Question about Inverter KEB COMBIVERT F5
F5 KEB inverter nop problem
I have a KEB F5 combivert 1.5KW VFd. The problem is that even after connecting the ST terminal the display is showing "nop" when it must be showing "LS", due to which the vfd is not running. I have checked the parameters but still could not find the problem. Please help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • Inverter Expert
  • 120 Answers
If using bus communications (Can, ProFi, Mod, ext), there may be a communications command (Software signal) that is not being provided. Hardware and software enable signal required to obtain LS.
Possible that the terminal on the control card is bad due to miss connection or signals outside of the rated value.
Posted on Apr 01, 2014
How to save the parameters in KEB F5
Here is how to use the keypad. If a decimal shows up after the value is changed, enter must be pressed to save the value.
Also insure that the inverter is not enabled or in nOP status.
Jun 27, 2016 | Inverter KEB COMBIVERT F5
Tip
KEB COMBIVERT F5 - Standard communications connections
Here is an overview of the the items required to communicate with the KEB COMBIVERT F5.
***X4A and X6B connections require special cable from KEB. This is a 24Vdc connection and will damage your PC/inverter if the proper cables are not used.**
on Feb 21, 2014 | Inverter KEB COMBIVERT F5
I have a KEB combivert F5. The parameter ru 00 shows nop even if i give switching to terminal 16 for control release.Please help.
This may be due to the inverter waiting for an ST signal via buss communications.
What is the part # of the unit in question?
The inverter is recognizing that terminal 16 is going active but still waiting for another command to enable the inverter.
Mar 09, 2015 | Inverter KEB COMBIVERT F5
Fcon in keb f5
Fcon = forward constant
The inverter is operating at the set speed in the forward direction.
Apr 01, 2014 | Inverter KEB COMBIVERT F5
Fcon in keb f5
Forward CONtinues
System is at the commanded speed in the forward direction.
Nop is showing in the display after connecting the ST connections
Nop = No operations
Provide signal to enable input (ST).
Indicate nop
Need to enable the inverter via the ST terminal
Jan 23, 2013 | Inverter KEB COMBIVERT F5
How to select rotation for one inverter keb f5 with servomotor
By default direction is selected via digital signals to the control terminal strip of most Combivert inverters.
Check your manual for forward and reverse terminal.
Dec 02, 2010 | Inverter KEB COMBIVERT F5
F5 keb inverter problem
i have a prblem in the F5 keb combivert it's show Error
E.OC & E.puci & E.Puch could you please advice us with the proper solution
thanks
Mar 10, 2010 | Inverter KEB COMBIVERT F5
When ion the power display shows nop i want to go in cp parameter but after press func key the figuers comes like aa pp.
Does the display say appl? if so, use the up arrow and go to a value of 200, then pres the enter key. Display should change to cp_on.
Oct 27, 2009 | Inverter KEB COMBIVERT F5
Inverter KEB COMBIVERT F5 Logo
275 people viewed this question
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
