Question about IBM Computers & Internet
BladeCenter E 8677 3RA DISPLAY PROBLEM
DISPLAY PROBLEM AND SOME DOUBT POWER ALSO. POWER SOUND WAS BIG SOUND CONTINUELY
    Master:
  • 785 Answers
Power supply is bad or ram errors
Posted on Aug 18, 2014
When we on the tv display only Sony and auto on/off continuely
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jun 13, 2016 | Sony Televison & Video
Phone works but display doesn't anymore.
sorry but possibly the manufacturer can assist you through their tech support .
Jun 18, 2015 | Lands Phones
IBM BladeCenter HS22 (7870) not boot from cd/dvd
Go into the BIOS and change the boot devices so that the CD/DVD boot first. Also, make sure your server is seeing the correct blade and its devices. (If not check your connections.)
Good Luck
C2Solutions
Feb 24, 2011 | IBM BladeCenter HS22 (7870B4U) Server
Ibm bladeCenter -S storage one hdd offline .how to forcely online
It probably is "offline" because it is "dead", and thus cannot go "online".
Replace the disk-drive, and the replacement should go "online", automatically.
Jan 23, 2011 | IBM Bladecenter H 88524XU Hard Drive Array
Regza Toshbia No picture No sound
IF YOU RAN YOUR SET 24/7 FOR A WHILE, BEFORE IT DID THIS ACTION, YOU MAY TRY TO LOOK AT THE POWER SUPPLY BOARD. FIND ANY BLOATED ON TOP ELECTROLYTIC CAPACITORS, HERE YOU GO: REPLACE THEM WITH SAME VALUE AND VOLTAGE.
NEED SOME EXPERTISE TO POKE IT OPEN AND INSPECT THE SET. BUT, I DOUBT IT! JUST GOT COUPLE TOSHIBA'S WORK ON, IN BOTH CASES IT WAS INVERTOR BOARD, ATTACHED TO DISPLAY. DID YOU FEEL ANY SMELL? POPPING SOUND? USUALLY, TOSHIBA'S POWER SUPPLIES ARE WELL BUILT, BUT INVERTORS ARE MADE BY PHILLIPS ANS HIGH FAILURE PART(S). YOUR SIZE MIGHT HAVE 2 OF THEM. MASTER AND SLAVE. MUST BE REPLACED BOTH. NON-REPAIRABLE, BUT HAVE DUD VALUE. STILL, LOOKING FOR COUPLE BIG ONES TO SPEND JUST FOR PARTS.
GOOD LUCK, ALEX'S TV.
Feb 22, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Friend turned volume up.. now display/volume died no sound
Sounds like your friend burned out the power amplifier. That would be the only reason none of the channels work. Unless the unit was muted by accident and no one checked the mute function - though I doubt that.
Jul 04, 2009 | Denon Audio Players & Recorders
How many hours is the normal charging of toshiba laptop?
That depents on what you do with it.
Battery drainers are:
- Big applications (Photoshop, Music, Video, 3D, Games...)
- Wlan/Wifi/Bluetooth
- Sound and Video playback
- Display set to brightest
- Burning/constantly reading Dvd/cd
a new laptop just sitting there should last 4-5 hours.
Under full workload i doubt that itll last longer than 2-3
but it also depends on the modell.
Feb 02, 2009 | Computers & Internet
Just beeping
Have you done something on your computer before that happen? Maybe change your display resolution? or video card?
Oct 24, 2008 | Gateway GT5654 Desktop PC
Panasonic-36" Pana Black Tube - channels are continuely changing
I would suggest to let the water dry or you can use a hair dryer to blow air through the buttons, you could also open the back cover to blow air towards the front panel to dry it faster.
The spilled water is acting as a conductor, that is why the channels are changing on their own.
Good Luck.
May 26, 2008 | Panasonic CT-36HX41 36" TV
No display on moniter but cpu is running
change the RAM(RANDOM ACCESS MEMORY) of your pc.
Dec 12, 2007 | Intel Motherboard
Computers & Internet Logo
57 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
