Question about Medion MD 30169 22 in. LCD TV
Ayl400207 Power short
How do I reset lift gate on 2004 lincoln navigator. It doesn't open or close anymore with the remote
Maybe your key fob needs a new battery !
Power Liftgate Initialization
NOTE:If the power liftgate system is turned OFF in the message center, the system cannot be activated with any switches or with the liftgate handle. The system will need to be turned ON for any power operation to occur.
NOTE:The power liftgate may not operate under the following conditions:
  • a low voltage or dead battery.
  • a disconnected battery
  • a power liftgate that has been left open for more than six hours.
  • a power liftgate that has been manually closed and left ajar.
If any of these conditions has occurred, the power liftgate must be reset.
  1. Manually close and fully latch the power liftgate.
  1. NOTE:If the power liftgate does not open during this step, refer to the symptom chart to diagnose the power liftgate for no operation.
    Power open the power liftgate by using the keyfob or overhead console switch.
  1. Once the power liftgate is fully open, close the power liftgate by using the keyfob or overhead console switch.
    This system can also set DTC'S
  2. POWER LIFTGATE MODULE DIAGNOSTIC TROUBLE CODE (DTC) INDEX (BODY CLOSURES) 501-03 Body Closures 2004 Expedition/Navigator DIAGNOSIS AND TESTING Procedure revision date: 08/23/2004
    Power Liftgate Module Diagnostic Trouble Code (DTC) Index
    DTC Description Source Action B1342 ECU Is Defective Power Liftgate Module INSTALL a new power liftgate module. REFER to Power Liftgate Modulein this section. B2477 Module Configuration Failure Power Liftgate Module REFER to Section 418-01. B2522 Vbatt1 Circuit Failure Power Liftgate Module GO to Pinpoint Test B. B2552 Vbatt2 Circuit Open Power Liftgate Module GO to Pinpoint Test B. B2698 Vbatt2 Circuit Failure Power Liftgate Module GO to Pinpoint Test B. B2699 Left Pinch Strip Open Or Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2700 Right Pinch Strip Open Or Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2701 Left Pinch Strip Stuck Active Power Liftgate Module GO to Pinpoint Test B. B2702 Right Pinch Strip Stuck Active Power Liftgate Module GO to Pinpoint Test B. B2703 Open/Close Switch Stuck Active Power Liftgate Module GO to Pinpoint Test B. B2704 Optical Sensor Power Short To Ground Power Liftgate Module GO to Pinpoint Test B. B2705 Optical Sensor 1 Input Not Active During Powered Gate Movement Power Liftgate Module GO to Pinpoint Test B. B2706 Optical Sensor 2 Input Not Active During Powered Gate Movement Power Liftgate Module GO to Pinpoint Test B. B2709 Gate Open Output Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2710 Gate Close Output Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2711 Gate Open Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2712 Gate Close Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2713 Unlatch Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2714 Uncinch Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2715 Cinch Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2718 Gate Ajar Output Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2721 Gate Ajar Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2722 Open/Close Switch Active During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2723 Glass Position Switch Active During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2724 Forkbolt Switch Invalid During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2725 Detent Switch Invalid During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2726 Home Switch Invalid During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2819 Gate Motor Circuit Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2820 Gate Motor Circuit Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2821 Cincher Motor/Unlatch Actuator Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2822 Cincher Motor/Unlatch Actuator Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2825 Movement Ceased Due To Excess Speed Deviation Power Liftgate Module GO to Pinpoint Test B. B2903 Chime Output Circuit Short To Battery Power Liftgate Module/ Liftgate Chime Module GO to Pinpoint Test C. C1935 Chime Circuit Failure Power Liftgate Module/ Liftgate Chime Module GO to Pinpoint Test C. U1950 UBP Communication BUS Fault UBP Communi cation REFER to Section 418-00. U2338 Invalid ACM Message Data Power Liftgate Module
Feb 05, 2015 | Lincoln Cars & Trucks
Tip
Ducati Fault Codes
Engine Fault Codes - Ducati 749/999
To see the fault codes, with the ignition off hold both dash buttons down and turn ignition on.
1.1 TPS Disconnected
1.2 TPS short circuit to earth
2.1 Pressure Sensor short circuit to power supply
2.2 Pressure Sensor shorted to earth
3.1 Water Temp Sensor shorted to power supply
3.2 Water Temp Sensor shorted to earth
4.1 Air Temp Sensor shorted to power supply
4.2 Air Temp Sensor Shorted to earth
5.1 Battery Hi
5.2 Battery Low
10.1 Hor. Coil shorted to power supply
10.2 Hor. Coil shorted to earth
11.1 Ver. Coil shorted to power supply
11.2 Ver. Coil shorted to earth
12.1 Inj1 shorted to power supply
12.2 Inj1 shorted to earth
13.1 Inj2 shorted to power supply
13.2 Inj2 shorted to earth
14.1 Inj3 shorted to power supply
14.2 Inj3 shorted to earth
15.1 Inj4 shorted to power supply
15.2 Inj4 shorted to earth
16.0 Pump Relay
17.1 LH Fan shorted to power supply
17.2 LH Fan shorted to earth
18.1 RH Fan shorted to power supply
18.2 RH Fan shorted to earth
19.1 Starter Solenoid shorted to power supply
19.2 Starter Solenoid shorted to earth
30.0 ROM/Eprom error
34.0 Signal Panel Sensor
36.0 Speed sensor
37.0 Immobiliser (transponder)
37.1 Immobiliser (antenna)
37.2 Immobiliser (instrument panel serial driver)
37.3 Immobiliser (serial cable disconnected)
37.4 Immobiliser (ccm serial drive)
37.5 Immobiliser (key not recognised)
37.6 Immobiliser (ccm program)
38.0 Can Line error
Source http://moto-files.weebly.com/ducati-fault-codes.html
on Dec 20, 2016 | Motorcycles
999 injection relay tick continuously when turn to on
found on the net
Listed below are the Ducati error codes for the 999/749 series which are very handy to know...
