pls suggest how to control or reduce...
try this
press f3 to increase the brightness, f2 to decrease
or,
hold fn key and press f3 to increase the brightness
fn+f2 to decrease
let me know if it works
Apr 19, 2011 | HP Computers & Internet
SCreen resolution to bright
You need to decrease the brightness of your screen by using the buttons on you LG monitor. Push the menu button and then navigate to and select brightness. Now use the left or right arrows to either increase or decrease the brightness.
All the best!
damnor01
Nov 06, 2010 | LG Monitor
How can I increase the screen brightness in sony reader touch
The Sony Reader Touch PRS 600 doesn't provide any mechanism to increase screen brightness, only to increase or decrease font size. There are many cases with built in lights you can purchase for it, though.
Jun 24, 2010 | Sony Reader Touch PRS-600
How do i make my screen brighter on presario v2000
Decrease Brightness (fn+f7) The fn+f7 hotkey decreases the brightness of the notebook screen. The longer you hold down the fn+f7 hotkey, the more the screen dims. Decreasing screen brightness conserves power. » To increase screen brightness, press the fn+f8 hotkey.
Increase Brightness (fn+f8) The fn+f8 hotkey increases the brightness of the notebook screen. The longer you hold down the fn+f8 hotkey, the more the screen brightens. » To decrease screen brightness, press the fn+f7 hotkey.
Nov 03, 2009 | HP Compaq Presario V2000 Notebook
The brightness adjustment bar appears on the screen all the time
Press the menu button on monitor select the brightness press the menuside button increases or decreases.after select exit oress the exit button on monitor.
Jul 13, 2009 | Compaq CV 7500 17" CRT Monitor
More Brightness
on the front of the monitor there are key buttons naming menu, ok button and left & right arrow marks buttons first press menu button then go to brightness then by using arrow keys you can increase & decrease the brightness once you are finished decreasing r increasing press ok button.& there are many other settings you can change like contrast etc....
Feb 07, 2008 | LG Flatron 775FT 17" CRT Monitor
HP EliteBook 2530p Notebook Logo
141 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
