Question about LG Washing Machines
Water leaking through air vent and estimated time remaining sticks during the rinse cycle
Here are the things that I have tried stopped using liquid softener use only HE liquid soap and less than 2 tablespoons removed drain hoses, checked, and cleaned them. made sure that the drain pipe in which hose empty is clog free and draining properly. replaced the mushroom (float) valve in the billow hose. replaced the drain pump. ran several loads of just whites, no soap, and 2/3 cup of bleach ran several loads of no clothes with vinegar. checked water inlet hoses and filters/screens. Ran QC Tests and everything seems normal but, I am not sure.
  • LG Master
  • 2,310 Answers
Run a tub clean cycle. No clothes. No soap. Just vinegar. About a cup.
Posted on May 03, 2017
5 Suggested Answers
  • 489 Answers
SOURCE: code OE water is not being drained out
You may have a broken or plugged drain pump and needs to be diagnosed by a qualified LG technician.
Posted on Jun 26, 2008
  • 311 Answers
SOURCE: Whirlpool Duet 9100 will not drain during regular wash cycle
I would assume that you are using HE detergent if not the pump could go into a suds lock. You may have a bad drain pump. The other options could be possibly a bad central control unit. (however these are very expensive) or possibly a door lock issue but usually you will get a door lock error.
Posted on Jan 13, 2010
  • 15935 Answers
SOURCE: Leaking // bleach/fabric softener dispener isnt emptying
Remove the dispenser cup and clean it. Be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
  • 41 Answers
SOURCE: Whirlpool Duet Sport Washer (model: wfw8300sw02)
puzzled here because there is always some water left in machine this is normal .you are quite right when you say that when you take the drain hose out of stand pipe and lower it water comes out but that is because of gravity .
Posted on Jun 07, 2011
Dryer Dry Time Appears to Jump or Stall During Auto Dry Cycles
The operation of dryers during the Auto Dry Cycles is based on the moisture content of the clothes as they cycle over the moisture sensor. At the start of the cycle, the default estimated time is displayed depending on the cycle selected. The moisture sensor feeds information to the control based on the "wetness' of the clothes during the first 5 minutes of the cycle. The control then calculates and display a new estimated time making the time appear to "jump".
Recalculation happens again based on the reduction in the "wetness" of the clothes when the Estimated Time Remaining is between 15 to 5 minutes. The control will extend the cycle and display the Estimated Time Remaining unchanged if it "sees" no significant reduction in the wetness level of the clothes. The dryer will run longer than initially projected and give the appearance that the displayed time has "stalled".
Clean the sensor bars for any films or dirt build up to make sure it sends accurate information to the control. Level the dryer front to back and side to side to ensure the clothing will tumble properly and making good and proper contact with the moisture sensor bars. Check the dryer vent duct for any restriction to ensure a good air flow as the operation of the Auto Dry Cycles is based primarily on the air flow condition.
It is highly recommended to clean the lint filter before every load and make sure the dryer is grounded at the wall plug.
on May 17, 2010 | Whirlpool WED9200SQ Electric Dryer
Fix washing machine
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 31, 2015 | Admiral Washing Machines
I have a front loading Kenmore washer and when i put liquid detergent and fabric softener, the liquid flows into the machine - should the detergent and fabric softerner remain in their compartements until...
Yes the detergent and softener will stay in the dispenser drawer until the correct time for them to be dispensed. The detergent is dispensed during the main wash cycle and the softener will not dispense until the rinse cycle
Jul 26, 2011 | Kenmore Washing Machines
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Kenmore washer leaking during rinse cycle
Your air vent in your drain line is stopped up in your plumbing. Your washer is fine.
Jul 16, 2009 | Whirlpool WTW6400SW Top Load Washer
Dishwasher leaks during rinse cycle
it sounds like you need to adjust the door latch so that the top of the door will close tighter. when in the rinse cycle try pushing door at top to see if leak stops. if that doesn't let you know something then you got me. you have changed all that i can think of. Good luck
May 01, 2009 | Dishwashers
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
Place a load of sorted clothes into the washer. See “Laundry
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
He4t - monthly bleach cleaning cycle
Washer Monthly Maintenance Procedure:
This cycle uses higher water volumes in combination with liquid chlorine bleach to thoroughly clean the inside of your washing machine.
  1. remove any clothing or items from washer
  2. CLOSE door (duh)
  3. open dispenser drawer and remove the detergent compartment and set aside. No laundry products will be added at this time. You will be required to add only liquid chlorine bleach at a later step.
  4. For Kenmore Elite HE products press a specific combo of buttons.
  • Select Rinse/Spin program
  • select low spin speed
  • select warm/cold water temp.
  • select 2nd rinse option
  • push the "end of cycle" signal button 4 times within 5 seconds to start the cycle
The machine will fill and run a short sensing cycle. This will take about 3 minutes.
Step 5
  1. The washer will provide 4 short tones. Check the: ESTIMATED TIME REMAINING display for the codes indicated below:
  • if "Ab" (add bleach) displayed in the estimated time remaining window (you'll hear 4 short tones) proceed to Step 6.
  • if "rL" (remove load) displayed in the Estimated Time Remaining window an error tone will sound. The door will unlock.
    -open the door and remove the items from the washer.
    -continue the cycle by pressing the START button.
    NOTE: The water in the unit will dispense for a moment, then the door will unlock, lock again, and then the cycle will continue with another check for items in the washer.
    The machine will fill and run a short cycle to determine whether any items have been left in the washer. This will take approx 3 minutes.
    the washer will repeat Step 5 until it can determine that there are NO items n the washer and will display "Ab" (add bleach).
6. Add liquid chlorine bleach.
  • If using the maintenance procedure for the first time, open the dispenser drawer and immediately add 1 cup liquid chlorine bleach to the Main Wash detergent compartment. The liquid bleach should immediately flow out of the dispenser.
  • If doing a monthly maintenance procedure, open the dispenser drawer and immediately add 1/3 cup bleach to the Main Wash detergent compartment. The liquid chlorine bleach should immediately flow out of the dispenser.
  • Water will be flowing into the dispenser drawer when the bleach is added ... this is normal.
  • Do not add any detergent to this cleaning cycle. Use of more than 1 cup of bleachw ill cause product damage over time.
7. Once the cleaning cycle has begun, allow the cycle to complete. An est cycle time will appear on the display.
8. After the cleaning cycle is complete, leave the door open, clightly to allow for better ventilation and drying of washer interior.
9. Replace the detergent compartment divider.
Feb 04, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washing Machines Logo
51 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
