Question about Ardisam Earthquake - CS4518 - Chainsaw
Cs4518 earthquake clutch tool
I want to remove the clutch to get at the oil pump. But the **** thing has a three sprocket dohickey that I cant figure out. Local dealer wont sell me the tool. Any suggestions?
  • John Williams
    John Williams Apr 01, 2014
    I would.... if I knew what it looked like.....
    Problem Solver:
  • 13 Answers
I usually try to make my own tools for these situations - do you have any skills/abilities for that? Otherwise try another dealer, negotiate a loan of the tool maybe. Many special tools eventually make it into the aftermarket, possibly they are being sold online somewhere.
Posted on Apr 01, 2014
  • John Williams
  • John Williams
    We are also limited in Australia by quite onerous distribution setups. EG a part for my Yamaha outboard costs 3 times as much as the USA. So there are no other suppliers, just the one in the entire country, Not in the dealers interests to sell a tool he can charge me to use...
CS4518 chainsaw viper engine
Check the compression. It should be 100 psi or above.
Aug 27, 2013 | Earthquake CS4518 - 18" 45cc Consumer Gas...
McCullock 7-38 chain lube not working
The oil pump is behind the sprocket and clutch, if you have cleaned out the delivery hole in the bar and still no oil, then you will need to check the pump itself, remove the e clip and washer securing the sprocket, remove the sprocket, the clutch is removed with a pin spanner, there is a genuine tool for this 530031112, you can then jar the clutch off against the compression of the saw ( left hand thread ) there is now just two screws securing the oil pump, the pump has a nylon gear, with a steel gear pressed onto the crank, check the condition of the nylon gear, remove the silver bar pad cover tou can then pull out the pick up/delivery tube, on the end is a filter.
Mar 05, 2013 | Garden
Earthquake cs4518 wont start
pull the spark plug out and check it for wetness. you may have flooded it unknowingly so it won't start. if it is wet, blow it off or let it air dry. turn the saw so the spark plug hole is facing down and pull the rope a few times to clear all the excess fuel out of the cylinder. put the plug back in and with NO choke try starting it again. if the plug isn't wet let me know and we will see if we can figure something else out
Feb 16, 2013 | Earthquake Chain Saw - CS4518
Earthquake chainsaw cs4518 wont start
Sounds like the Chain Brake? You will need to replace this or disengage the brake. Take the cover off and see if you can start it.
Feb 10, 2013 | Earthquake Chain Saw - CS4518
How do I change the oiler line that's on the
Too replace the pipe you need to remove the sprocket, clutch and oil pump, start by removing the e clip and washer retaining the sprocket ( dont lose the bearing ) there is a special tool to remove the clutch, or if you do not have this, insert a sturdy flat screw driver into on of the cut a ways in the clutch spider, and strike with a hammer you will have to strike numerous times to jar the clutch off ( left hand thread ) once off, remove the cross head screw holding the steele bar protection plate and remove, remove the two 4mm allen screws securing the oil pump, knock the chain brake on, this will allow enough movment of the brake band to remove the brass delivery tube from the pump, the pump will now come away, the pick up pipe will now just pull out of the tank.
May 12, 2012 | Husqvarna Garden
Not pumping oil to chain, bought a new pump and oil pickup but I`m not sure where the oil pump is located and what I have to disassemble to get to it.
Most oil pumps are situated behind the clutch and sprocket, these will need to be removed before you can acsess the old pump, if it has an inboard sprocket you will need to remove the clutch first, these are a left hand thread and just spun onto the crankshaft, they need to be jarred off against the compression of the saw, you may need a special tool if there is no nut on the outside of the clutch, this tool fits most Poulon clutches 530035560, once removed it is a fairly straight forward job to change the pump.
Sep 13, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Oiler does not flow well have cleaned chain and oiler holes & bar slot? what next? ian
The next step is to check the pick up filter, and the oil pump itself, to do this you will need to remove the clutch and sprocket as the pump is behind here, unfortunatley you need a special tool to remove the clutch, part no. 530031112, this tool fits into the clutch centre, it has a 19mm nut on the end so as to jar the clutch off against compression ( left hand thread ) once removed you can get at the pump, once the pump is removed you can check the plastic worm gear for wear, you can also pull the pick up pipe out and clean the filter. there is a trick that some times works, drain the oil tank, now fill it with a suitable cleaning fluid, give it a good shake, rinse it out two or three times, this will help to remove any dirt in the oil filter.
