Question about ourWorld.com ourWorld
Gmail e-mail I have my gmail account on the short cut menu and usually just type in 'g' and the computer goes straight to me e-mail. Yesterday I got Error 404 ... "can't do anything" up on the screen and had to ferret through all the options associated to anything e-mail or google and still was unable to get my e-mail. Please help!
How to configure Gmail in Outlook?
Who else not expect to configure Gmail in Outlook?
Outlook can be configured to work with Gmail
Using a cloud-based e-mail service is a great way to get started with cloud computing. That's why the use of Gmail instead of server-based Microsoft Exchange is recommended to you. Yes, the Outlook interface can be configured to perform with Gmail. Enabling the IMAP protocol is the key. In this context, you may ask how to configure Gmail in Outlook - the configuration procedure. Well, it is a simple process which will take a small slot of time.
Open Gmail
Log into your email account
Go to the top right portion and open the Settings window
It will bring the forwarding option in front of you
We suggest you to press it
Hence, you will get the opportunity to enable IMAP
Save the changes now and move towards the next stage
Open Outlook
Choose File
Go to the Account Settings section
You will find the a button as New which is needed to be clicked
Hit Next now
Now you need to choose the Email Account menu
Also, choose Manual Setup (Additional Server Types is also preferable)
Here, in this stage, you will have to choose the account type
Once you select it, you are supposed to enter the given information
1. Your name: Choose a display name
2. Account type: IMAP
3. Incoming mail server: imap.Gmail.com
4. Email address: Enter your complete Gmail address
5. Account type: SMTP
6. Outgoing mail server: smtp.Gmail.com
7. User name: Enter your complete Gmail address
8. Password: Enter your Gmail password
Save the inputs and click on More Settings
Move into the Outgoing Server section
My Outgoing Server may prompt you for an authentication
At last, you are suggested to Use Same Settings as My Incoming Mail Server
visit- How to get online Gmail help
Dec 26, 2016 | Computers & Internet
Tip
How to set up Gmail on my Motorola Razr
<p>Creating a Gmail account on a Motorola RAZR allows you to access and send e-mail, even when you're away from your home computer or office. As email typing on the keypad of the RAZR seems difficult to have your Gmail account configured on a cell phone is useful for analyzing e-mails on the road. RAZR models feature an email client that lets you access Gmail, but you must manually configure the client to access Gmail using Post Office Protocol (POP) for incoming messages, and Simple Mail Transfer Protocol (SMTP) for outgoing. <br /> <p><br /> <p>1. Press the menu button and select "Messages" menu by pressing the "Select" soft. <br /> <p><br /> <p>2. Go to the "Email" option, and click the "Menu" button. Then choose "E-mail Settings." <br /> <p><br /> <p>3. Mark "ISP Setup" and press "Select" soft. This shows the settings for the mobile Internet, this information is provided by your mobile provider, and should not change. Click "Done" button after ensuring that all fields are filled <br /> <p><br /> <p>4. Highlight the "Account Settings" option, and click "Change" button function, which is assigned the appropriate button below the screen. <br /> <p><br /> <p>5. Highlight and select "New" and enter the account information e-mail, as described below. <br /> <p><br /> <p>6. The name of your account, in this case, using the numeric keypad to enter the account name "Gmail" is the best choice, although the account name "Personal", "Home" or whatever you see fit. <br /> <p><br /> <p>7. Enter the display name you want to link to all e-mails sent in the "Name" field. Enter your name using the keypad on your RAZR. <br /> <p><br /> <p>8. Enter the username to your Gmail account in "User ID" field. Your Gmail username in the format "username@gmail.com". If the "@ gmail.com" your account name, because Gmail also supports business accounts using different domains. Replace "username" with the Google account name. You will need your e-mail is also enrolled in the complete "Return Address" field in the account setup window. <br /> <p><br /> <p>9. Enter your Gmail password in "Password." <br /> <p><br /> <p>10. Scroll to "send host" field, and type in "smtp.gmail.com". Enter "25" in the "Outgoing Port" field. <br /> <p><br /> <p>11. Enter 'pop.gmail.com' in the "target host", type "110" in "door to receive" field. <br /> <p><br /> <p>12. Click "Done" to e-mail setup. <br />
on Aug 18, 2011 | Motorola Mobility RAZR V3
Tip
Gmail on outlook!
