Question about Alemite 585-B1 14.4 Volt Cordless Grease Gun
Need an alemite charger - Alemite 585-B1 14.4 Volt Cordless Grease Gun
My friends bro loaded a cartridge into my grease gun backwards. I'm now left with task of removing it and it's not cooperating at all.
no doubt and there is not secret to getting it out . have friend buy you a new gun and give him the one his brother ruined
Jul 20, 2016 | Professional Pistol Grip Grease Gun
For what Purpose Alemite Grease Pump is used?
The main function of Alemite Grease Pump is it reduces friction and increases the productivity. Alemite grease pump does is that it pumps a certain amount of grease into the perfect places where friction is produced because of the movement of machineries and its components; this particular pump not only pushes the right amount of grease, but also makes it show to push the grease at the right time.
Article source : http://www.fdjohnson.com/
Aug 21, 2014 | Lincoln Automotive Air Operated Grease...
How do grease pumps help in reducing friction ?
Alemite grease pump function is used to pump a certain amount of grease into the perfect places where friction is produced because of the movement of machineries and its components; this particular pump not only pushes the right amount of grease, but also makes it enough capable to push the grease at the right time. Article source
Jul 19, 2014 | Lincoln Lubrication 1293 Hand Operated...
How to load grease in it?
The model 1056S will accept the standard grease cartridge available at any parts store. I have to use a razor blade and cut off the metal pull tab end. Then push the cartridge into the cylinder from the top. The real trick is to guide the rubber seal into the cartridge; it can be done, I load mine this way. Use the little lock to hold off the long plunger, allow just enough to work with inorder to insert rubber seal into cartridge. Only after the rubber is in the cartridge, then screw on the bottom cap. Then release the long plunger rod. You noticed that the plunger rod will rotate out of the rubber seal assembly, rotate it so the rod can be pushed into the cylinder without pushing the rubber seals. The sping will push the rubber seal to ensure grease is mover to the top. Very powerful PSI, do not blow out the rubber cups around the zerk fittings. Good luck
Jul 05, 2014 | Alemite Lever Gun Model 1056s
Hyundai sonta we're is the grease fitting
Good Morning! If you remember years ago, all vehicles had grease fittings all over it. Then in the late 70's going into the 80's they were slowly removed. This didnt mean that the parts didnt need to be lubricated, only that the manufactures cut costs by taking the grease fitting out and meant more repair parts being sold. Eventhough there is no grease fitting, you can still lubricate this parts if it has a boot to protect it. Most equipment manufacturers (Alemite, Balcrank, Graco, Lincoln, Samson, etc) make a Injection needle, You can pick one up for less than $10 at Napa or any parts store. It is actually the same needle used for IV's with a grease fitting pressed on the end of it. You can snap it on your grease gun and insert the needle through your boot (including CV joint boots). Be careful NOT to over lubricate. Normally two or three strokes of the gun is enough. Dont pump so much that the boot bursts. Then you defeated your purpose. Hope this helps and good luck!
May 05, 2014 | Cars & Trucks
Drill for thread 3/4" NPTF
if you look at a drill index just go down three sizes
Dec 11, 2013 | 1958 1/8" NPTF Straight Grease 1ea
Greasing the arm vertically and horizontally
Remove the cover then apply grease to the moving area of the saw
Aug 25, 2012 | Craftsman Sears Radial Arm Saw Arm 815688...
Charger problem how to identify
Hi, to identify charger. You will need to test another charger on the cell phone and test that same charger on another phone to confirm if the charger is working.
Also after testing for the charger and and if the charger works, that means the charging port of the phone where the charger is been inserted is damaged.
It will need to be fixed.contact you local repair person for help.
Take care.
May 22, 2011 | Cell Phones
Alemite 585-B1 14.4 Volt Cordless Grease Gun Logo
Top Alemite Drills Experts
Are you an Alemite Drill Expert? Answer questions, earn points and help others
