Question about Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch
How do you change part # wr55x10025
Change part # wr55x10025
    Prodigy:
    An expert who has answered 500 questions.
  • Hotpoint Expert
  • 650 Answers
This is a thermistor. It depends where it is located how you would be changing it but the generic answer would be unplug the refrigerator. remove the old one leaving some of the leads from the old one before you cut the wires. so you have some wire to work with. Using small wire nuts or crimp connectors wire the new thermistor to the old leads from the old thermistor it is best to either fill the wire connectors or crimp connectores wirh silicone sealant or tape the connectors with electrical tape to prevent water from entering the connections. Put the thermistor into position and away you go.
Posted on Apr 13, 2014
Do you have to remove crisper to replace temperature sensor?
Almost all hardware questions are model specific in terms of answers. Some refrigerators have multiple sensors. You might locate a service manual for the brand and model via a search. Or even a video:
Refrigerator Repair Replacing the Temperature Sensor GE Part WR55X10025
Apr 15, 2018 | Refrigerators
Refigerator and freezer all of the sudden don't seem to keep cold enough
The back wall of your freezer covered with snow? If it is I would suggest you replace the heater and a thermistor - Heater: WR51X10101 Thermistor: WR55X10025. If no snow then it is probably the main pcb: WR55X10656
Mar 24, 2013 | GE GSH22JFT Side by Side Refrigerator
HOTPOINT FRIG GEHSM25GFRESA THERMOSTATS WERE ON 5 NOW ON 1 TO KEEP UNIT FROM GETTING TO COLD
Either your auto damper has frost blocking it open or the=> WR55X10025 Thermister is defective.
Try using a hair drier to force warm air into the damper to see if the damper will close better by melting any ice that may have the damper stuck open.Here is the=> WR09X10050 Damper Thermister Assembly Instructions on how to change this part can also be found on the same page HERE If you have any questions please ask, Thanks Sea Breeze
WR09X10050 Damper Thermister Assembly Below
Jul 11, 2012 | Hotpoint HSS25GFP Side by Side...
Coils frzg up in freezer section refrig side to warm. changed terminator and heater.i have a ge sxs gss22wgmd.
well i wonder if you have changed both the white sensor part number WR55X10025. This is the sensor that tells the mother board to go into defrost. The other terminator is only a backup safety stat. If this dont solve your defrost problem. Then change the motherboard.
Aug 17, 2011 | Refrigerators
Zisb480dmc monogram, replaced Fresh food damper(-17 in freezer, 48 in refer), did not solve. Replaced Main board and fresh food thermistors, worked 10 days, problem became 44 in fresh food -27 in freezer....
there's a temp sensor on the evap coil part WR55X10025,i would change that out and when you changed the board if there's a wire in the second pin of the connector with ithink 9 pins on it you have to cut the wire that's in the second pin,if there's no wire in the first pin but one in the second pin then leave it alone,look at the paper that came with the board and it will tell you what connector it is,let me know what you find,the old sensor has like a black piece on it where the wires come out of it,the new one is all white but you should change the sensor when you change out the board
Sep 30, 2010 | GE Refrigerators
Refrigerator won't cool and freezer has ice build up on back.
its a defrst problem most likely the defrost thermister wr55x10025
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
How to install the sensor part number WR55X10025
To install remove the panel protecting evaporator, cut the 2 wires to the old sensor, crimp the 2 new wires on and snap the new sensor to the clip on the evaporator.
Apr 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge freezes everything!
The defrost timer has failed. It is defrosting too long.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 05, 2009 | Washing Machines
Freezer on GE model 25 GSS25SGMDBS not working
change sensor temp- part number WR55X10025. You can get from searpartdirect. approximate$7.00
Jul 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Logo
61 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