To use your Gmail e-mail account in Outlook, you must first make sure POP3 support is enabled in Gmail, and then you can add it to Outlook.
Log in to your Gmail account.
At the top of any Gmail page, click Settings.
In the Mail Settings window, click Forwarding and POP.
I don't see Forwarding and POP
Gmail is turning on POP3 support for users in phases. If Forwarding and POP does not appear, your Gmail account cannot be configured for POP3
support.
In the POP Download section, select Enable POP or all mail or Enable POP only for mail that arrives from now on.
Click Save Settings.
In Outlook, on the Tools menu, click E-mail Accounts.
Click Add a new e-mail account, and then click Next.
Click POP3, and then click Next.
Under User Information, do the following:
In the Your Name box, type your full name the way you want it to appear to other people.
In the E-mail Address box, type your e-mail user name followed by @gmail.com.
Under Server Information, do the following:
In the Incoming mail server (POP3) box, type pop.gmail.com.
In the Outgoing mail server (SMTP) box, type smtp.Gmail.com.
Under Logon Information, do the following:
In the User Name box, type your full e-mail address, including @gmail.com.
In the Password box, type your password.
Select the Remember password check box.
Note You have the option to have Outlook remember your password by typing it in the Password box and selecting the Remember password check
box. Having Outlook remember your password means that you won't have to type your password each time you access the account; however, it also
means that the account is vulnerable to anyone who has access to your computer. Use strong passwords that combine upper- and lowercase letters,
numbers, and symbols. Weak passwords don't mix these elements. Strong password: Y6dh!et5. Weak password: House27. Use a strong password
that you can remember so that you don't have to write it down.
Click More Settings.
On the General tab, under Mail Account, type Gmail.
Click the Outgoing Server tab, and then select the My outgoing server (SMTP) requires authentication check box.
Select Use same settings as my incoming mail server.
Click the Advanced tab, and then under Server Port Numbers for both Incoming server (POP3) and Outgoing server (SMTP), select the This server
requires an encrypted connection (SSL) check boxes.
Change the Outgoing server (SMTP) port number to 465.
The Incoming server (POP3) port number should change automatically to 995 when you select the This server requires an encrypted connection (SSL)
check box.
Click OK.
To verify that your account is working, click Test Account Settings. If there is missing or incorrect information, such as your password, you will be
prompted to supply or correct it. Make sure your computer is connected to the Internet.
Click Next, and then click Finish.
Notes
Do not select the Log on using Secure Password Authentication (SPA) check box.
Unless specified by Gmail, all server and address entries are typed in lowercase letters.
This works for both Outlook 2003 and 2007!
on Sep 04, 2009 | Microsoft Office Professional 2007 Full...
Cannot access yahoo mail
If you are unable to access your yahoo mail account or facing an issue to access your yahoo account then just do some simple steps and solve our issue.
1) Sign in yahoo account.
2) Go to settings.
3) click on accounts from the left panel.
4) create one extra email address.
5) Enter an email address in the required option.
6) In the last step, you will get the code. Put that code in the required field.
For getting more info or to update your yahoo messenger latest version you can visit this:
Get your Yahoo Messenger Update with its Latest Version
Apr 30, 2016 | Yahoo Mail
I created a new gmail account on my iPhone but my computer does not recognise it - i am on mac and have Mac mail
When you set up an email account on the iPhone, it does not automatically get set up on your computer.
