Question about Dodge Vehicle Parts & Accessories
OE replacement rear transmission mounts 2004 dakota sxt rwd
Looking to purchase OE replacement rear transmission mounts 2004 dakota sxt rwd v6 3.7L, I need to know best pricing for OE replacement rear transmission mounts 2004 dakota (sxt rwd) and where do i order these?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
I believe this might be the part your looking for.
DEA Motor and Transmission Mount JCWhitney
Posted on Apr 02, 2014
We are looking at purchasing a 2004 Volvo XC70 details below
best advice look for another car somewhere else as it is a pristine lemon
if you still want the car get a quote from an accredited automotive transmission specialist shop as the price quoted may be for a genuine factory out of the box price but a fully reconditioned unit with 12 months guarantee andy be around 1/3 of the price
Jun 13, 2017 | Cars & Trucks
I have a 94 chevy Silverado 5.7l with 4l60 transmission will a 97 chevy Silverado 4l60 work even if the speed sender is on different side and made different on transmission
Chevrolet / GMC / GEO Transmission Look Up Table
www.autorepairmanuals.biz/page/372807
Blazer, 1993-, 4L60-E. Blazer, 1994 - Up, 6.5L V8 Turbo Diesel, 4L80-E. BLAZER/TRAIL BLAZER/JIMMY, 1995-2003, 4 SP RWD/4X4, L4 2.2L L6 4.2L V6 4.3L ...
Transmission Applications - GM Automatic Transmissions
www.gmautomatictransmissions.com/transmission_applications.php
Avalanche, 2001-06, V8 5.3L 5.7L 6.0L, 4 Spd RWD/4X4, 4L60E. Avalanche, 2004-06... Camaro, 1994-05, V6 3.4L 3.8L, 4 Spd RWD, 4L60E. Camaro .... Monte Carlo, 1997-05, V6 3.8L (W/S.C.), 4 Spd FWD, 4T65E. Monte Carlo ... Silverado, Sierra,1500-3500, 1995-06, V8 4.8L 5.0L 5.3L, 4 Spd RWD/4X4, 4L60E. Silverado ...
4L60E Transmission Rebuilt ' eBay
Dec 27, 2015 | Cars & Trucks
2004 dakota sxt OE replacement rear trans mount
If it's 2wd, it should be Napa 620-1294 or equivalent at other places.
Apr 01, 2014 | Dodge Vehicle Parts & Accessories
Chrysler caliper bracket
you will need the rotors, calipers, brackets, and pads off of a 300c
Apr 28, 2013 | Cars & Trucks
Shaking issue when accelerating- 2004 dodge dakota have replaced transmission mount, flushed transmission, and replaced sway bar
Check your universal joints, as well as your wheel bearings and play in your front wheels. If your pitman arm, idler arm, or tie rods are worn the initial acceleration will cause a shaking feeling because the tires are wobbling.
The Universal joints are a big problem as well, and you should check them before its too late. If one breaks you can damage your drive shaft when it hits the road.....Let me know what you find.
Mar 07, 2011 | 2004 Dodge Dakota
The brakes, when pressed in the front, seem to not stop and slide , brake lights will not come on, transmission shift makes noise when shifting from park to driveand to reverse. I have taken my vehicle...
Brakes - most common is brake pads were replaced with non-OEM pads and/or rotors were machined during the brake service. Use OEM brakes pads and replace, instead of machining, rotors. Again, use OEM parts for best results. GM recommends replacing rotors during brake service on that model, similar to European models. Unfortunately, GM has not priced the rotors as the Europeans have priced theirs.
Transmission noise - I am assuming a "clunk" noise when shifted while at a stop, also known as "garage shift". Most common is the bushings in the rear differential housing mounts. They may look OK upon inspection but when removed they will be split. Second common is similar issue with transmission mount itself, although that is quite rare.
Brake lights - Any competent automotive electrical repair facility should be able to diagnose this as there is an open in the circuit somewhere. That system is relatively simple and stratagy based diagnosis should lead the technician to the problem.
Nov 22, 2010 | 2004 Cadillac CTS
Engine light came on, doesn't up-shift
The transmission is in limp in mode. The check engine light is on because the transmission controller told the engine controller to turn it on. You will have to get the fault codes checked to diagnose the problem. Expect to find a P0700 code in the engine controller. Thats the code for a transmission fault in the trans controller. It could be as simple as an input speed sensor or as complexed as an internal failure. Either way have the transmission fault codes checked for a proper diagnosis.
May 15, 2009 | 2004 Dodge Dakota
Front wheel drive or rear wheel drive?
do a spinout in some dirt or snow and have a friend watch! Step on the gas and peel out, then hit the brakes and see where the skid mark is!!! lol
the easiest way is to look underneath. If there is a long tubular drive shaft from the transmission to a rear gear differential, it is RWD.
If there is no rear differential, it is FWD.
Look at the engine too... if it is linear to the body... RWD. FWD engines sit sideways and have 1/2 shaft axles coming out of them with rubber boots.
Dec 25, 2008 | 1985 Toyota Pickup
2WD OR 4WD? To buy or ot to buy!
On the plus side, 2wd gets better gas mileage, is cheaper to operate over time (no 4x4 transfer case or any 4x4 components to wear out or maintain). With a good set of snow tires and weight in the back, winter traction should be ok. The mileage 63k, is good too. If u live in southern New England, as I do, u can probably get by w/out 4x4.
On the negative side, If you have a job that requires u to be there no matter what the weather, and u live where there's a lot of snow, then maybe 4x4 is really necessary. How many days over the last few winters did you REALLY need 4x4? Around here, I'd say maybe 6 days a year. Do you really need it for 6 days?(or however many for your area). It is great to have when u need it, but u have to justify the extra expense for occasional need.
On a personal note, my 1st truck was 2wd, and I hauled a lot of stuff to the dump when I purchased a run down house. After loading up to overflowing, I got stuck in the yard, and had to unload everything to get out. I swore I'd never own a 2wd truck again. But gas was about 45 cents a gallon then, and now, 2 4x4's later, I avoid driving the truck due to gas prices, (I do plow snow, haul firewood, lumber, etc, buts after all this blah blah blah, I probably have u more confused than ever! GOOD LUCK, and let me know what u decide. countrycurt0
Sep 03, 2008 | 2000 Dodge Dakota Quad Cab
Vehicle Parts & Accessories Logo
124 people viewed this question
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Ruben Diaz
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