Mar 20, 2011 | Poulan Garden
How to replace the timing chain of nissan cefiro v6 2000? its 97 model.
Engine - Timing Chain/Front Cover Revised Procedure
Classification:
EM98-009
Reference:
NTB98-107
Date:
January 15, 1999
GA16DE TIMING CHAIN/FRONT COVER
REVISED SERVICE PROCEDURE
APPLIED ENGINE:
GA16DE
APPLIED MODELS:
1991-94 Sentra (B13) w/GA16DE
1991-93 NX1600 (B13)
1995-99 Sentra (B14) w/GA16DE
1995-98 200SX (B14) w/GA16DE
SERVICE INFORMATION
A revised service procedure for the engine front cover/timing chain has been adopted for the GA16DE. It is no longer recommended to remove the
cylinder head when removing the timing chain/front cover(s). Utilize the following steps when servicing the front cover, timing chain, guides or
tensioner(s)
PARTS INFORMATION
CLAIMS INFORMATION
Please reference the "Revision C" pages of the Nissan "1992-1999 Warranty Flat Rate Information Manual", Section "AG", Op Codes AG12AA,
AG14AA, AG142A, AG143A, AG144A and AG24AA. Also reference Section "CA", Op Codes CA20AA and CA22AA. You will note that the
descriptions and flat rate times applicable to the B13 and B14 vehicles (with GA16DE engines) for these Op Codes have been revised to reflect this
new procedure.
Caution
^ After removing the timing chain, do not turn the crankshaft and camshaft separately or the valves will strike the piston heads.
^ When installing chain tensioners or other sliding parts, lubricate contacting surfaces with new engine oil.
^ Apply new engine oil to bolt threads and seat surfaces when installing the camshaft sprockets and the crankshaft pulley.
^ Do not spill engine coolant on the drive belts.
^ Please refer to the Service Manual for the correct tightening torque.
Removal
1. Set # 1 piston at TDC on its compression stroke.
2. Remove the spark plug wires.
1995 Nissan-Datsun 200SX L4-1597cc 1.6L DOHC MFI (GA16DE) Page 2
3. Remove the rocker cover (see Figure 1).
4. Remove the coolant reservoir tank with bracket and reposition it for clearance.
5. Support the engine with a suitable jack.
6. Remove cylinder head front mounting bracket.
7. Remove engine front mounting, then the engine front mounting bracket.
8. Remove cylinder head front cover.
9. Remove the upper chain tensioner (see Figure 2).
1995 Nissan-Datsun 200SX L4-1597cc 1.6L DOHC MFI (GA16DE) Page 3
10. Wipe off the links of the upper timing chain next to the timing marks on the sprockets. Put paint marks on the timing chain, matching them with
the timing marks on the cam sprockets and idler sprocket (see Figure 3)
11. Remove the four (4) front cover to cylinder head bolts.
12. Remove side and lower engine compartment splash covers.
13. Remove the accessory drive belts.
14. Remove the crankshaft pulley.
15. Drain coolant by removing the cylinder block drain plug and opening the radiator drain **** (Refer to MA section of the Service Manual).
16. Drain engine oil.
17. Remove intake manifold support of engine front side.
18. Remove power steering pump, pump bracket and tension rod. Position pump aside for clearance.
19. Remove the thermostat housing (See Figure 4).
1995 Nissan-Datsun 200SX L4-1597cc 1.6L DOHC MFI (GA16DE) Page 4
20. Remove the lower chain tensioner (see Figure 5).
21. Remove the front exhaust tube. Refer to the "FE" section (Exhaust System) of the Service Manual.
22. Remove the front and rear engine gussets (if equipped) on either side of the oil pan.
NOTE:
On A/T models, remove the rear plate cover.
23. Remove the oil pan (see Figure 6).
a. Insert the Tool between the cylinder block and oil pan.
CAUTION:
Be careful not to damage the aluminum mating face. Do not insert a screwdriver, or the oil pan flange will become damaged.
b. Slide the Tool by tapping it on the side of the Tool with a hammer.
24. Remove the A/C compressor and position it aside for clearance.
25. Remove the A/C and alternator bracket with the alternator.
26. Remove the oil pump drive spacer.
CAUTION:
Be careful not to scratch the drive spacer when removing it.
27. Remove the front cover bolts and front cover.
1995 Nissan-Datsun 200SX L4-1597cc 1.6L DOHC MFI (GA16DE) Page 5
CAUTION:
One bolt is located on the water pump (see Figure 7).