If you can send and receive emails through your gmail account on your iPhone, to set up your Gmail account on Mac Mail
  • Launch Mac Mail on your computer
  • Choose the "Mail" menu and select "Add Account"
  • Select Gmail, and provide your email address and password at the prompt.
This assumes that you created the Gmail account with Google. That means you would have visited the Google site and first created the email account in Safari, or another browser, on your iPhone or Mac.
If you need further help, reach me via phone at https://www.6ya.com/expert/john_77bb351c0c06b354
Mar 13, 2015 | Computers & Internet
How do I log into my old gmail account after creating a new one?
Each Gmail account ought to have its own password. Often, people let their software "memorize" the password, but after some time tend to forget what it was.
I set up my Gmail accounts to "POP" settings so that they actually "download" the incoming mail locally to my computer. This way I've got ALL the mail I want to keep ON my computer, meaning I don't have to use online access to Gmail to get it.
Aug 07, 2014 | Google Gmail
Login to my gmail account
Point your web browser at http://www.gmail.com
If another account comes up, sign out of it by clicking the avatar in the upper-right then clicking "Sign out."
If you then still can't get in, click the "Can't access your account?" link on the sign-in page.
Jan 02, 2014 | Computers & Internet
G mail login
-Check if you have locked your CAP.
then try your password again.
-Did you type your email properly?
if not then well, you should type correctly.
Nov 20, 2013 | Computers & Internet
I cannot configure my gmail account with outlook
  1. Log in to your Gmail account.
  2. At the top of any Gmail page, click Settings.
  3. In the Mail Settings window, click Forwarding and POP.
  4. In the POP Download section, select Enable POP or all mail or Enable POP only for mail that arrives from now on.
  5. Click Save Settings.
  6. In Outlook, on the Tools menu, click E-mail Accounts.
  7. Click Add a new e-mail account, and then click Next.
  8. Click POP3, and then click Next.
  9. Under User Information, do the following:
  10. In the Your Name box, type your full name the way you want it to appear to other people.
  11. In the E-mail Address box, type your e-mail user name followed by @gmail.com.
  12. Under Server Information, do the following:
  13. In the Incoming mail server (POP3) box, type pop.gmail.com.
  14. In the Outgoing mail server (SMTP) box, type smtp.Gmail.com.
  15. Under Logon Information, do the following:
  16. In the User Name box, type your full e-mail address, including @gmail.com.
  17. In the Password box, type your password.
  18. Select the Remember password check box. Note You have the option to have Outlook remember your password by typing it in the Password box and selecting the Remember password check box. Having Outlook remember your password means that you won't have to type your password each time you access the account; however, it also means that the account is vulnerable to anyone who has access to your computer.
  19. Click More Settings.
  20. On the General tab, under Mail Account, type Gmail.
  21. Click the Outgoing Server tab, and then select the My outgoing server (SMTP) requires authentication check box.
  22. Select Use same settings as my incoming mail server.
  23. Click the Advanced tab, and then under Server Port Numbers for both Incoming server (POP3) and Outgoing server (SMTP), select the This server requires an encrypted connection (SSL) check boxes.
  24. Change the Outgoing server (SMTP) port number to 465. The Incoming server (POP3) port number should change automatically to 995 when you select the This server requires an encrypted connection (SSL) check box.
  25. Click OK.
  26. To verify that your account is working, click Test Account Settings. If there is missing or incorrect information, such as your password, you will be prompted to supply or correct it. Make sure your computer is connected to the Internet.
  27. Click Next, and then click Finish
  • Do not select the Log on using Secure Password Authentication (SPA) check box.
  • Mar 20, 2010 | Google Gmail
    ourWorld.com ourWorld Logo
    44 people viewed this question
    Top ourWorld.com Facebook Apps Experts
    David Payne
    David Payne
    Bill Boyd
    ray gallant
    Are you an ourWorld.com Facebook App Expert? Answer questions, earn points and help others
