Question about Vizio P42HD Television
Can you plug in an hdmi cable with some type of adaptor?
  • Demian Ahrendt
    Demian Ahrendt Apr 01, 2014
    Hi Laurie Suarez, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Plug it into what? There are many types of HDMI/other plugs for instance HDMI one end mini USB on other for cell phones and such.
  • Laurie Suarez
    Laurie Suarez Apr 01, 2014
    A friend gave me a chromecast but it requires an hdmi port and despite looking at the back panel, I see none. Is there any way around this?
  • 46 Answers
Depends on your television.
Laurie's answer might work if your television has a DVI jack but that isn't likely for a television. DVI Jacks are more commonly used on computer displays.
If your television does not have an HDMI plug, and only has those round RCA-style jacks, then you need an HDMI-to-Composite Adapter (http://www.amazon.com/gp/product/B00P7RL5C8). I have two of these (one each for a WiiU and a Samsung Blu-Ray Player) and they work just fine.
Posted on Oct 18, 2015
    New Friend:
HDMI Female to DVI Male Adapter is what the IT guys at work said would work
Posted on Apr 03, 2014
How do I connect tablet to tv
select on tv menu the hdmi source and the game is done
Mar 10, 2015 | Samsung Tab Tablets & eReaders
How do I connect my galaxy s5 to my Samsung flat screen tv which has usb,hdmi, av cable etc. ?? I am trying to watch videos off my phone from my gallery
This is easy. All you need is a HDMI adaptor for the S5 .you will find it on Amazon .when you get it plug in the usb into your you then plug a HDMI lead into the HDMI socket then get the lead for charging your phone and plug that into the usb socket on the adaptor then you plug the adaptor to the mains. . Don't forget to connect the other end of the HDMI Lead to the TV. I have one for my Galaxy S3. They do work but you have to get the right one for the phone . I don't know if the one for the S3 will be ok but it mighy work
Mar 02, 2015 | Samsung Televison & Video
Turn on ps3 i get no picture or sound then i cant turn it off i have to unplug it whats wrong with it?
  • Check your HDMI Cable
    HDMI is available in several versions. The PS3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PS3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
    The HDMI cable is not included with the PS3.
  • Cable adaptors (i.e., HDMI to DVI converters)
    If you are using an adaptor (i.e., HDMI to DVI converter), try bypassing this adaptor and connecting the HDMI cable directly into the display.
  • Check the adaptorTry an alternate cable
  • Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HDMI setup and/or equipment.
  • Some older HDTVs may have issues with the copy protection protocols (HDCP) causing the handshake not being communicated between the TV and the PS3. Try resetting the TV by turning the TV and PS3 off, then unplug the TV power cord from the outlet and plug it back in. Then turn your TV and PS3 back on and see if the picture appears.
  • Try using a different the HDMI Cable on the PS3.Make sure the HDMI Cable is free of any cuts, frays or other visible damage.
  • Try installing the PS3 to another TV or display (i.e., monitor).
  • Try using the HDMI Cable with a different PS3 system.
Aug 18, 2011 | Sony Playstation 3 (PS3) Console
Hi I am trying to connect a Dell Latitude E4310 computer to a HD Vizio TV. I know that I need a HDMI cable to plug into the TV But what should the other end be? or what adaptor do I use to connect with?
HDMI cables will have either HDMI or DVI on the other end to plug into a flatscreen tv. If you are trying to plug it into an older tv without HDMI or DVI, you will need an HDMI to whichever plug is available on your tv. http://www.amazon.com/GefenTV-HDMI-to-Composite-Scaler/dp/B0013LTNF8
Jun 28, 2011 | Computers & Internet
I have a Jazz HDV178 where does the adaptor plug in
The USB adapter gets plugged in the back. The HDMI cable gt plugged in under the flash (take off the HDMI cover)
Jun 12, 2009 | Jazz DV-179 Digital Camera
I have a phillips 26pf5520d/10 model number, ive connected a dvi cable and hdmi cable to my playstation 3 and tv, but i have no sound, please any ideas. many thanks steph
I'm assuming you mean you have HDMI coming out of the PS3 and going in to the DVI port on the back of the TV, via an adaptor or cable with a different connector on either end.
I have the same TV, you need a separate audio connection between ps3 and tv. HDMI can transmit audio and video but DVI (which is what the TV has) can only do video.
You'll need a 2 x phono female to 3.5mm jack male adaptor cable. like this one to make the audio connection.
you could also try this adaptor but its a bit big and therefore may not fit into the space available.
after getting an adaptor do this (keep your original setup the same)
1. Put the ps3 AV cable into the back of the ps3. 2. then connect the red and white plugs (ignore the yellow) from the ps3 AV into the adaptor (discussed above). 3. then connect the 3.5mm jack (from the adaptor) into the small audio port right next to the DVI port on the back of the TV (I believe its called 'DVI Audio')
I've not tried this and I don't have a ps3, yet, but in theory it should work, as long as the ps3 will send audio to the av output at the same time as to the hdmi output.
if it works, then post a response, i'd like to know for the future.
good luck
Aug 01, 2008 | Televison & Video
Ps3 doesnt connect to my computer monitor, how can i make it work?
Hey daashman,
According to information provided by the manufacturer, this particular Samsung model supports both VGA and DVI-type cable connections. The Playstation 3 however, does not currently support cables of either of these formats.
The good news is that there are ways around these limitations, typically in the form of a cable adaptor. Most models of the Playstation 3 should have an option for owners to use an HDMI cable to connect their TV or monitor, and many major electronic retailers often sell HDMI to DVI adaptors or adaptor cables of varying lengths.
If you're not quite sure what to look for, I would suggest checking out an online search engine for "HDMI to DVI adaptors." This should pull up a number of links that can provide you with not only detailed pictures, but also average pricing of the products available to you as well.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 02, 2008 | Sony Playstation 3 (PS3) Console
Vizio P42HD Television Logo
65 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
