Question about Inverter KEB COMBIVERT F5
Fcon in keb f5
I have a keb f5 inverter and it is showing Fcon after i give connection to St terminal. What is the meaning of Fcon, i did not understand from the manual
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • Inverter Expert
  • 120 Answers
Fcon = forward constant
The inverter is operating at the set speed in the forward direction.
Posted on May 08, 2014
3 Suggested Answers
SOURCE: F5 keb inverter problem
i have a prblem in the F5 keb combivert it's show Error
E.OC & E.puci & E.Puch could you please advice us with the proper solution
thanks
Posted on Apr 11, 2010
  • 120 Answers
SOURCE: Fcon in keb f5
Forward CONtinues
System is at the commanded speed in the forward direction.
Posted on Apr 01, 2014
I have a KEB combivert F5. The parameter ru 00 shows nop even if i give switching to terminal 16 for control release.Please help.
This may be due to the inverter waiting for an ST signal via buss communications.
What is the part # of the unit in question?
The inverter is recognizing that terminal 16 is going active but still waiting for another command to enable the inverter.
Mar 09, 2015 | Inverter KEB COMBIVERT F5
Tip
KEB COMBIVERT F5 - Standard communications connections
Here is an overview of the the items required to communicate with the KEB COMBIVERT F5.
***X4A and X6B connections require special cable from KEB. This is a 24Vdc connection and will damage your PC/inverter if the proper cables are not used.**
on Feb 21, 2014 | Inverter KEB COMBIVERT F5
Fcon in keb f5
Forward CONtinues
Apr 01, 2014 | Inverter KEB COMBIVERT F5
F5 KEB inverter nop problem
If using bus communications (Can, ProFi, Mod, ext), there may be a communications command (Software signal) that is not being provided. Hardware and software enable signal required to obtain LS.
Possible that the terminal on the control card is bad due to miss connection or signals outside of the rated value.
Nop is showing in the display after connecting the ST connections
Nop = No operations
Provide signal to enable input (ST).
Fcon
Forward CONtinues
Hi, I have KEB 07.f5.c1b-3b0a inverter. I just got
Via Combivis, write a value of -4 to Fr.01. This will set all parameters back to the factory default values.
Then download your backup parameter file.
Sep 24, 2013 | Inverter KEB COMBIVERT F5
Indicate nop
Need to enable the inverter via the ST terminal
Jan 23, 2013 | Inverter KEB COMBIVERT F5
How to select rotation for one inverter keb f5 with servomotor
By default direction is selected via digital signals to the control terminal strip of most Combivert inverters.
Check your manual for forward and reverse terminal.
Dec 02, 2010 | Inverter KEB COMBIVERT F5
thanks
Mar 10, 2010 | Inverter KEB COMBIVERT F5
Inverter KEB COMBIVERT F5 Logo
111 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
George Scott
George Scott
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
