Question about Regina Chain 520 ZRD Chain and Sprocket Kit - 520 Conversion Kit 5ZRD/116-KSU007
My bike chain always become loose ??
While driving condition it making a such a little bit of noise i don't know what? it is wheather due to chain or sprocket
    Guru:
  • 145 Answers
Both, chains and sprockets have "pitch" if they are not the same pitch the chain will become tight then loose breaking the bearings and destroying the chain
Posted on Apr 13, 2014
Noise and rough pedaling from main crank
not knowing if this is a single speed or multispeed bike, this could be several different things and a proper analysis by a mechanic at your local bike shop is what is needed.
It could be that the chain is too tight, it could be the derailleurs are out of adjustment and the chain is skipping between gears or rubbing on the derailleurs. It could be a bottom bracket out of adjustment and the bearings are loose and making the noise. It could be a loose bottom bracket shell in an aluminum frame make creaking noises.
Aug 14, 2014 | Cycling
How can i stop the noise from chain set?
hi there is your chain in good condition or worn out ,is the chain dry and needs oiling or is it incorectly adjusted for the bike ,or is the chain out of aliagnment these would all cause noise problems ,or if the chain has been replaced before is it the right size for the sprockets ,and are the sprockets in good condition ,to check if the chain is stuffed move the chain sideways left to right of your bike and if it moves more than a sixteenth of a inch it is worn out .hope this helps cheers
Apr 23, 2014 | Yamaha YZF-R15 Motorcycles
Bajaj Discover 135cc 2009 model Drive Chain Making Obstructing sound
Hi, Vinod you may need a new chain and sprockets with that many Kilometers for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Easy Motorcycle Chain Stretch Test
Is Your Sprocket Worn Out
Bajaj Discover Technical Specifications Bajaj Discover 135 DTS Bikes in...
Owner Manual Bajaj Auto
Bajaj Discover DTS 135 2009
Mar 22, 2017 | 2008 Bajaj Discover DTSi
Help my sons mini pocket quad is making a ringing noise and I don't know what it is. Please Help
open the clutch case there will be a bolt came loose. the clutch is behind the chain drive bolts can come loose from vibration buy lock tight for bolts from halfords do not run untill you have fixed this will rip the clutch apart
Mar 31, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
Chain noise
Excessive drive chain noise is caused by the following, lack of proper maintenance, keep it clean and lubed, next would be correct adjustment, most bikes about 3/4" deflection at center run of chain up and down play, next would be a worn out chain and/or drive or driven sprockets, last but not least and very noisy is the chain being stretched, if you rotate the wheel the chain gets loose then tight. Always check the sprockets for excess wear when replacing a chain, the drive sprocket on the engine is hardened steel and wears the least.
Feb 09, 2012 | Bajaj Pulsar 180 Motorcycles
Hi I have a Toyota Corolla 2001 160i. when I drive over 100kms my steering becomes very loose and there is not much tension anymore. Also when I turn left or right I hear a noise, like something under the...
As you said, steering feels lose while driving and makes noise on turn, please don't drive as it condition. It seems cars front low arm lose or got damage, get it check on urgent basis. It is danger.
Thanks
Yogesh Mule
Sep 15, 2011 | Toyota Corolla Cars & Trucks
2003 Harley Road King....Just had the rear tire replaced and now I hear a slight whining noise. Pulled off the interstate for fuel and almost every gear "Jumps" unless I really baby the throttle....
Hmm! This is a difficult one as I can't feel the tension of the belt nor hear the sound for myself. Any time you have anything done to your machine by anyone, ALWAYS CHECK BEHIND THEM. Mechanics are only human and as such, we make mistakes just like everyone else. There is nothing different in a Harley-Davidson mechanic than any other mechanic. And, since it's you riding the bike, you have a vested interest in making sure that your bike has been repaired correctly and is safe to ride. Always go behind the mechanics and check for loose bolts and things that are not done correctly within the scope of your knowledge of your machine. If you don't know anything about your bike, at least look for obvious things that were overlooked. It's for your own safety.
As for the noise. Check the alignment of the rear wheel in the swingarm. Make sure the inside edge of the final drive belt is not rubbing the edge of the tire. Check the tension of the drive belt. Most drive belts feet "too tight" to the average person in that they don't feel like they've got any slack at all when you check them. It should have something like a 1/2" deviation with a 10 pound force applied to the belt. Usually, a loose belt will "chirp" when you change gears. Sight along the top of belt looking toward the engine and see if it looks straight. Check the adjuster screws to see if they're the same length. Basically, look for obvious things wrong. If you're still in doubt, take it to a shop and have them look at it. On several occasions, I've seen people load their bikes too heavily and the bike sits down in the rear end. This caused the top of the final drive belt to rub the underside of the inner primary just below the starter and make a whining noise. All I did was to tighten up the shocks just a bit to stop the problem. You may not can see this as you must be sitting on the bike to check. Get a friend about your same size to sit on the bike or someone else to check it while you sit on the bike.
This is about all the advice that I can give you without actually putting my hands on the bike which I can't do. I wished I could have helped more. Always remember, it's your fanny riding that bike and if something isn't done correctly, it's your fanny that may get skinned up. You don't have to be a high-dollar mechanic to notice things that just don't look right on your bike but if you don't look, you won't see them. NEVER trust any mechanic to not make a mistake. I've been doing this for years and I still make mistakes from time to time but usually I catch them before the owner gets the machine back. See, I learned to check behind myself years ago.
Ride Safe
Steve
May 03, 2011 | 2003 Harley Davidson FLHRCI Road King...
How often does the chain need lubricating
Touch your chain, feel it, does it feel super hot, does it feel sandy, does it make alot of noise, is it loose?
Riding conditions is the main factor for your chain.
Do you travel down alot of dirt roads? the worse the conditions the more frequent lubrication is required.
If your chain gets alot of dirt on it then you'll need to wash that off and then lubricate it.
A well maintained chain will also save on your sprokets.
I check mine once a week, sometimes its good and sometimes its dirty and needs washed and lubricated.
I use chain lube that doesn't fly off and get all over my bike. In a pinch any lube will due.
Nov 29, 2010 | 2008 BMW G 650 Xcountry
Honda CB Seven Fifty 1992. Sudden engine noise
I have no answer, but I have a 1994 cb 750 with a noisey cam chain, I need a chain and a link, I know they are avaialble, this will allow for repair engine in sit, I had a guy offer one for good money with link but lost his frikking details, any one know where I can get a chain and link for the 750 1995 cb bike fires first on the button be a shame to scrap it, break it, any one ionterwested in the bike i want 900 have aero qups hagen shox, new pilot tyres, also need one fork seal doing, and I know this is a easy job, I do all my suzuki ones myself.
Jan 25, 2010 | 1992 Honda CB 750F2 Seven Fifty
I have a rattle noise . it sounds like my front sprocket
were is the rattling coming from?the onle rattling that i can think of without noing were its coming from is your chain might be snaping around from 1st to 2nd cause its a little to loose, or your cam chain is a litttle loose. a bolt near the engine could be loose and the vibes from the engine can be rattling. tell me wat bike u got, the year and were the noise is coming from and other details and i can help u out
Feb 02, 2009 | 2001 Suzuki GSX-R 750
Regina Chain 520 ZRD Chain and Sprocket Kit - 520 Conversion Kit 5ZRD/116-KSU007 Logo
56 people viewed this question
Top Regina Garden Experts
Dennis Key
Dennis Key
john h
Are you a Regina Garden Expert? Answer questions, earn points and help others
