Question about HP LaserJet 1020 Printer
There was a problem with teflon sleeve in hp 1020 printer. so i replaced new teflon sleeve. But after i replaced teflon sleeve i faced a new problem. that is, there is a noise just like a drum frictio
There was a problem with teflon sleeve. So I repleced it with new one. Now I facing a different problem. That is, there is a noise just like a drum frictioning. My printer model is hp 1020.
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Please sure that when you replace teflon sleeve can you lubricate it's base with soilicon or other high quality grease..... if not then do so
other thing is that be sure about noise it is from drum or upper portion of the printer
Posted on Apr 02, 2014
    Problem Solver:
  • 13 Answers
Fixing film/sleeve must be lubricate with grease prior to installation. Check if you properly return all the components in heating area.
Posted on May 28, 2014
What is the rate of teflon of 1005 printer
Do you mean how many pages does the P1005 print before it requires replacement?
Here is the service manual, it is the fuser fixing sleeve:
http://www.lbrty.com/tech/Manuals_HP/P1000sm.pdf
A youtube video on the procedure:
https://www.youtube.com/watch?v=dSenawkbM3M
The part on Ebay, it mentions 30,000 pages:
http://www.ebay.com/itm/1x-Fuser-Film-Sleeve-HP-LaserJet-P1005-P1006-P1007-P1008-Grease-Grade-A-manual-/270940113101
May 28, 2014 | HP LaserJet 1020 Printer
HP LJ P3015 Printer not printing clearly after replace the sleeve
Reasons:
1. Teflon Sleeve, use better quality sleeve.
2. Apply good quality of Teflon grease.(Don't apply more or less)
3. Chk Fuser temperature..& connectors..
4. Adjust Fuser temperature in fuser mode..
May 23, 2014 | HP Laserjet P3015X Printer
when replacing the Teflon sleeve did you clean the heating element? if so did you also re apply new fuser lube? this Lube is not a normal lube.. its a lube that is specifically manufactured for fuser units and Teflon sleeves.. you can buy it thru a Company called Precision Roller look them up on line
Apr 01, 2014 | HP LaserJet 1020 Printer
Hp Laserjet 1020 Left Side Margin Problem
change your drum or teflone inside the printer
Jan 22, 2014 | HP LaserJet 1020 Printer
Process for changing teflon sleeves
suggest the job of stripping the fuser to replace the fuser sleeve(roller) is something to be done by a qualified technician. for this size machine the job should take less than an hour with most of the time spent removing and reinstalling the fuser assy
Jan 15, 2014 | HP LaserJet 1020 Printer
What is causing the black lines that I am getting on all of my printed pages?
Most of the cases vertical lines on print out causes 1. Toner cartridge 2. Fuser Teflon sleeve.. If you are replaced with new cartridge try to replace fuser teflon sleeve( only professionals can do this activity)
Jul 31, 2012 | HP LaserJet 1020 Printer
Vertical grey line about 2 inches wide appearing to the right of the page. Print seems ok apart from this. Tried new cartridge but still happening.
Teflon sleeve might be damaged, My suggestion replace both Teflon sleeve & pressure roller if available or else replace fuser assm..
Sep 27, 2011 | HP LaserJet 6L Printer
2 pages are accrdianed in the very back of the printer. I cannot see a way to open to get them out. Is this a case where I have to just pick them out?
Paper might be roller on teflon sleeve, take out fuser from the printer, remove paper gently to avoid damage to teflon, after removing the paper observe that is there toner particles deposited on teflon sleeve, if observed replace the teflon sleeve,other wise this problem will repeats again & again.
Note: for this process technical skills required.
Sep 24, 2011 | HP LaserJet 1300 Printer
ONE SIDE OF PRINT IS COMING BLACK PRINT OF MISSING SOME WORDS
Might be Teflon sleeve warn out or damaged, replace it..
Sep 20, 2011 | HP LaserJet 1020 Printer
After replacing teflon sleev printer dont fuse the text properly. it washed out with hands and
re install the sleeve properly and use minimal sleeve grease. If it is installed correctly some brands of chinese made sleeves are **** and dont work. Try one from a different seller.
Feb 26, 2011 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
91 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
