Question about Locks & Locksmithing
I can't switch the alarm off, it goes off at 2am every day now
Somehow, while moving home. An alarm has been set on our weather pro and i don't know how to switch it off. I can't see an obvious alarm option.
otacon
  • 1944 Answers
SOURCE: Alarm Goes off
This is a known bug in the P990 firmware (I personally went crazy from this). You need to update to the latest firmware for this issue to be fixed.
Posted on Mar 26, 2008
SOURCE: I just got a Freestyle
I had the same problem. Emailed Freestyle support, it's pretty simple: Go into the alarm setting, and before you do anything else, push the reset button. That'll clear it. If you push the set button first, that'll put it in the set it mode, and the reset button will just advance you to the next setting.
Posted on Aug 18, 2009
  • 4 Answers
SOURCE: We have this HM3817DT CD radio and somehow the
When you press the AL SET/ SLEEP button on the remote or the system, it will flash. If you press it again, it should go away, meaning it is turned off.
Posted on Oct 10, 2009
Testimonial: "Thanks"
  • 173 Answers
SOURCE: car unlocked but it sets
Are you using the the keychain to lock unlock the vehicle? A low battery in the keychain will send wacky codes to your vehicle alarm system and will not set properly. Try using the key in the door to lock unlock vehicle. IF the alrm does not go off when using the key in the door, then you probably have to change the battery in the key chain. Best guess without being there to look at vheicle.
Posted on Feb 03, 2011
  • 5 Answers
SOURCE: Problem with launcher Pro and alarm clock. No way
I had the same problem the other morning. All I wanted to dowas go back to sleep, but the alarm would not shut off.
Here is how to fix it:
Go into the clock, then alarm clock and click the menu button, then settings. Go to Slide Button Behavior, which will give you threeoptions, choose none.
Now, when your alarm goes off there will be a pop up and you can either choosedismiss or snooze. Please don't forget to give thumbs up!!
Posted on Jul 14, 2011
Can't shut off alarm totally. It goes off every day. How do I shut it off.
Push the "alm/date" button to display the date instead of the alarm time. If the date is displayed on the LCD, the alarm will not sound.
Jan 06, 2014 | La Crosse WS 9037U IT CBP Wireless Weather...
Alarm goes off but after pressing done it sets off again for about 15 times...its irritating
  • Connect the Dash to an AC outlet via the power adaptor to turn it on. The initial setup wizard should appear if this your first time turning it on.
  • 2Touch "Menu" on the bottom left of the HOME screen. Then choose "Clock & Weather."
  • 3Choose either "Quick Alarm" or "Custom Alarms," if you've previously set up an alarm. Tap "On" to turn it on or "Off" to deactivate your alarm.
  • Sincerely. G-d bless you
    ernesto cuadra
    managua,nicaragua con.a.
    Dec 14, 2011 | Sony Ericsson P990i Cellular Phone
    Problem with launcher Pro and alarm clock. No way to turn it off or to put on snooze. I can't switch off my alarm clock or snooze. I have to turn off the phone completely to make it stop. I use...
    Jul 13, 2011 | McNeil-PPC Android Apps
    How do you set the day of the week and 24 hour on the watch?
    You only have to pull the crown of your watch to its third position ( to set the time) so that if you turn it until it reaches 2am or 3 am the day moves and you have to continue it until you reach the exact day of the week. Then, you don't have to set the 24 hour on the watch because the time remains the same on with the time on your watch. observe it. I hope that i had solve your problem.
    Jul 08, 2011 | Michael Kors Mk5039 Wrist Watch for Women
    I need help setting the alarm on my radio controlled digital clock.
    1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    I have an old Westinghouse Security Systems that keeps alarming every 15 minutes Model XL4600SM Key pad and its driving us crazy.. don't know how to shut it off can someone pls. help us (numeros days...
    Check all ur windows and doors sensoring connections,might need to be changes.Weather is too hot or too cold,will trigger the alarm.When u arming tries by passed and any error codes for doors or windows connections codes.This should stop the fault alarm by the expanding and contracting sensors by the weathers.
    Dec 15, 2010 | GE Security Simon 3 Wireless Home Security...
    What is the best time of day or night to set the date on Beringer watch Brand name not listed
    If it's a mechanical watch don not set the date between 7pm and 2am to avoid damage to movement.
    May 03, 2010 | Watches
    Dont know the reset code or anything about home security alarm sy
    need to know brand name of system. IE Ademco, bosch, DS, it will be on the inside of the alarm panel.
    Apr 23, 2009 | Electrical Supplies
    System goes on at odd times
    yuo have to walk through every day program in stat and check you more then likley missed a day when you programmed it
    Feb 20, 2009 | Heating & Cooling
    Optima house alarm
    after a power cut alarm goes back to factory setting 0123. you need to use this code to re program alarm
    Jul 31, 2008 | Computers & Internet
    Locks & Locksmithing Logo
    Top Locks & Locksmithing Experts
    ray gallant
    Tom Chichester
    Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
