Question about Sub-Zero Refrigerators
Sub Zero 650S 3 Shutting Down/Tripping
Compressors for freezer and refrigerator both turn on, and there is power at the plug up by the compressors. Once I adjust the temp to lower it in the case, they unit will trip and shut down completely, lights, compressors, display. I push the On/Off button and it resets it and comes on right away but only will run for a little while longer and does the same thing. No error codes or anything, it just shuts down. Seems like the board gets overloaded and trips, is this correct?
  • Sub-Zero Master
  • 842 Answers
According to your information you gave you either have an extended circuit (electrical) or a short/weak connection in the unit. If you can get to the outlet for the unit, try another outlet (different circuit would be better) this would rule out the electrical issue, either the unit or the power supply to the unit could be the issue. If you can you might want to call a subzero tech to look at this. This units main power supply into the unit is located in front on the freezer compressor, if you have a dark or blackened molex connection you would have a short there. Try the relocation of power first and see were the issue can be isolated to supply or unit.
Good luck
Posted on Apr 02, 2014
aborcass
  • 2651 Answers
SOURCE: Refridgerator and freezer wont get cold
sounds like a bad compressor, or at least the start device plugging in to the compressor has gone bad,
Posted on Mar 15, 2009
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
robotek
  • 1512 Answers
SOURCE: suddenly tripped off house
Hi akula, 200 ks to a fridgie, LG appliance, you must be in Australia;) Is it the earth leakage circuit breaker operating. If so, then you have a leakage problem to earth from the heater pad(not quite sure what that is, but this problem will need to be repaired. Am doing some research to see if there is anything that can be done without just getting a new fridge. Back to you soon.
regards
Graeme
Posted on Mar 21, 2008
  • 151 Answers
SOURCE: sub-zero 650 freezer gets too cold (-18). freezer
sounds like it could be a bad thermostat on the unit.
Posted on Dec 26, 2009
tbreeze47
  • 3083 Answers
SOURCE: Sub-Zero Model 690 S Refrigerator
The following blog may be of help to you, and suggests that thermisters may be the problem:
http://www.applianceblog.com/mainforums/refrigerators-freezers/3937-sub-zero-model-690-refrigerator.html
This makes sense, especially since it's your last error code.
If the unit has a damper, it could be frozen or stuck, but that's the only other thing I can think of to check.
Good luck, and hope this helps.
Posted on Nov 27, 2010
I have a Sub Zero 650. The fan on top runs all the time. The temperature inside both Freezer and Fridge are fine and will respond to the changes I do to the settings. The fridge had been off for a move and...
If either compressor is running the fan is always on to cool both compressors. As they cycle it is possible the both compressor cycle at the same time and the fan turns off. But it is rare to see this happen. So yes the fans for the compressor does run at the time. I hope this helps, good luck
Jul 30, 2013 | Sub-Zero 650 / O Bottom Freezer...
My refrigerator is warm 72 and my freeze is 00. how to fix it.
You have to remember that sub zero has two independent compressors and evaporators so the freezer is fine. Focus on the fridge part. Here are some things you want to look at.
1) When you open the door, press the light switch and the fan switch, Does the fan run, it should.
2) Take the grate down that covers the compressors. The fridge is usually on the right as your looking at it. Is it running, hot or cold. If its running and hot, that's normal. If its hot and not running, you can tell by if its vibrating, you may have to turn the freezer off to prevent outside vibration. If its not running that means you more than likely have a bad compressor. If its cold and the fan inside didn't come on then the thermostat is bad inside the machine.
Jun 05, 2012 | Sub-Zero 611 / O Bottom Freezer...
I have sub zero 642 and my techinician says that I need a ice make valve replacement. He says it costs $495, does that seem accurate?
Sub-Zero a hallowed name in refrigeration, and the 642 side-by-side refrigerator/freezer unit is a landmark Yeah, it's that impressive. Dual refrigeration uses two compressors and three evaporators, I can tell you to never expect less than $300 for calling anyone to your home!
Aug 10, 2011 | Sub-Zero 642
Sub Zero 642 started humming when the compressor turns on
check your evaporator and, condenser fans and, lube them with machine oil one of the back ones is stuck
I would never get rid of my Sub Zero they are the best made and, I service all makes of refrigerators good for you; buying the best!
Apr 30, 2009 | Sub-Zero 642
Fab32 ps4 smeg
Is the freezer compressor running? The sub zero's have dual compressors, maybe one failed. How about the condensor coil, is it clean?
Dec 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
60 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
