Question about Ruud Handle Air Conditioner
3 Ton Ruud compressor
My Ac guy came by and said the compressor is shorted, he quoted me a 5-8 hundred dollar price, is that fair...does anybody know.
Thanks
bob
  • 43 Answers
Is the unit over five years old? If so it is a fair price for conpressor, parts, labor and refrigerant. Have him give you a firm price. If it is an older unit, say over 10 years, and you have the money replace the complete system
Posted on Jun 16, 2009
I dont get cold air from ac. mechanic told me to replace evaporator . he tested using a sniffer inside the car after filling freon. Gave me aquote of about 1600 USD.wanted to know if this is a fair pr
For your make and model that is a way fair price. BMW seems to be a little more labor intensive them some other vehicles. But those recommended repairs are well worth it and help the longevity on your vehicle.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_677dced97ad9bddf
May 08, 2017 | 2000 BMW 323i
RUUD Achiever 3 ton roof unit. Pops fuses. Place "hard" fuses in and it would pop the house's 60A fuse. Checked both motors and they spin just fine at the touch. Both caps also...
The compressor is going bad or the unit is charged wrong...
Whatever the cause the problem is the compressor locking up and blowing the fuses...
Clean the condenser coil...maybe the pressures are going too high...
If that don't work, then the compressor is shot or over charged...
Here is a tip that I wrote about how to clean your condenser
Cleaning Air ConditionerCondenser Coil with Pictures
heatman101
Jul 25, 2011 | Ruud UBHC Air Conditioner
I have a Ruud AC model UACC-056jas serial number 3170 F1085 5657. Does anyone know the tonnage?
That would be a nominal 5 ton BTU unit or 56,000 btu....
At 12,000 btu/ton you can see that it is just a bit short of 5 ton but larger then 4 ton....actually about 4.75 ton....
heatman101
Apr 12, 2011 | Heating & Cooling
We have a fairlynew 5 ton Central Ruud or Rudd unit that it is so noisy in the yard that we can not stay out there. We thinkit is the compressor. Help
I have a new 13 seer rheem or ruud same thing. I can not here it run. Uou must have a bad compressor. Ruud put schroll compressor in and when they start to go out they will drive you nuts they are so loud. Get it changed before your warranty runs out. Ruud will change your compressor if it to noisy. No problem. Russ
Jul 20, 2009 | Ruud Central System Air Conditioner
A/C Compressor Problem 3 Ton
IF the compressor is under warranty they should not charge you anything. it is according to what type of warranty you purchased, If the business is gone, i don't know much of what you can do other than calling ruud directly. Most likely the unit is past the warranty. Call ruud to be sure.
Jul 12, 2009 | Heating & Cooling
Need to replace 3 ton compressor
Depending on age of the unit. The compressor amy under warranty. The replacement is something that should be done by a service tech. You have 3,5 ton unit Rus
Jun 14, 2009 | Ruud UAKA042 Air Conditioner
Replaced my 5-year old 3-ton 12 SEER Goodman outside condensing unit with an older 3-ton RUDD condensing unit because of lack of funds. Now the compressor has gone out on the RUDD. Is it better to replace...
at 5 yr on goodman unit rhe comp should of been under warrenty if theat is what was bad with it on the rudd that was a 3.5 ton out door unit are you sure the pump is bad pulling locked rotar amps or shorted to ground check the wires on the comp to make sure not burnt check the capicitor as far as replacement i always lean twoards new unit unless not going to live there long due to comp is 1 yr and labor around 850 +325 for pump i would go with another used unit over comp replacement 13 seer goodman w 99yr pump and latley have 5 yr free labor and I normally dont recommend a brand of unit on this site go to a hvac store and ask who may have a used unit I have had some still w warrenty before that came from remodel jobs in up scale areas! if helpfull rate me good luck
May 12, 2009 | Ruud UAKA042 Air Conditioner
Is the Model #25HBA360A300 a 5 ton unit?
36k-car-ms Key Features AC Type: Split System Additional Features: Ductless Cooling Capacity: 36000 BTU/hr Electrical Requirements Voltage: 220It is a 3 ton aprox 550 sq feet per ton is required
May 01, 2009 | Carrier 36KCARMS Air Conditioner
I need help selecting the best Amana 5 ton furnace/ac.
I believe you are asking which furnace to go with?
Just some clarification first.
The "condensor" is the outdoor unit.
A "Compressor" is the device inside the outdoor unit that pumps and "compresses" the refridgerant.
An evaporator is the indoor coil, it has refridgerant running through it.
The furnace is completely seperat from the condensor and evaporator.
I "THINK" you are saying that you are looking to buy an AMANA system with a 5 ton 14 to 16 SEER condensor, and a furnace, but you need suggestions on the furnace.
typically when you purchace a condensor, the evaporator coil is simply matched by the manufacturer to the specific condensor you purchace, there is no choosing to deal with. All condensors ofcourse come with a compressor already installed.
If my assumption about your request is correct, maybe this will help.
Amana's 90+ furnaces are great units. I would recomend them to anyone. The 80+ uses a somewhat inferior heat exchanger, and is ofcourse less efficient.
Anything higher than a 90+ can take quite a while to recoup the costs of the enitial purchace through your efficiency savings.
If it were my home, I would go with the 90+ furnace, and the 16 SEER Condensor/evaporator system. But ultimatly, its up to you, your efficiency standards and your wallets potential.
If you live in a northern state where AC is little needed, I'd go with the 14 SEER AC.
Again, an initial cost verses long term savings issue.
Dec 09, 2008 | Amana Heating & Cooling
Heating & Cooling Logo
198 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
