Question about Lacor 69049-Maxi Vacuum Machine 120 W
Lacor 69049-Maxi no sealing
I have wasted quit a bit of the bags because the food saver is not sealing completely. It leaves a 1/4 to a 1/2 inch unsealed therefore I can not vacuum seal. What am I doing wrong
Try making a seal with nothing liquid in bag, check seal on bag after. If seal looks good it could just be liquid getting on seal area causing it not to seal. There are tips online on how to help prevent this (example: placing rolled up paper towel sheet). If seal still looks bad than you may have a bad spot on the heat seal wire.
Jan 23, 2016 | Vacuums
Seals but won't draw all the air out. Seals fine
That could be a bad foam seal not completing suction, A piece of debris that got sucked into vacuum line and or in pump, or in some cases a crack in a elbow or pump housing.
Jan 22, 2016 | FoodSaver Vacuum Sealer Kit V3460
Why does the vacuum sealer not seal the bag nor seal?
wow when I ran my food business I seemed the only one that could get this thing to seal right every night , Im gonna say it was because I wasn't in a big hurry , these machines work great but there not fast it takes sometimes 5/10 minutes to get a good seal on them , and you cant overload them either , when it comes to these less is more , makes for a easier time using them
allow the food to stop about two inches from top edge of bag , and wipe any loose food from the sealing surface (inside) as this will affect the seal as well
Jan 19, 2016 | FoodSaver V3420 Smart Seal Vacuum Sealer...
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
Hi I have an Ariston Aqualia front loader. It has
You could try mild solution of bleach to the drum, perhaps replace door boot seal..
Nov 04, 2009 | Vacuums
Leaking Solution Tank/Seal Install - Hoover Steam Vac
Not sure this will help, but we have a Hoover Steamvac F5843 and our valve seal seemed to have shrunk so the tank was leaking. Bought a new seal and had the same problem. How to install? There weren't any instructions or pictures of the part(s) involved in the manual. Online there were a few pics but nothing helpful. After careful examination of the existing part and where it was supposed to be, I removed the original off the valve stem, placed the new one on it and carefully pressed the valve stem with the seal into place. It didn't look quite right and we were thinking "now what?". My wife and I got the idea at the same time...install the clean water tank (with the stem & seal in the bottom) back onto the steam cleaner. I took it back off to see what the stem & seal looked like afterwords and voila...the seal was perfectly inserted where it should be and the tank no longer leaks! The 'peg' that presses up on the valve stem pushed the seal perfectly in place.
Nov 16, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Steamer will not **** up the water
There is a black rectangular seal under the front of the tank that seals to the top of the tank lid to the suction of the cleaner be sure that the seal is there and sealing properly that should fix it. If you need to order that seal or cleaner for that machine or any other visit www.stevessewandvac.com
Aug 12, 2008 | Bissell Vacuums
Melts the bag and won't seal
if your vacuum cleaner gets hot enough to melt it's own parts, i think you have a problem. exesive heat could indicate a serious problem and might also cause a fire. try having it checked by a repair shop because replacing the seal and continuing to use it might be dangerous.
Mar 30, 2008 | Vacuums
Lacor 69049-Maxi Vacuum Machine 120 W Logo
22 people viewed this question
Top Lacor Vacuums Experts
Are you a Lacor Vacuum Expert? Answer questions, earn points and help others
