Question about HP LaserJet Pro M1217nfw MFP - multifunction fax / copier / printer / scanner B/W
Used supply in use error
How do i remove this error
  • HP Master
  • 783 Answers
I found an article for another Laserjet that has the error code within its matrix:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c01931013
The only available information is that the cartridge that was inserted, and is being used, has experienced prior use. This error is to warn you of this circumstance, as used supplies can damage your product. Certain safeguards may not be available or may no longer be active with used supplies.Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For HP Support
Posted on Apr 01, 2014
Cartridge error 1203
The 1203 error indicates either a communication failure between one of your cartridges and your printer or a short in one of the cartridges. Please follow the steps below to fix the problem:
1. Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on. Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3. Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return?
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5. Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return?
Yes: Continue to Cleaning the Cartridge Contacts, and then repeat steps 4 and 5 of this procedure. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7. Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return?
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
1. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
2. Remove the cartridges. Clean the cartridge contacts (How to Clean the Print Cartridge Nozzles and Contacts Manually).
Source: 1203 Error Message on the Lexmark X7170 All-In-One
Oct 08, 2011 | Lexmark X7170 All-In-One InkJet Printer
My Lexmark printer when turn on it makes noise and it can not print with a error code 2200
Hello thanks for using Fixya
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Step1.
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Yes:
Continue to step 2.
No:
Attempt a test scan. If the error message does not reappear, the error is resolved.
Step2. Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.Did the error message return?
Yes:
No:
Continue to step 3.
Step3: Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes:
Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No:
Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Step4: Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes:
Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No:
Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Feb 11, 2011 | Lexmark P4350 All-In-One InkJet Printer
Show error2200
1.Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved. Source(s): http://support.lexmark.com/index?page=co…
Apr 23, 2010 | Lexmark P4350 All-In-One InkJet Printer
What is error #2200
Printer Reset
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: contact Dell.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, contact Dell.
No: Install the color cartridge. If the printer fails, contact Dell. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Mar 23, 2010 | Dell 962 Photo All-In-One InkJet Printer
I get the error 2200 message everytime I try to send a fax
Hello there:
this is a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message2.gif.
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.
StepAction1
No: Attempt a test scan. If the error message does not reappear, the error is resolved.2
Power off the AIO and remove the power supply from the back of theunit. Open the scanner cover. Check the scanner glass for cracks andthe scanner casing for cracks. Close the scanner lid. Open the topcover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
No: Continue to step 3.3
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Insert the colorcartridge, close the top cover, reinsert the power supply, and power onthe AIO.
Yes: Repeat step 3 with another color cartridge. If the printer2.gif fails again, continue to step 4.
No: Repeat step 3and install the black/photo cartridge. If both cartridges areinstalled, attempt a test scan. If the error message does not reappear,the error is resolved.4
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Remove the color cartridgeand insert the black/photo cartridge. Then close the top cover,reinsert the power supply, and power the AIO on.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark.If the error message does not appear with both cartridges installed,attempt a test scan. If the error message does not reappear, the erroris resolved.
Nov 10, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
What does error code 2200 mean?
Printer Reset
Step Action 1
No: Attempt a test scan. If the error message does not reappear, the error is resolved. 2
No: Continue to step 3. 3
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved. 4
Sep 25, 2009 | Lexmark X7170 All-In-One InkJet Printer
How can the Error 2200 be fixed? Lexmark X7170
Power off the All-In-One (AIO) off and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover and check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
No: Repeat step 3 and install the black / photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black / photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black / photo cartridge.
Mar 31, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error 2200 lexmark 6250.
hey ,
Follow the steps :-
Step Action
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved...
Nov 15, 2008 | Lexmark X7170 All-In-One InkJet Printer
Error 2200
Step Action
1 Power off the printer and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the printer on.
2 Power off the printer and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the printer on.
3 Power off the printer and remove the power supply from the back of the unit. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the printer.
4 Power off the printer and remove the power supply from the back of the unit. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the printer on.
Sep 16, 2008 | Lexmark P4350 All-In-One InkJet Printer
What does error 2200 mean
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.Step Action
Mar 07, 2008 | Lexmark P4350 All-In-One InkJet Printer
HP LaserJet Pro M1217nfw MFP - multifunction  fax / copier / printer / scanner   B/W Logo
143 people viewed this question
Seeker5211
Seeker5211
