Question about Maxdata Computers & Internet
Mainboard fault
  • Daniel Phillips Apr 01, 2014
    more information needed, what you are doing when the problem occurs, error messages etc
  • 26 Answers
We need more information. Please list your problems and all your computer information. We need very specific detailed questions in order to help you properly
Posted on Apr 01, 2014
I HAVE A MSI MS-7131 M/B PROBLEM IS NO DISPLAY,PROCESSOR HEATING NORMALY,RAM AND CLOCK ON B16 ARE OK .NOT RESET SIGNAL ON A15,WHICH IS GENERATING RESET SIGNAL AND HOW TO SOLVE THIS
Hello here is some info about the mainboard:
http://www.motherboards.org/mobot/motherboards_d/MSI/915GLM-V%2B%2528MS-7131%2529/
More info and drivers visit the MSI homepage.
The fault could be the ram module ( wrong mhz size )
The ram module must be DDR ram, other type of ram will not fit the mainboard.
The mainboard does not support more than 2gb of ram, if more insertet the mainboard will not boot up ( no display ) and maybe a beep code will come when you try to boot.
The fault could also be the power supply, or a intenal fault on the mainboard, maybe bad capacitors or the graphic chip is burned.
Try to boot with only one ram module, and try also with another power supply you know is working.
Try also to reset the bios by removing the cmos battery for like 10 min.
The power cord must be disconnected when you do this.
Also try with a intenal AGP graphic card.
Hope you get it running
Jul 31, 2013 | Computers & Internet
Gigabyte ga946GMX-s2 sometime power on sometime not
Hello the mainboards homepage is here:
http://www.gigabyte.com/products/product-page.aspx?pid=2550#dl
Try to renew the power supply, and check all the connections on the mainboard, for any loose cables.
The fault could also be a ram module failing.
Or the power button.
Any beep codes when, it not powers on ??
Try also to download the manual.
Please take antistatic precautions when working on the mainboard.
Good luck
Jan 28, 2013 | Computers & Internet
Need large, clear diagram for MSI motherboard, type ms 7613-iona gl8e
Hello this mainboard belongs to the HP/ COMPAQ support:
https://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c02014355&lc=en&product=4262655
The manual:
https://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&docname=c02014355&lc=en&product=4262655&
You can`t find anything at the msi support site.
Do you get any picture (blue screen of death) ???
Any beep sound ???
This fault could be: ram failure,harddrive,graphic card,cpu.
Or sinply mainboard is dead.
It`s always difficult to do fault finding on a mainboard.
Many thing can go wrong.
And it will sometimes cost more
than a new mainboard or pc to solve the problem.
Ask a qualified repair shop (hp support) about known issues
with this mainboard.
Good luck
Nov 25, 2012 | MSI Computers & Internet
G31MX-K 2.0 ram
Hello the mainboard homepage is here:
http://www.foxconnchannel.com/ProductDetail.aspx?T=motherboard&U=en-us0000419
From here you can download a manual if you don`t have it.
If you have insertet a wrong ram module the pc will not boot.
And then a beeb code will appear.
But i think you have a defect ram module.
Your mainboard supports:
Dual channel DDR2 800/667 x 2 DIMMs, Max 4GB
That means you can not add more than 4 gb of ram.
It could be the fault if you have added more than that.
The fault could also be overheating of the cpu.
Remove the cooling fan and clean it for old cooling paste
Then add new cooling paste and mount the fan again.
If you are not familiar with that job let a expert do it.
The fault could also be the harddrive.
Good luck
Oct 29, 2012 | Foxconn G31MX-K 2.0 Lga 775 Motherboard
My MSI computer won't startup. It has an
It appears that you have only checked the power supply and the on/off button. There are many reasons a computer won't start.
These are only two. Have you "stripped down" the system? This means removing everything but the CPU, Memory, and video card. If it starts with only these things attached, then you can rule out the mainboard, memory, and video.
Next remove the memory. If it starts but you get memory error beeps, then it could be one of the memory modules.
After all that, you can then figure it's the mainboard or the CPU.
As for circuit diagram, I would think these would be very hard to find.
Jun 18, 2011 | MSI Computers & Internet
Lg tv has no picture nor sound just the backlite, the remote control works, because when I press any key the power light flashes
The sound and video signal on LGs are driven directly from the mainboard which suggests a faulty mainboard..If the channels were tuned in previously to the fault then this solution is futher backed up. If the channels were not tuned in prior to the fault then you wont get any sound until the channels are tuned in, and it would not be possible to see the menu to do so. The prescence of REMCON pulses suggest the PSU is delivering power to the mainboard..Id go with a new mainboard but providing the channels are tuned in ok with no sound.
Oct 17, 2009 | LG Televison & Video
Asus mainboard p5gd1 - fm/s motherboard, giving bios fault d0 or d4 Need ot know the bios type and codes list
Are you by chance using a mainboard diagnostic card? Asus use beep codes to indicate different bios issues. I'm almost certain it is the Award Bios used on their boards.
Oct 17, 2009 | ASUS P5GD1 Motherboard
MY COMPUTER SCREEN LOOKS LIKE IT WENT THROUGH A SHREADER
Sounds like either a driver problem or a defective graphics chip. Is this a new or older notebook? Determine your graphics manufacturer and try downloading their latest driver for your video graphics software or hardware driver.
If it is a defective chip, you will need to contact the notebook manufacturer to get repair service. If the notebook is less than a year old you should be able to get the service for free. If you have an extended warranty then it should cover your situation.
Hope this helps.
Sep 04, 2009 | Compaq Presario Notebook
Shuts off red lights flashing
Hi there
If the temp light is showing from startup and doesn't fire up at all - you might be facing a Mainboard fault.This will need either repair or replacement.Must warn you that the replacement of a Mainboard is very expensive.
thank u
rate me!!
Aug 24, 2009 | Sanyo Office Equipment & Supplies
Mitsubishi sl2u projector fault
Hi there
Apr 02, 2008 | Office Equipment & Supplies
Computers & Internet Logo
20 people viewed this question
Top Maxdata Computers & Internet Experts
Willem.
Willem.
tim brauer
tim brauer
AnyMHz.com
AnyMHz.com
Are you a Maxdata Computer and Internet Expert? Answer questions, earn points and help others
