Question about Food Mixers
Sunbeam Planetary Mixmaster MX7900 has fallen off
Sunbeam Planetary Mixmaster MX7900 has fallen off the kitchen bench Works but top plastic cover has shifted and sounds like motor fan rubbing against cover How can I get the top cover off to reseat this Suspected one of the screw fix points on the top cover has broken Any ideas
How to disassemble a sunbeam 2370 mixer
To disassemble a sunbeam mixmaster 2370, find four plastic snappers arranged at 1, 5, 7 and 11 o'clock around the front circle of vents. They can be seen with the help of a good flashlight. un-snap them and the top and bottom shells will separate. From there on, it is clips and screws. Good luck!
Nov 28, 2013 | Sunbeam 2370 MixMaster Series Stand Mixer
Worn out beater gears
Soft plastic gears inside the machine from what I've read around the web, sorry but you'll need a complete new mixer.
I've had one apart to see just how fixable it might be, and it took me about 30 minutes to get the motor and gearbox into a position where they could be looked at. The gearbox had 2 stainless steel clips holding the top cover on and I didn't want to pry at those in case the cover snapped.
Not a lot gained from looking inside it sadly.
Apr 12, 2013 | Sunbeam 2346 Heritage MixMaster Series...
Mixmaster motor won't spin. Leads from circuit board to motor read 119 volts at the motor. voltage does not vary when speed knob is rotated but does turn off & on. 275 W sunbeam mixmaster, white...
so far I determined the thermal fuse had blown. I jumped around it but can get replacement. Now the motor runs full speed when turned on. I suspect the pot turned by the speed knob is bad. Having trouble locating a replacement circuit board.
Jan 19, 2010 | Sunbeam 2366 MixMaster Series Hand/Stand...
Sunbeam Mixmaster 250W tilt stuck
Here are the steps repeated from bove with photos
  1. Unplug machine from power
  2. Pry of the dome shaped cover at the back - putting a flathead screwdriver under it witll work, note the plastic prongs on the inside of it below10_23_2012_11_25_02_pm.jpg
  3. Get a couple of screwdrivers to hold out th e prongs on the speed control ring and then prise it of by intserting a srewdiver in front of the ring
  5. Now you can tighten the nut on the vertical bolt at the lower inside of the mixer using a small screwdriver to push the nut around till it is tight and then add some loctite (or nail polish) to stop it coming undone.
  7. The tilt mechanism should now work. To reassemble align the off indicator on the top of the machine with the OFF on the speed control ring and push it back on. Push on the dome shaped cover and you are finished.
Jun 02, 2009 | Sunbeam 2353 Stand Mixer
Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
Dec 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Beater keeps falling out. The plastic thing at the top of the beater inside the mixer needs to be replaced. Where can I get the part?
Sunbeam 2366 stand mixer -- Front view: mixer-0-small.JPG -- 0d345a3.jpg-- image of the "beater clip": mixer-1-small.JPG -- notice the wear on the plastic clip --8982711.jpg -- image of the "modified" beater: mixer-2-small.JPG - I took a paper clip an wound very tightly to the smallest diameter (notice it covers the entire section to prevent slippage) and then put one wrap around the "top knot" to increase diameter --d67ddea.jpg -- image of the back of the front cover: mixer-3-small.JPG - notice the broken clip at the top. I used a wide scrapper blade to separate the cover from the main body. 3297c2c.jpg----
Oct 16, 2008 | Sunbeam 2366 MixMaster Series Hand/Stand...
Regarding the Sunbeam Mixmaster (model 2346): How do I remove the front cover of the mixer so that I may reallign or replace the beater gears?
Pry the beater release button out with a screwdriver. There are two screws underneath it and one under the motor housing between the the beater holes. This will allow you to remove the chrome front cover, but not the motor and drive assembly. Getting to the part that contains the gears requires complete disassembly of the mixer. It is not designed for service, and requires patience and a variety of tools to disassemble.
It has a metal worm gear and plastic drive gears. If the beaters are out of alignment, then one or both of the plastic gears are stripped and the mixer is junk. Repair plus shipping costs equals the price of a new mixer. This is the weak point of these mixers and a fundamental flaw in an otherwise robust and sturdy design. It is definitly not the same mixer *********** bought 30 years ago.
Jul 18, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Food Mixers Logo
62 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
