Question about Dodge Vehicle Parts & Accessories
2004 dakota sxt OE replacement rear trans mount
Looking to purchase OE replacement rear transmission mounts 2004 dakota sxt rwd v6 3.7L, I need to know best pricing for OE replacement rear transmission mounts 2004 dakota (sxt rwd) and where do i order these?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 103 Answers
If it's 2wd, it should be Napa 620-1294 or equivalent at other places.
Posted on Apr 02, 2014
How to replace rear engine motor mount
1994-1997 Honda Accord Rear Motor Mount - YouTube
? 13:31
https://www.youtube.com/watch?v=QTDLBZonjvo
Aug 14, 2014 - Uploaded by NutzAboutBolts
1996 Honda Accord rear engine mount Tools: Impact wrench 3/8 ratchet ... Wat size are those bolts in the rear motor mount, I have to replace them ..... 1998-2002 Honda Accord 3.0 V6 Spark Plug Replacement - Duration: ...
How to Replace the Motor Mount on a Honda Accord ...
? 5:28
https://www.youtube.com/watch?v=jCIBNq0jg0U
Oct 17, 2013 - Uploaded by Chandler Cox
How to Replace the Motor Mount on a Honda Accord .... I have 2001 Accord and engine/front vibrates when car is idle. .... onreplacing and removing rear mounts for this year and model car.... 1998-2002 Honda Accord 3.0 V6 Spark Plug Replacement - Duration: 12:48. by CharlietoKind 103,467 views.
How To Change A Motor Mount and Transmission Mount ...
? 29:43
https://www.youtube.com/watch?v=vkO19Ux9q9M
May 30, 2013 - Uploaded by klowny1969
Step by step honda transmission motor mount and transmission... 2000 2001 2002 2003 2004 2005 engine mount how to replace install check change ... MAKE A VIDEO TO INSTALL THEREAR MOUNT MOTOR PLEASE .
Dec 16, 2015 | 2002 Honda Accord
How do i know which motor mount needs replacement
With car in drive/reverse and foot hard on brake if the engine moves when gas pedal is depressed and quickly released in both D&R, then that mount/mounts is defective...
Engine mount should be replaced if:
1) The hard rubber surface is covered with heat check cracks.
2) The rubber is separated from the metal plate of the engine mount.
3) The rubber is split through the center of the engine mount
The transmission case will crack or break if either engine mounts or transmission rear mount is broken...Here is a GM Service bulletin addressing the issue:
#02-07-30-024B
The transmission mount (see drawing) test:
>Raise and support the vehicle
>Raise the transmission/transaxle in order to remove the weight from the transmission/transaxle mount and create slight tension in the rubber.
Replace trans. mount if anyone of the three conditions listed above exist
...saailer
Jan 02, 2015 | 2004 Chevrolet Impala
VW Jetta MKIV - G68 sensor replacement - how to lower transmission?
Use a floor jack or trolley jack under the transmission. Also use a block of wood if you have the jack on the transmission's lower pan. You will see that the whole engine and transaxle assembly will tilt down somewhat with the transmission mount removed. If it is not enough to replace the sensors, raise the jack back up and take off that dogbone, then lower the whole thing again until you can get to the sensors. Be careful when getting the mounts back on, that the engine and transaxle settle down perfectly into the mounts, so you have no vibration issues.
May 20, 2014 | 2008 Volkswagen Jetta Wagon
How to remove rear transmission mount bolts
remove air cleaner housing to have better access to the 4 17mm bolts holding the mount to the trans
Apr 22, 2014 | 2004 Kia Sedona
Chrysler caliper bracket
you will need the rotors, calipers, brackets, and pads off of a 300c
Apr 28, 2013 | Cars & Trucks
Where is the transmission mount on a 2003 dodge neon sxt
Really : !!
Get under the car & change all engine & transaxle mounts at on time
If you can't find & identify them-- then you not up to changing them
Have a repair shop or trans shop do it
Dec 07, 2012 | 2003 Dodge Neon
How do you change the transmission fluid in a 2004 GMC Yukon Denali?
At the bottom of your transmission there is a large square/rectangular pan (depends which trans you have). Have a large drain pan to catch 5 to 9 liters/quarts of transmission fluid. Undo all of the retainer bolts and carefully lower the pan (this can get messy for the unexperienced) .
In some cases the rear transmission mount may need to be undone and the rear of the trans lifted to allow clearance for the pan to be slid past the crossmember.
Replace the trans filter too!
Oct 31, 2009 | 2003 GMC Yukon Denali
Transmission Mount is broken
Check the frame crossmember at the mount. If it looks like the crossmember can be unbolted, it should be a simple job. You would remove the crossmember while supporting the tailshaft. Then unbolt the trans mount from the transmission, change out the parts and reinstall. Or have a shop put it on a lift and change it out in less than an hour.
May 30, 2009 | 2004 Ford Crown Victoria
Engine light came on, doesn't up-shift
The transmission is in limp in mode. The check engine light is on because the transmission controller told the engine controller to turn it on. You will have to get the fault codes checked to diagnose the problem. Expect to find a P0700 code in the engine controller. Thats the code for a transmission fault in the trans controller. It could be as simple as an input speed sensor or as complexed as an internal failure. Either way have the transmission fault codes checked for a proper diagnosis.
May 15, 2009 | 2004 Dodge Dakota
Vehicle Parts & Accessories Logo
95 people viewed this question
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
