Question about Sony Cyber-shot DSC-W120 Digital Camera
Memory stick formatting error
My digital sony camera cannot capture a pictures. i started formatting my memory stick using usb connected to pc i have lost any data and my camera cannot capture a picture because of memory stick formatting error.pls help a problem
  • 4 Answers
Try formatting the stick through the camera itself. else download the software of camera and connect it to pc and see if it has any formatting options...
Posted on Apr 01, 2014
bmwrider
  • 215 Answers
SOURCE: "No Memory Stick" errors
Due to the length of the memory stick it rarely causes bent pins sideways but they can over a long period lose their tension and fail to make contact with the memory. Also, more commonly they can tend to get a build up of dirt on them. Try using an old memory stick and quickly push the stick in and out of the camera as fast as you can and do this for about 15 to 20 times (with the camera off of course) this should clean any gunk built up on the contacts. Now switch on and use the new stick to see if it's working. If not try the exercise again. If it still doesn't work try sticking 2 layers of sticky tape to the front (the side opposite the gold contacts)Run the tape from the bottom (the contact end) to the top. Running it to the top will ensure it comes out with the stick when you eject it and it doesn't stay inside causing problems. Doing this will marginally increase the size of the stick and put a little more pressure on the contacts. Just nake sure the sticky tape comes nowhere near touching the stick's contacts as this will tend to make them pick up dirt. Also this trick is only to see if it's you camera's contacts have lost tension, its not meant as a permanent fix. If neither of these tricks work I'm afraid it's a trip to the camera hospital.
Posted on Jul 20, 2006
  • 17 Answers
SOURCE: Format error in Sony Cyber-Shot DSC-S650
Format the memory stick via setup menu inside the camera. Let me know if this works.
Posted on Nov 11, 2007
welcomejee
  • 10594 Answers
SOURCE: format error
Format memory stick, if no data on it.
If there is data on memory stick, copy it on PC using any good card reader.
Posted on May 31, 2008
SOURCE: Memory Stick Formatting Error - Sony Cyber Shot DSC T-20
I have had the same problem. Contact your camera via USB to your PC. Click on MENU. You do see "USB Connect" and "folder" at the bottom. Make sure that it stays on "USB Connect" click on round button in the middle and you will get 4 options. It probably stays on AUTO. Select PTP and see what happens. Adobe Photo Album started up and I got to see the pictures till the moment that the stick got the format error. I lost a couple of pictures, but got a lot back.
I'm not sure what the problem is, however realized that if this happens again. Shut your camera. Start it up again. Go into MENU, SET UP, Memory stick tool, chnage Rec folder and create a new. This way you keep the folders smaller and do not loose that many pictures.
I hope that it helps.
Pepe
Posted on Jun 05, 2008
SOURCE: sony memory stick pro duo format error
when i turn my camra on its does nothing it has a black screen and it don't turn off then when i take the memory stick out it works and turns off with no problem
Posted on Sep 21, 2008
When i turn on my camera it says the memory card needs formatting i follow the instructions but it doesnt work and keeps saying to format the memory card. this happens over and over and i cannot take...
To understand the photo loss situation, consider a scenario: You format a memory card in Digital Camera, and start to capture some pictures. However, while capturing pictures, your camera shuts down due to low battery. Now, after recharging battery, when you try to access those photograph on the card, you receive the following error message on camera screen:
The Card requires formatting: Additionally, the camera is unable to capture any new photographs.
The main cause for the above error message is corruption of memory card due to conking of battery while a read/write operation was running.
These memory card needs to be formatted before you save any new pictures. It is always a good practice to take backup of card and format it before use. This enables you to fight with any damage done to the memory card and to erase the old data saved on the card. However, the probability of card getting corrupted again (after you have saved new data) still exists.
First try formating with an external SD Card reader connected at PC and test it.
Oct 13, 2011 | Kodak EasyShare C143 Digital Camera
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
Problems with my Sony Cybershot W210
1) Make sure that you're not using more than 4 GB memory stick pro duo with the camera. Then try to remove the memory stick and capture 2 images in the internal memory and turn OFF and turn ON the Camera and check. If the error message comes, its the issue with the Camera itself and requires service after resetting. to reset the Camera, select Initialize under Main Settings 1 menu under Settings. if the issue persists, the camera may require service
If its working fine, transfer all the images to the Computer and format the memory stick. Formatting will delete all the contents. If the issue persists, memory stick should be replaced.
Sep 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
I was trying to download new pics to my computer using a USB cord
Please try using a different Memory Stick and check whether the issue persists.
Please try Formatting the Memory Stick using the Camera.
Jun 14, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Format error
If Duo Pro got hardware problem, then it can not be fixed and you can't retieve data on it. Regarding new memory stick, camera will check it and let you know about format it or not.
Jul 31, 2008 | Cameras
Dsc h9 Sony file error
yeah, go to camera menu and format memory stick.
if same thing exist, format it with PC.
Apr 06, 2008 | Sony Cybershot S650 Digital Camera
Memory Stick Duo Formatting Error
when i turn on slide show the slide show music is not working and it is error of coming to show the music download music from pc and connect to pc
Jan 06, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
Nov 09, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Pepe
Oct 30, 2007 | Sony Cyber-shot DSC-T9 Digital Camera
Sony Cyber-shot DSC-W120 Digital Camera Logo
47 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
