Question about HP LaserJet 2420 Printer
How much voltage it takes a fuser to heat
How much voltage a hp 1020 printer takes to heat fuser assembly? Can you please anyone tell me technically.
    Sergeant:
    Champion:
  • HP Expert
  • 345 Answers
120 volts AC in the US. Wattage is between 700- 1200.
Posted on May 20, 2014
SOURCE: Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Posted on Mar 28, 2008
SOURCE: HP 2430tn lj printer with 13.20 jam inside top cover error
This question is directed at Steve from the post above. I need to order the sensor you mentioned. Is that sensor located exclusively on the power supply (Part number RM1-1505-000CN)? Will I need to order the whole power supply, or can I order the sensor separately? It does not show it very clearly in the service and maintenance manual. Thanks for the help!
-Shawn
Posted on Nov 14, 2008
acdr
  • 1913 Answers
SOURCE: HP laserjet 1020 driver
freee downoad from here
http://www.driverstock.com/HP-LaserJet-1020-driver-download/10-26-2954/index.html
Posted on Feb 03, 2009
niquose
  • 198 Answers
SOURCE: how i print a watermark picture in hp 1020 printer
To change the default settings for all future print jobs in Windows XP
1. In the Windows task bar, click Start, select Settings, and click Printers and Faxes.
2. Right-click the HP LaserJet 1020 printer icon.
3. Click Properties, or click Printing Preferences.
4. Change the settings, and click OK.
5. On the Effects tab, select the watermark you want to use.
NOTE Not all printer features are available from all drivers or operating systems. See the printer
properties (driver) online Help for information about availability of features for that driver.
Posted on Jun 23, 2009
SOURCE: HP LaserJet 1020 Printer Installation Software
click here
Then select operating sytem and download driver and hp solution centre software for your printer.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 18, 2009
How to change teflon hp laser printer 1020
Pl observe the snap shot for the Teflon loading Technic & browse the link for how to fix the fuser..10_1_2011_4_07_04_pm.gifLink: http://v.youku.com/v_show/id_XODYxNzgxNDA=.html
Sep 30, 2011 | HP LaserJet 1020 Printer
We have an HP 3550 color printer that has a 50.1 Fuser Error. Will replacement of the fuser correct the problem?
The most common reason that causes a fuser error is its failure to reach operating temperature. If the fuser area can be accessed, check to see if there is noticeable heat present. If not, the fuser may not be getting the required voltage to bring it to temperature and you may need technical help to determine the exact cause of the error.
Aug 24, 2010 | HP Color Laserjet 3550 Printer
HP LaserJet 1020 Printer fuser
Hello kenterprise1 !
This is the part number for the Fuser on this LaserJet 1020 :
RM1-2086-000CN Fusing assembly (For 110V to 127VAC (+/- 10%) operation) - Bonds the toner to the paper with heat - Mounts in the upper rear of the printer
Jun 21, 2010 | HP LaserJet 1020 Printer
I have HP Laser Jet 1020 When I print letters
Most cases on that machine it's the transfer roller that does that at 75mm, but could also be drum cartridge or fuser. Use a flashlight and inspect the fuser, shouldn't be toner or image on fuser rollers, If you unplug the machine when the print is in the middle, you can tell if it's before or after the fuser, and after the drum.
Nov 24, 2009 | HP LaserJet 1020 Printer
Plastic metal shavings inside printer
I had a similar problem on an hp-3052. I was getting pieces of plastic that were grey and yellow stuck to my pages and all inside the printer then papaer stared jamming. The problem was the fuser sleve which can be picked up on ebay fairly cheap. The bigger problem is installing the sleve over the fuser. I tried the repair my self and broke the fuser assembly. It's a cheap part but a pro should do the install this is definately not a diy fix.
Sep 26, 2009 | HP LaserJet 1020 Printer
My hp laser printer 1020 is printing extra lines
This can be caused by a few things and depends on type of mark.
The first thing to do is try another toner cartridge. If the problem persists it is usually caused by a defective fuser assembly. Either the fixing film in the fuser assembly is worn or torn, or there is toner excess on the film. The fuser is situated just below where there paper exits.
Aug 06, 2009 | HP LaserJet 1020 Printer
50.1 fuser error
Fuser error is the high voltage drum. Normally there is a blown fuse somewhere attached to it that gives the error other you could have a defective fuser unit. Dont attemt yourself it works with very high voltages +- 600V
May 12, 2009 | HP LaserJet 8150n Printer
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00602236&cc=us&lc=en&dlc=en&product=439320&dlc=en&lang=en
Dec 06, 2007 | HP LaserJet 1020 Printer
Hp laserjet 1020
update the HP driver fron internet.
May 04, 2007 | HP LaserJet 1020 Printer
Laserjet 6L
The way-off ohms reading would suggest the fuser element is bad. If the fuser is not heating, a sensor will tell the logic circuitry so, and thus your error, and no-print condition. I'm reasonably certain the self check at power on checks for fuser heating. Guessing here, but a heating check is likely done prior to a printjob being completed too. If you can check the voltage at the fuser during the self check or as it readys to print, this would tell you if full voltage is applied. The 12 volts you are seeing probably is a standby voltage. The HP laserjets I've worked with all have higher heating voltages than this. You might be able to find some more accurate info elsewhere on the 'net.
Apr 23, 2007 | HP LaserJet 6L Printer
HP LaserJet 2420 Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
