Question about Glacier Bay Stainless Steel Kitchen Sink: 2-Hole Double Bowl All-in-One Top Mount
Same issue glacier bay soap dispenser not pumping soap...recently installed. Has never pumped soap. Did you ever get the problem resolved?
Diluted soap..did not work. Put water in bottle still will not pump.
My soap dispenser wont pump soap
Are you out of soap? Does the pump go freely up and down? If the pump goes down a little and then stops its probably clogged. If this is the case just get a long piece of notebook wire and slide it through the pump and it may unclog it. Really a soap pump is a very simple set-up. Suction from one end brings the soap through the tube and out the actual dispenser. Hope this was helpful:)
Sep 20, 2012 | Grohe Soap Dispenser for Kitchen...
Soap despenser+will not dispense soap.
Hi. WHen a soap dispenser will not dispense soap it is generally because of one of two things. Either it is clogged or the soap you are dispensing is too thick and needs to be diluted a little with water, or possibly both. J.
Aug 07, 2010 | Delta Cycle Rothko Rolling Bicycle Stand
My grohe soap dispenser won't pump out any soap.
If the soap dispenser is not pumping the soap then the soap is to thick. You need to then the soap down some so it will pump.
Apr 01, 2010 | Grohe Satin Nickel Soap Dispenser...
Soap dispenser doesn't pick up soap
Make sure the clear tube is inserted into the pump head properly.Make sure the tube is not kinked. try filling the bottle full of water and try pumping the water out first. Sometimes the dispenser gets an air lock and takes a bit of continuous pumping to get it to work
Feb 24, 2010 | Price Pfister Marielle Kitchen Faucet with...
I have a Simple Human 14 oz sensor Soap Dispenser
This is what I found in the Simplehuman FAQ's. I had to wait about 30 minutes for the light to stop blinking, but it seemed to work for me.
If the pump is unresponsive or the blue light is flashing, fresh batteries should resolve this issue. Please power off the pump completely. Once the pump is turned off, remove the old batteries. Please wait for the pump to reset (until the flashing light stops and preferably letting it rest overnight) before you install the new ones.
Aug 05, 2009 | Kitchen Appliances - Others
Kitchen sink soap dispenser won't pump
soap may be too thick or pump tube may not be touching soap in dispencer. try pumping same soap from cup
Mar 08, 2009 | Plumbing
It seems that the plastic pump mechanism is not
Unfortunately it is a very common problem with soap dispensers. First before you replace the dispenser, dillute a small amount of water mix with the soap in the bottle of the dispenser to see in fact if the pump is deffective. It could simply be that the soap is too thick for the pump to work properly. As to replace it, call the manufacture of the faucet which I presume came with the dispenser and very often they will stand by their products and send you one free of charge.
Feb 20, 2009 | Price Pfister Marielle Kitchen Faucet with...
Price pfister soap dispenser will not work
Replacement parts can be found on amazon. Click here Watkins Hand Soap Made Naturally Since 1868 and take a look. I hope this was helpful. Cheers
Dec 13, 2008 | Price Pfister Marielle Kitchen Faucet with...
Soap dispenser pump pricefister
Here is the link to installing a Price Pfister Soap dispenser:
Soap Dispenser
Hope this helps!
Nov 23, 2008 | Price Pfister Home
Glacier Bay Stainless Steel Kitchen Sink: 2-Hole Double Bowl All-in-One Top Mount Logo
76 people viewed this question
Top Glacier Bay Plumbing Experts
Donni Steen
Tom Chichester
Are you a Glacier Bay Plumbing Expert? Answer questions, earn points and help others