*1: Located on engine front mounting bracket.
*2: Located on the water pump.
*3: Located on the power steering oil pump adjusting bar.
CAUTION:
Be careful not to tear or damage the cylinder head gasket.
28. Remove the cylinder block to front cover alignment dowels.
CAUTION:
Do not hit the dowels or the cylinder block will crack.
29. Wipe off the links of the lower timing chain next to the timing marks on the sprockets. Put paint marks on the timing chain, matching them with
the timing marks on the idler sprocket and crankshaft sprocket (see Figure 8).
Installation
1. Install the crankshaft sprocket, making sure the mating marks face the front of the engine.
2. Install the idler sprocket and lower timing chain using the mating marks and the paint marks made during the removal process.
CAUTION:
1995 Nissan-Datsun 200SX L4-1597cc 1.6L DOHC MFI (GA16DE) Page 6
3. Install the lower chain guides.
4. Front cover installation:
a. Using a scraper or other suitable tool remove all traces of liquid gasket from the cylinder block and front cover mating surfaces.
b. Install new crankshaft seal in front cover.
c. Install new oil passage O-rings and apply a continuous bead of RTV sealant to the front cover (see Figure 1).
NOTE:
Use Genuine Nissan RTV silicone sealant P/N 999MP-A7007, Three Bond P/N TB1207D or equivalent.
d. Install the front cover to the engine.
CAUTION:
Be careful not to tear or damage the cylinder head gasket or oil seal.
5. Align oil pump drive spacer with the oil pump, and install.
6. Install the oil strainer.
7. Install oil pan, referring to "Installation" in the "OIL PAN" section of the Service Manual.
8. Install upper timing chain and sprockets, using the painted reference marks made during removal.
9. Install upper chain tensioner.
1995 Nissan-Datsun 200SX L4-1597cc 1.6L DOHC MFI (GA16DE) Page 7
a. Before installing the chain tensioner, insert a suitable pin into the pin hole of the chain tensioner (see Figure 2) to hold the tensioner in.
b. Once the tensioner is installed, remove the pin.
10. Install the lower chain tensioner (See Figure 3).
NOTE:
Make sure the gasket is facing the proper direction before installing the tensioner.
CAUTION:
Now rotate the crankshaft by hand. Check that no binding or interference problems occur when the engine is rotated.
11. Install the thermostat housing.
a. Use a scraper to remove all traces of liquid gasket from the mating surfaces of the engine front cover and the thermostat housing.
1995 Nissan-Datsun 200SX L4-1597cc 1.6L DOHC MFI (GA16DE) Page 8
b. Apply a continuous bead of RTV sealant to the housing as shown in Figure 4.
NOTE:
12. Install camshaft sprocket cover:
a. Use a scraper to remove all traces of liquid gasket from the mating surfaces of the cylinder head and camshaft sprocket cover.
b. Apply a continuous bead of RTV sealant to the cover as shown in Figure 5.
NOTE:
d. Install camshaft sprocket cover.
1995 Nissan-Datsun 200SX L4-1597cc 1.6L DOHC MFI (GA16DE) Page 9
13. Apply RTV sealant to rocker cover gasket (see Figure 6a) and install rocker cover, tightening the bolts as shown in Figure 6b.
14. Install the following parts:
a. Crankshaft pulley.
b. A/C compressor and alternator bracket with alternator.
c. A/C compressor.
d. Power steering oil pump and tension rod.
15. Install front and rear engine gussets (if equipped), and rear cover plate (A/T models).
16. Install front exhaust tube.
17. Install upper right engine bracket and mount.
18. Install coolant reservoir tank.
19. Install alternator, power steering and A/C compressor drive belts.
20. Install engine compartment splash guards.
21. Install vacuum hoses, electrical harnesses and connectors.
22. Install spark plug wires.
23. Refill with coolant. Refer to the "MA" section ("Changing engine coolant, Engine Maintenance") of the Service Manual.
24. Refill with engine oil. Refer to the "MA" section ("Changing engine oil, Engine Maintenance") of the Service Manual.
Jan 15, 2011 | 1997 Nissan 200SX
Ardisam Earthquake - CS4518 - Chainsaw Logo
54 people viewed this question
Top Ardisam Garden Experts
Jay Finke
Jay Finke
lnbn1975
Wade Mobley
Wade Mobley
Are you an Ardisam Garden Expert? Answer questions, earn points and help others