If your stead decides to create an error and then flashes her yellow warning strobe (the EOBD light) then follow these steps....
1) Turn the ignition to 'OFF' (Whilst stationary that is.... )
2) Depress and hold the left hand instrument panel button
3) Turn the ignition to 'ON' whilst still depressing the left hand button
4) You should then see the error codes displayed
5) Make a mental note of the codes and cross reference with the following list.........
ERROR CODES
1.1 = Throttle Position Sensor (TPS) Disconnected
1.2 = Throttle Position Sensor (TPS) short circuit to earth
2.1 = Pressure Sensor short circuit to power supply
2.2 = Pressure Sensor shorted to earth
3.1 = Water Temp Sensor shorted to power supply
3.2 = Water Temp Sensor shorted to earth
4.1 = Air Temp Sensor shorted to power supply
4.2 = Air Temp Sensor Shorted to earth
5.1 = Battery Hi
5.2 = Battery Lo
10.1 = Horizontal Coil shorted to power supply
10.2 = Horizontal Coil shorted to earth
11.1 = Vertical Coil shorted to power supply
11.2 = Vertical Coil shorted to earth
12.1 = Inj1 shorted to power supply
12.2 = Inj1 shorted to earth
13.1 = Inj2 shorted to power supply
13.2 = Inj2 shorted to earth
14.1 = Inj3 shorted to to power supply
14.2 = Inj3 shorted to earth
15.1 = Inj4 shorted to powersupply
15.2 = Inj4 shorted to earth
16.0 = Pump Relay
17.1 = L/H Fan shorted to power supply
17.2 = L/H Fan shorted to earth
18.1 = R/H Fan shorted to power supply
18.2 = R/H Fan shorted to earth
19.1 = Starter Solenoid shorted to power supply
19.2 = Starter Solenoid shorted to earth
30.0 = ROM/Eprom error
34.0 = Signal Panel Sensor
36.0 = Speed sensor
37.0 = Immobiliser (transponder)
37.1 = Immobiliser (antenna)
37.2 = Immobiliser (instrument panel serial driver)
37.3 = Immobiliser (serial cable disconnected)
37.4 = Immobiliser (ccm serial drive)
37.5 = Immobiliser (key not recognised)
37.6 = Can Line error
__________________
May 17, 2014 | 2003 Ducati 999
As soon as tit went to the baking process it trip the power
you have a short circuit : God bless you
test a) door switch b) power cord c) diode power d) high capacitor e) magnetron f) thermall short a g) control board in short h) Transformer in short i)fan motor shorta5842f2f-6344-411f-a460-cd95076f5e60.gif
Oct 25, 2013 | Microwave Ovens
What is the problem when you troubleshoots your computer and you unplug all peripherals except the CPU, motherbaord and the power supply was left but still has a strange beep
Check all data and power leads connecting to motherboard.
start up beeping sounds
1 short beep : Normal POST - system is ok
2 short beeps : POST Error - error code shown on screen
No beep : Power supply or system board problem
Continuous beep: Power supply, system board, or keyboard problem
Repeating short beeps: Power supply or system board problem
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
http://www.pchell.com/hardware/beepcodes.shtml
Nov 23, 2012 | Computers & Internet
Any help for beeping acer laptop when opening..thanks
g'day!
i would like to know how many and the kinds of beeps? there are what they call beep codes which indicates what kind of problem the your laptop is experiencing: here are the common ones:
0 beep = no power, loose card, short
1 short beep = normal,POST (Power On Self Test), your computer is ok
2 short beeps = POST error, review screen for error code.
continuous beeps = no power, loose card, short
repeating short beeps = no power, loose card, short
1 long, 1 short beeps = motherboard issue
1 long, 2 short beeps = video issue
1 long, 3 short beeps = video display circuitry
three long beeps = keyboard/keyboard card error
one beep, blank, incorrect display = video display circuitry
aside from the 1 short beeps, you need to take your laptop to a technician to have it looked at.
cheers mate!
jelo a.
Aug 21, 2011 | Computers & Internet
My rca tv (model #42LA45RQ) has sound but i do not have a picture, the screen is black
After having seen a few of those in-house and having developed what we consider sufficient expertise we now offer a repair service for the power/inverter board AYL400207.
See the following for details or search for AYL400207 at our site:
http://blog.coppelltvrepair.com/2012/07/rca-42la45rq-no-picture-no-backlight.html
Hope this helps!
bobby @ coppell tv repair
May 19, 2011 | Televison & Video
2000 Ram 1500 4x4 "no bus"
All the modules are connected together to communicate with each other via the PCI bus. It is possible that one of the modules is pulling the bus down. If the vehicle won't start it could be any one of the modules. It will be a process of elimination to find the faulty one by disconnecting them one at a time.
Apr 22, 2009 | 1998 Dodge Ram 1500 4WD
4 seconds long beep
I think that either you have a bad power supply or it is not connected properly. I suppose it could also not be supplying enough power.
Try disconnecting all of the connections to the Motherboard and reconnecting them. Make sure they seat properly. Try a new power supply. You can get a good one from Newegg.com
Jan 26, 2008 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
Medion MD 30169 22 in. LCD TV Logo
42 people viewed this question
Top Medion Televison & Video Experts
Raj Patel
Electro Med Services...
Andrew Taylor
Andrew Taylor
Are you a Medion Televison and Video Expert? Answer questions, earn points and help others
