Question about MSI Computers & Internet
Snapon verus scanner
Says problem with soundcard
The OBD2 is not communicating with scanners or Verus what do I do?
i once found that the 12volt accessory fuse is blown. its was also the same one for the ECU thats the reason it does not connect
Mar 06, 2015 | 2002 Nissan Maxima SE
Remove speed limiter
Most cars can have the speed limiter removed from dealer OBD scan tools or third party scanners like SnapOn or OTC etc... you can also remove limiter if your car has a custom programmer made for it for performance mods.
Jul 07, 2014 | Vehicle Parts & Accessories
Hello I have a 2002 chrysler town and country lsi 3.8 and I'm installing a tcm and after installing do I need to get that reflashed or will the computer learning itself
You will need a scanner to relearn. Sometimes a used will will work but I suggest getting it relearned. It only takes 10 minutes to do if you have the scanner. SnapOn or OTC scanners will work. I know this because I have uesed both of mine to do it with. Good Luck !
Aug 13, 2012 | Cars & Trucks
98 vortec ckt ,learn snapon has my scanner for repair ,there is a way to relearn ckt or crankshaft sen with out scanner
Nope, must be enabled via class 2 data, so you'll need to barrow a scanner or wait til yours is back.
Oct 18, 2009 | 2003 Chevrolet Tahoe
95 Blazer code P0401
Have a little read of this link, it may help you.
http://www.obd-codes.com/p0401
Jun 19, 2009 | 1995 Chevrolet Blazer
I change the cam senson on a 99 chevy astro it have the code of the cam senson on the scanner but the code still there can some one help me with this
I CHANGE THE CAM SENSOR ON A GMC SAFARI AND IT WILL STILL COME ON THE CAM SENSOR CODE. BY THE WAY I OWN A SNAPON 2500 GRAPHIC SCANNER AND UNTIL I FOUND OUT THAT THE DISTRIBUITOR NEDD TO BE ADJUSTED AFTER I CHANGE THE CAM SENSOR IT WAS FUN I LEARN SOMETHING I HOPE THIS HELP SOMEONE LATES
May 01, 2009 | 2005 Kia Sedona
On a snapon modis scanner i got a code 22, 42, 92 anybody have an idea what these codes mean?
Didn't your OBD reader come with a cd which contains the code meanings? if not see your Snap-On rep.
Hope this helps,
Please remember to rate my effort,
Paul 'W'
Onyer~EDson(:)0 {#><U.K.
Jan 20, 2009 | 1989 Mercury Cougar
Computers & Internet Logo
20 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
