Acer aspire ax1301
I have the Aspire AX1301 Desktop Computer with AMD Athlon II x 2, 4MB RAM, VNIDIA 512MB VGA. The computer does not turn ON unless press the power switch for more than20~30 times... I replaced the Power Supply unit and jumped the power switch wires, but still same problem. I suspect the Motherboard is defective, and like to replace the Motherboard. Can I use the X1200/AX1200 Motherboard for the above AX1301 machine ? I only find this X1200/AX1200 Motherboard in the market. Please advise me. Thank you, Bogie Yanagi Email: bogieyanagi@gmail.com
    Top Expert:
  • Computers & ... Master
  • 12,962 Answers
Try to locate the bad capacitor(s) on the board responsible for the hassle. They usually bulge on top or leak when they go bad.
Any board that fits will work - just get one that is compatible with your memory and processor and you are good to go.
If you check the website for your computer under support you can get the info you need for both your mo bo as well as the proposed one and you can take it from there.
Posted on Apr 01, 2014
  • 3600 Answers
SOURCE: ACER Aspire AX1200-U1510A:
you have given the memory chip number and not the computer model the chips you have are 533 MHZ DDR so I would suggest you click on start go to my computer right click on properties and it will list the chip set. here is a web page you can go to to see the memory you have.
acer
-aspire-ax1200-u1510a-tower-desktop-memory-1x-512mb-91ad346008-pc2-4200-ddr2-533mhz-unbuffered-dimm-upgrade.html">http://www.memoryupgrade.pro/512mb-acer-aspire-ax1200-u1510a-tower-desktop-memory-1x-512mb-91ad346008-pc2-4200-ddr2-533mhz-unbuffered-dimm-upgrade.html
Posted on Feb 11, 2010
ginko
  • 19396 Answers
SOURCE: PC dead. Replaced power supply. No lights. No nothing.
When that happens it is usually the motherboard.
To test parts you need a benchmark.
PSU can be tested using a multimeter.
Motherboard is tested using a tester like this one: PCI Test Card, PC Analyzer, Motherboard Test Card
Ram and CPU (CPU sometimes get damaged) are usually not damaged by this kind of problems, they can be tested mounting them on a working motherboard. For the RAM we also use a RAM tester that costs about $200.
Ensure also that the switch contacts to new motherboard are installed properly. A technician can test cabinet power switch using a multimeter, or carefully bridging with a screwdriver the switch on contacts on motherboard (do not do this unless you are sure about what you are doing)
Test the new PSU on a different socket, when a PSU blows , it may damage the main socket.
Also remember that new power supply units have two connectors. The big rectangular main one (24 pin) and a smaller 4 pins squared one.
As an home user you may not have access to testing equipment, therefore my suggestion is.
Ensure you are using the right PSU.
Ensure that the motherboard is connected to power switch.
Test the new PSU with a multimeter.
Examine the motherboard for blown or leaking components and burnt areas.
If you do not find anything, but the mainboard is still not working, then buy a motherboard-cpu bundle compatible with the PSU that you bought and assemble a new system inside the old cabinet.
Regards.
Posted on May 04, 2009
benwabnick
  • 2404 Answers
SOURCE: Motherboard repair
Best thing to do is to make sure only the CPU, Power Supply and memory are hooked up to the motherboard and then turn it on and see if you get video. If you don't get video then it probably is the motherboard that is bad and it wouldn't be worth your time spendingany more postage on it.
Also check the capacitors on your motherboard and see if any of them are bulging from the top, if they are then you might want to try and replace those with capacitors of the same value.
My feeling though is that the motherboard is bad and you would need to get a new one.
rytechltduk
  • 72 Answers
SOURCE: I have an Acer Aspire M5100 with a Acer F690GVM
AM3 Processors are, as you state, backwards compatible with AM2 Sockets. However, this is based on a BIOS update and may not be the case in all motherboards. I would recommend checking with ACER directly, as to weather they have relased an update for this bios to support this function. I have done a search but turned up nothing, but they may not have released it yet. My initial thought was that this seems to be a problem with these OEM boards.
Posted on Nov 05, 2010
  • 434 Answers
SOURCE: I have M4A88T-M LE +
Does your monitor show anything at initial power on and then go blank, if so try booting into Safe Mode...Right click on your screen, select Properties and reset your video settings
Posted on Feb 11, 2011
How to make it fast my acer aspire R7 computer, since 8GB RAM and 1TB HDD intel core i5, but still very slow sometimes cannot play the video
It should play video with 8 meg. The max memory is 12m but you have to take the whole laptop apart to increase it.
Aug 10, 2014 | Acer Aspire M1100-U1402A Refurbished AMD...
Pc
I'm not sure what that error means, but the first drive is usually drive 0 on computers. Maybe this will help. You can verify in BIOS. gl
May 30, 2013 | Acer America Acer Aspire AX1301-U9032...
Pxe-e61 media test failure check cable
The unit lost communication to the hard drive. You need to physically re-seat the drive and make sure BIOS sees it.
Feb 03, 2013 | Acer America Acer Aspire AX1301-U9032...
Acer ax1301 won't power on
It's very possible that when your power supply died so did your motherboard. Especially if a power surge was involved..
Aug 18, 2012 | Acer America Acer Aspire AX1301-U9032...
Acer Aspire AX1301.. less then year old, over heats as soon as I go on net ??
it is probably clogged up with dirt look through the vent holes to see if you can see dust clogged up
if there is then clean it
Feb 26, 2011 | Acer Aspire X1301U9032 (PTSCM02007) PC...
What steps do i neeed to take for adding ram to aspire m1100?
1st open the machine
look for the RAM cards
if there is only one, remove it and read the type
buy exact same type RAM card of higher capacity say 512MB or 1GB
insert it into the other slot and switch on PC
Nov 29, 2010 | Acer Aspire M1100-B1300A Refurbished AMD...
Acer aspire wont start past boot screen
May be the hard drive is not detecting properly on the computer.
Try resetting BIOS.
If that doesnt help, try checking your hard drive on a different computer or using some 3rd party HDD checker.
Nov 05, 2010 | Acer Aspire M1100-U1402A Refurbished AMD...
Pc turns on but screen says no signal
There may be problem in Monitor or VGA Card. When you Turn on PC the Monitor light is green after 10 second if It will be orange . It means your monitor is alright . but problem in you VGA Card.
  • When the PC turn on there is any beep.
  • If no beep then your RAM is alright.
  • Problem in VGA Card.
Mar 15, 2010 | Acer Aspire M1100-U1402A Refurbished AMD...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
