Question about Ariston Technologies Washing Machines
Ariston washing machine makes spinning sound but does not spin
    New Friend:
    Problem Solver:
  • 11 Answers
Check drive belt on motor is not broken
Posted on Apr 06, 2014
natengel
  • 19 Answers
SOURCE: washing machine will not spin makes loud humming noise
motor coupling needs to be replaced
Posted on Nov 05, 2007
SOURCE: Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Posted on Feb 17, 2008
  • 1462 Answers
SOURCE: Ariston Washer Dryer AML 105
i know it sounds simple but have you checked the filter and also check for foreign objects in the pump impellor
Posted on Jun 26, 2008
barkencoa
  • 3463 Answers
SOURCE: Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Posted on Jul 24, 2009
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
Why are my clothes dripping wet after the spin cycle I have a ariston front loader avxl129
sounds like the pump could be unable to get the water out after the wash. check the door into the pump, at the bottom front of your machine
Aug 12, 2014 | Ariston Technologies Washing Machines
Water not emptying from the machine,
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Ariston Technologies Ariston AWD12 Front...
I have a noisy ariston front loader washing machine and
From the front of the washer, spin the drum by hand, and if it feels rough, or is noisy, or rumbling, then the main drum bearings have failed..
If no noise, then problem is elsewhwere.
Hope this helps.
Jan 27, 2010 | Ariston Technologies AW149NA Washer
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Ariston front loading washing washing
Believe it or not.....its almost always the cloths ( heavy blankets) that one places inside.
TRY:: In the spin cycle if the load is unbalanced the TUB will rock and make that "loose drum out of alignment" noise. STOP the machine and open the door ( IF IT IS A TOP LOADER ) realign the cloths (heavy or more then one blanket) so that it is EVENLY spaced through out the tub.Start the machine again.If it does it again, stop the machine and REALIGN the cloths (blanket !!) again.
p.s. there is a simpler way of doing it but I don't want you to loose your hand in the process.
Aug 31, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
Washing machine making crackling noise when spinning
check for some loose items underneath the unit. washing machines normally reverses its rotation when spinning. check if mechanical solenoids pulls the right levers as it starts to spin....
Feb 12, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Washing Machines Logo
42 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
