Question about Freezers
My upright rank arena BF260 has the red and orange light on and not the green and is not working can you expalin why, thanks.
Only red and orange light on not the green and not working not sure why???
  • mike cooper Apr 26, 2014
    Hi Lisa Hendrie, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? The green light is immaterial. If you have red and orange on the power is ok. Check Thermostat, compressor electrics etc first.
5 Suggested Answers
  • 7 Answers
SOURCE: Defrost light stays on
Try advancing the defrost timer manually.
Posted on Jan 17, 2008
  • 1531 Answers
SOURCE: I purchased a used upright freezer Fridgiaire
the red light is a temp warning light and will not respond unless the temp goes way above the set temp
Posted on Oct 13, 2010
  • 91 Answers
SOURCE: Upright freezer orange and red
Draw fan has failed, temp unreachable over the past cycle of 24hrs, turn your unit off for 24hrs and defrost it, restart and should work fine for a few days, if so, replace fan and defrost element only. Call service tech for this unless you are clued in on this work, not that costly.
Posted on Aug 28, 2011
SOURCE: I have a Rank Arena BF260 freezer I got from my
It is the fast freeze switch. It keeps the freezer full on even if it gets down to its operating temperature. You will see the yellow or orange light come on. You do this if you want to add some new item in the upper fast freeze compartment. Make sure you turn it off after about 2 hours.
Posted on Nov 11, 2011
Icetech Chest Freezer Orange Light Is This on All the Time
Red is alarm, Green is power OK and Orange is super cool. There is a button next to it to turn that off or it will not stop cooling.
Jul 03, 2017 | Freezers
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Sep 02, 2014 | Electrolux Freezers
Green light wont come on
Is unit running? Orange switch - is that the fast freeze switch? If on and running, green light faulty. If nothing happening, start with fuse, test the switch and make sure power is to the thermostat.
Apr 04, 2014 | Freezers
Orange light is on instead of green light on freezer what does this mean
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees - orange light : pressing the so-called S-switch which means that the compressor is running continuously. The S-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
Dado
Jan 14, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
Upright freezer orange and red light on but green light off can you advise? Frigidaire freezer.
Aug 28, 2011 | Frigidaire Freezers
I have a Rank Arena BF260 freezer I got from my dad. There is a switch on the front, if it is to the left, there is no icon on it, if it's to the right it has a snowflake icon show. Dad didn't even realise...
Oct 17, 2010 | Freezers
We have an ancient Kenmore Chest freezer. I don't know what the orange, green & red lights mean. Also which is "ON" 0 or -
the light tell you if the door is closed properly or not . Close the door tightly and check the lights. Then open it and check them again this will tell you the positiopn of the door for each colour
Oct 06, 2010 | Kenmore Chest Freezer 16082
On the bottom outside of freezer bottom front what is the on and off switch for it located between a red an orange color light
it is the fast freeze button,use it when filling up freezer when less than 1/2 full.red is a high temp warning.orange is fast freeze on/working.
Jun 18, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
91 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
