Question about LG Dare VX9700 Cell Phone
After dialing via Contact, screen will go blank
I've had my Dare about a month & this started happening.
I dial out via a Contact & after the call connects, the screen intermittently goes blank. It won't come back, with me touching the screen, or touching any of the buttons on the side.
Telu exchanged the phone for me, but the replacement one is also now doing this.
I'm suspecting a settings problems, but can't figure out what to change.
It's especially a problem when I'm dialing a call that has a vocie-mail or numbers(you know, press 1, press 2, etc)as, since the sceeen is blank, I can't do that.
Might it be to do with the phone's acceleratometer(ie-- if I dial with the phone vertical, horizontal, etc ??)
Hitting the lower right button simply ends the call -- it doesn't bring up the dial pad/speaker screen menu....
Any idea what the problem is, or what I've set wrong ??
  • 3 Answers
Try taking the battery out wait a couple minutes then put it back in. after this process it should work normaly
Posted on Jun 15, 2009
My phones are going blank on screen after I dial out or while dialing.
While the screen goes blank, does it drop the call? Are the handsets fully charged, or are they on the charging dock whenever they are not in use?
The batteries may need to be replaced. Bad batteries can in some cases cause the phone features to not fully work. They are located in the back, bottom of the handset.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mike_005777b2fc6bfc30
Nov 21, 2014 | Uniden DECT15803 3 handsets and Chargers -...
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
No dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Sep 04, 2009 | Vtech Lands Phones
My compaq laptop refuses to connect to dial-up & braodband (LAN)
please update ur driver immediately or contact vendor
Jul 24, 2009 | Computers & Internet
My wifes laptop is trying to use DUN instead of network cable
Open up Internet Options (from the Tools menu in IE or right-clicking the desktop icon and selecting Properties, or through the Control Panel). On the Connections tab, select 'Never dial a connection.' When you want to connect to your ISP you will be required to manually start the dial-up connection.
Apr 14, 2009 | Computers & Internet
Screen turns off after i dial number then screen shuts off
Whoever your cell phone provider is, you need to contact them and notify them of this problem. This is a common problem with Touch Screen phones. Call them usually by dialing *611 from your mobile phone and ask for a replacement phone. Their own tech team may try to do a master reset on the phone, but to me it sounds like there is an internal issue. Seeing as you have problems calling from your touch screen you may want to email them or use a landline phone to reach someone. If you need any help let me know!
Mar 18, 2009 | LG Dare VX9700 Cell Phone
Setting time and date
From the manual:
1. Press the MENU button to open the menu.
2. Turn the SET dial to select [SYSTEM] and press the
SET dial.
3. Turn the SET dial to select [T.ZONE/DST] and press
the SET dial.
4. Turn the SET dial to select the setting option that represents your time zone and press the SET dial. To adjust for daylight saving time, select the time zone with the * next to the area.
5. Turn the SET dial to select [D/TIME SET] and press
the SET dial. The year display starts to flash.
6. Turn the SET dial to select the year, and press the
SET dial.
• The next part of the display starts flashing.
• Set the month, day, hours and minutes in the same way.
7. Press the MENU button to close the menu and to
start the clock.
Jan 15, 2009 | Canon Video Cameras
Sony VX-2100 unresponsive dials
it can happen if any of the setting switch is struck or short....
Dec 11, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
LG Dare VX9700  Cell Phone Logo
138 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
