Question about NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000
Glow bouy will ony stay on for 45 minutes
Some times only 15 minutes
  • 640 Answers
According to the owners manual for these swimming pool lights, if you light is not working for the full amount of time expected (at least 4 hours) you should try the following troubleshooting steps:
1. The battery pack might not be fully charged. Check the charge and recharge if necessary.
2. The battery pack or charge might be defective. Run the light through several charging cycles. If it fails to hold a charge but the indicator lights are showing normal operation, take the light to an authorized repair shop.
3. The battery pack might be old. After approx. 600 charges, the batteries might lose their ability to be charged. If this is the case, take the light to an autorized repair shop to receive new battery installation.
4. The product might be overheated. The light's internal temperature regluator will shut of the product to prevent damage. Allow the light to cool down and then test for normal opperation.
Posted on Jun 16, 2010
How do I reset the time on the fax machine. The time showing is not correct its out about 15 minutes
Faxes are more than 15 minutes out of date. More like a decade plus.
But if you insist, go back to menu, setup, station, then reset date and time.
Oct 31, 2017 | The Office Equipment & Supplies
Perm Press cycle only runs for 2 min. and jumps to 14-15 min. every time.
find your manual and read it . sounds like the cycle has a 12 to 15 minute limit .
Feb 14, 2016 | Samsung DV330AE Dryer
I have a Bulova chime mantle clock, three wind, that needs sync. it is off by 15 minutes (it chimes 1/2 hour on 15 minute time etc. can you help me?
Simplest way is to remove the minute hand on dial and reseat it at the correct setting I.e one quarter turn .recheck the hour chime is on hour etc.replace glass front.
Jun 20, 2015 | Bulova Collins Majestic Triple Chime...
Smart T.V Sumsung Got Stuck
It sounds that your TVs' timer function is set to 'ON' for 15 minutes time. Check it, and make it 'Off'. Refer its user manual for details.
Jul 21, 2013 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Need to st clock on panasonic nne281mm
follow the steps and fix it. God bless you
1) Press the "Stop" button on the microwaveicon1.png to reset the digital display to the clock setting.
2) Push the "Clock" button once. Locate the "Hour" button and press it once for each hour of time. For example, if the current time is 5:15 p.m., press the Hour button five times.
3 )Press the "Minute" button to set the second half of the time. For the example above, you would press the Minute button 15 times to set a time of 5:15 p.m.
4)Push the Clock button to saveicon1.png the time setting. Check the time on the microwave's digital display.
Feb 07, 2013 | Panasonic Microwave Ovens
How do I rest the time on the fax. It's off by 15 minutes
type ip address of the printer in browser
select time
and correct it
Oct 28, 2009 | HP Photosmart C6100 All-In-One Printer
Alarm problems
When creating a new alarm, the LG Shine will start with the "Set Time" function where you can set a 15 minutes alarm jump (by moving the navigation button horizontally). If not desired, you can go one step down onscreen to set the alarm time manually. If you accidentally jump back to the 15 minutes jump method in the previous function, it will automatically postpone the alarmsetting with 15 minutes increments again. Please verify you don't use that function by accident while setting up the alarm time manually. If all of this is not the case, I would suggest to return the phone because there could be a problem with the phone or software.
Feb 06, 2009 | LG Shine KE970 Cellular Phone
Setting up the AM and Pm of time on calculator
Time has to be entered as in military time:
Example: 3:15 AM = 03:15
or
Example: 3:15 PM = 15:15
The calculator's clock works just like a 24 hour clock and will automatically display AM or PM depending on how you set it up with hours and minutes.
Jul 22, 2008 | Sharp EL-1197P Calculator
NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000 Logo
161 people viewed this question
Top NRS Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a NRS Pool and Spa Expert? Answer questions, earn points and help others
